Monster Cable® SS-4 Multispeaker Selector
#96
4.7
based on 6 reviews
Ratings Distribution
5 star
4
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.3
Low Price:
$41.75 at AllegroMedical.com
 Trusted:
$89.99 at RadioShack
Find it at Amazon
$41.75 - $99.99
from 3 stores
More Images
Pros
  • Easy setup (3)
  • Accurate controls (2)
  • Good power output (2)
  • Great sound quality (2)
  • Durable (1)
  • Pricey (1)
  • Quality build (1)
See less See more
Cons
  • Limited functions (1)
  • No volume controls (1)
  • Runs hot (1)
Best Uses
  • Basic systems (2)
  • Home theater (2)
  • Adding more speakers (1)
  • Audiophiles (1)
  • Large rooms (1)
  • Multiple zones (1)
  • Smaller rooms / apartments (1)
Provided by MAGo Enterprise
Internally Wired with Monster Cable for the Best Possible Sound Product Information An Ordinary Speaker Selector Can Degrade Amplifier Performance Many people demand the flexibility and convenience of using multiple speakers throughout the house - even outdoors. If you hook up more than one speaker pair to your amplifier however the impedance (ohms) may drop to a dangerously low level stressing your amp beyond its limits causing circuitry damage or shutdown. You may avoid this potential nightmare by connecting your speakers to a multiple speaker selector. However ordinary speaker selectors can also degrade system performance. Although they use a resistor in series to protect your amp from low impedance loads these ordinary inductive resistors can cause noticeable high frequency loss so you hear less detailed music reproduction. The power rating is often low potentially damaging your speaker selector if you're using a high current amplifier. Monster Delivers an Unbeatable Combination of Performance Convenience and Amplifier Protection With the Monster Cable Speaker Selector you can enjoy the convenience and flexibility of listening up to4 speaker pairs at a time in any location. With Monster's advanced Amplifier Protection circuitry you will have the comfort of knowing your amplifier is delivering maximum power and performance. When engaged this impedance matched circuitry maximizes high power amplifier performance and allows you to safely use up to4 speaker pairs simultaneously without overloading or damaging your amplifier. The Monster Cable Speaker Selector features high quality materials for maximum reliability and durability Non - inductive 50 watt resistors with aluminum finned heat sinks are specially designed to deliver peak power from even mega-powerful amplifiers - up to 150 watts per channel . These precision - crafted resistors improve frequency response so you'll enjoy fuller more three dimensional music reproduction. And all the connections to the circuit board are completely wired with high performance Monster Cable for the best possible sound. Get All The Performance You Paid For With Monster Cable Speaker Selector you will be able to enjoy music anywhere in the house while protecting your amplifier from damage and maximizing the performance of your entire music system. Product Features High Current Amplifier Protection Circuitry: Maximizes high power amplifier performance and allows safe use of up to four speaker pairs simultaneously without amplifier damage Large Push-Button Speaker Selectors: Allows you to select one speaker pair or up to four pairs of speakers simultaneously - anywhere in the house Internally Wired with Monster Cable: For smoother more natural sound with improved clarity and dynamics PC Board with Extra-Wide Traces: Extra-heavy copper on printed circuit board for maximum conductivity signal transfer and durability Ultra-High Conductivity Silver Contact Switches with Paralleled Contacts: Provides superior corrosion resistance for maximum durability and reliability 24k Gold Contact Spring-Loaded Connectors: Delivers maximum signal transfer and provides quick easy speaker cable hookup - up to 14 gauge non-terminated speaker wire and any gauge speaker cable terminated with Monster Angled Gold Pin connectors Low-Loss Resistors with Aluminum Finned Heat Sinks: Delivers maximum power from power hungry amplifiers - up to 150 watts per Easy-to-use Push Button Speaker Selectors: Instantly enjoy music in any room or multiple rooms of your home by selecting up to four pairs of speakers simultaneously
Specification Description
Model SS-4, SS4, ss-4;1pc 4-way speaker
UPC 050644260360
Accessory Indicator Yes
Benefits High-current amplifier protection circuitry allows you to use up to 4 speaker pairs without damageAccepts any gauge speaker cable ter
Capacity UOM mAh
Country Of Origin China
Description Header Protection, performance and convenience.
Display Catalog Number 55013157
Features High-current resistors with aluminum finned heat sinks deliver up to 150W per channelPrecision-crafted resistors improve frequency re
Manufacturer Labor Warranty 1
Manufacturer Part Number SS-4
Manufacturer Parts Warranty 1
MAP Price 99.95
Model SS-4
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Disclaimer Warranty is limited lifetime.
Product Type Selectors
Product Weight UOM pounds
Supported Languages English
Monster Cable® SS-4 Multispeaker Selector Questions
Questions and Answers
Where to Buy
$41.75
$99.99
Code KMART5OFF50 : Save $5 off $50 with coupon ends 12/31/09
$89.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Jun 14, 2009
Monster Cable® SS-4 Multispeaker Selector Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
Good Switch at Reasonable Price
4.0
    Pros
  • Clean Sound
  • Easy To Set Up
  • Price
  • Quality Build
    Cons
  • No Volume Controls
    Best Uses
  • Basic Systems
  • Home Theater
  • Multiple Zones
"Monster SS-4 4-Zone Speaker Selector Switch--being used to connect a home 5.1 system to two additional pairs of speakers; one pair on a back deck, and another on a front porch. Neither listening environment is "audiophile quality", but the sound from a Yamaha RX-V563 through this unit into some TIC …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Monster Cable® SS-4 Multispeaker Selector helpful to you?
Aug 30 2008
XEagleDriver
Columbia SC
I am:
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Does what it says it does
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • Gets really hot
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Larger Rooms
  • More »
"Purchased hoping to protect new Receiver from impedence inbalance caused by having three pair of 8 ohm speakers connected. Box gets really hot. Emailed Monster Cable but have not heard back from them. "
Jul 2 2008
Dave the Georgia drummer
Atlanta
I am:
  • Audiophile
  • Musically Inclined
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
perfect and gives you a crazy workout
5.0
    Pros
  • Accurate Controls
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • Limited Functions
    Best Uses
  • None
"at first I didn't want to spend the $$ on these, but once I got i, it was worth it and much better than the cheaper ones "
Jun 14 2009
workout chic
NJ
Reviewed at:
Price: $41.75
Great product. Exactly ...
5.0
"Great product. Exactly what I was dreaming of. I now can hook up my surround sound and outdoor speakers and basement speakers with any easy push button switch to turn each on or off. Fabulous! Great price.[...] "
Sep 1 2004
robert m
Undisclosed
Reviewed at:
"Monster Cables are the ...
5.0
"Monster Cables are the best for your Sound and TV Components. Don't go cheap when it comes to sound!!!!
Renee
Kingsville, Md "
Jan 31 2006
Renee K
Undisclosed
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
