Monster Cable PowerProtect MP AV 600 6 Outlets Surge Suppressor
4.8
based on 17 reviews
Ratings Distribution
5 star
12
4 star
4
3 star
0
2 star
0
1 star
0
Category Average
4.3
$11.73 - $39.00
from 16 stores
More Images
Pros
  • Durable (6)
  • Compact size (4)
  • Good cord length (4)
  • Great protection (4)
  • Warranty (4)
  • High quality (1)
  • The color scheme (1)
  • Well labeled (1)
See less See more
Cons
  • Pricey (1)
Best Uses
  • High-end equipment (4)
  • Tv's (4)
  • Audio equipment (3)
  • Computers (1)
  • Home (1)
  • Home use (1)
  • Lcd tv (1)
  • Office (1)
Provided by MAGo Enterprise
MODEL- MC109300 VENDOR- MONSTER LLC FEATURES- PowerProtect AV 600 with Surge Protection Color-coded labeled outlets and matching cord labels for easy hookup. 8 foot Monster AC power cable with FlatProfile right angle plug provides flexibility for installations. Maximum conductivity 24k gold contact grounded right angle plug lets furniture hug walls. 555 Joule rating provides higher level of surge absorption. $10 000 Monster guaranteed connected equipment protection and a 5 year product warranty. Slim design for easy placement in tight areas. * Lightning automatic garage doors power tools refrigerators andfluorescent lights all cause power surges and voltage spikes that cantravel up AC power lines to damage the sensitive electronic cicuitry ofyour connected AV components. Ordinary surge protectors or the so-calledvalue brands often fail to provide the adequate level of protectionyour AV components need. * Harmful power surges and voltage spikes can permanently damage thesensitive electronic circuitry of today's sophisticated audio videocomponents. Proper connection to an advanced surge protector that offersintegrated system protection can help minimize the risk of permanentsurge damage. * Unlike standard surge protectors the Audio Video PowerProtect AV600 withMultiple SurgeGuard protection provides multiple layers of defenseagainst harmful surges. Strategically-placed multiple Metal OxideVaristors respond within one nanosecond (a billionth of a second) topower surges and voltage spikes before they can reach and damage your AVcomponents. * Monster's FlatProfile plug lets you push your furniture flush against thewall. And with color-coded outlets and cord labels you can avoidunplugging your VCR by mistake causing it to blink 12:00. Finally agenerous eight foot Monster power cord which is the optimum length toreach most electrical outlets - is included. * Now you can get protection from harmful surges voltage spikes andinconvenience! Monster's PowerCenters offer high performance solutionsfor today's technology challenges.-- SPECIFICATIONs ------------------------------------ CONNECTORS - (6) AC Outlets JOULE RATING - 555 SIZE - 2w x 1.75h x 10.5d WT.- 1 lbs.
Specification Description
Model 109300, 109300-, MON109300, MP AV 600
UPC 050644214257
Accessory Indicator Yes
Benefits Color--coded, labeled outlets and matching cord labels for easy hookup8-ft. Monster AC power cable with FlatProfile™ right-angle
Body Material Multi
Cables Included 1 x power cable - 8 ft
Capacity UOM mAh
Country Of Origin China
Description Header Absorbs harmful power surges.
Display Catalog Number 55001896
Enclosure Color Multi
Features $10,000 Monster guaranteed connected equipment protection and a 5 year product warrantySlim design for easy placement in tight areas<
Manufacturer Labor Warranty 5
Manufacturer Part Number 109300
Manufacturer Parts Warranty 5
MAP Price 0.0
Model 109300
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 1.7
Product Length 10.5
Product Type 501-1000 Joules
Product Weight 1.1
Product Weight UOM pounds
Product Width 2
Supported Languages English
Monster Cable PowerProtect MP AV 600 6 Outlets Surge Suppressor Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 26, 2009
Monster Cable PowerProtect MP AV 600 6 Outlets Surge Suppressor Reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
...And it's color coded.
4.0
    Pros
  • The color scheme
    Cons
  • NONE
    Best Uses
  • Home use
"OK, how does one review a power cord? Let's face it the proof is in the pudding, and in my situation I experience blackouts and brownouts every year, and the only way I'll have proof this device works is when those events occur.
Have I had a power cord fail? Yes I have, and Monsters $10,000 insuran …"  Read Full Review »
Was this Surge Protector review on the Monster Cable PowerProtect MP AV 600 6 Outlets Surge Suppressor helpful to you?
 Report Abuse  (1)  (0)  0 comments
Apr 5 2009
DPC_Guy
NY, NY
I am:
  • Experienced
Reviewed at:
Price: $16.99
I would buy this product again!
5.0
    Pros
  • Compact Size
  • Good Warranty
  • Great Protection
    Cons
  • None
    Best Uses
  • Audio Equipment
  • High-End Equipment
  • TV's
"The AV-600 Power strip and surge protector is a great choice at an excelent price. I'm using it with a presentation equipment and it works very well. I recomend it for persons who needs to be traveling for its compact size and talking about the back up of protection by the manufacturer it is extra …"  Read Full Review »
Feb 15 2009
Ray Acevedo
Lajas, Puerto Rico
I am:
  • Professional
  • Tech Savvy
  • Technically Challenged
Reviewed at:
Price: $14.99
Great Product
5.0
    Pros
  • Durable Construction
  • Good Cord Length
  • Good Warranty
  • Great Protection
  • Well Labeled
    Cons
  • None
    Best Uses
"I use the Monster surge protector for my Proform Treadmill. I always use Monster products to not only to protect my high-end tech toys (plasma tvs, ps3, laptop, blue-ray player...etc) but also for great quality in performance. I would recommand this Monster product to everyone. "
Sep 10 2009
Sue
Upstate, NY
I am:
  • Tech Savvy
Reviewed at:
Price: $19.99
Less for surge protection than Color organization.
4.0
"Living in the lighting capital of N. America, I don't see this as a protection as much as an organizer. I use an office TV with about 5 different products every day before the storms. I color coordinate the color swatch on the cord with the color on the Monster Cable and quickly hook up the product …"  Read Full Review »
Jul 30 2009
PJCC
Florida
Reviewed at:
Price: $19.95
Definitely would Recommend
5.0
    Pros
  • Compact Size
  • Good Cord Length
  • Good Warranty
  • Great Protection
    Cons
  • None
    Best Uses
  • Audio Equipment
  • Computers
  • TV's
"Size is compact, labeling is easy to see what plug you want to unplug or plug in. Easy to use and take us little space. "
Jun 2 2009
Ann Margaret
Monmouth Co., NJ
I am:
  • Tech Savvy
Reviewed at:
Price: $16.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
