Monster Cable 6-Zone Speaker Selector
#89
4.7
based on 6 reviews
Ratings Distribution
5 star
4
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.3
Low Price:
$129.99 at Amazon
$129.99 at Kmart
Find it at Amazon
$129.99 - $179.30
from 3 stores
More Images
Provided by MAGo Enterprise
Internally Wired with Monster Cable for the Best Possible Sound Product Information An Ordinary Speaker Selector Can Degrade Amplifier Performance Many people demand the flexibility and convenience of using multiple speakers throughout the house - even outdoors. If you hook up more than one speaker pair to your amplifier however the impedance (ohms) may drop to a dangerously low level stressing your amp beyond its limits causing circuitry damage or shutdown. You may avoid this potential nightmare by connecting your speakers to a multiple speaker selector. However ordinary speaker selectors can also degrade system performance. Although they use a resistor in series to protect your amp from low impedance loads these ordinary inductive resistors can cause noticeable high frequency loss so you hear less detailed music reproduction. The power rating is often low potentially damaging your speaker selector if you're using a high current amplifier. Monster Delivers an Unbeatable Combination of Performance Convenience and Amplifier Protection With the Monster Cable Speaker Selector you can enjoy the convenience and flexibility of listening up to six speaker pairs at a time in any location. With Monster's advanced Amplifier Protection circuitry you will have the comfort of knowing your amplifier is delivering maximum power and performance. When engaged this impedance matched circuitry maximizes high power amplifier performance and allows you to safely use up to six speaker pairs simultaneously without overloading or damaging your amplifier. The Monster Cable Speaker Selector features high quality materials for maximum reliability and durability Non - inductive 50 watt resistors with aluminum finned heat sinks are specially designed to deliver peak power from even mega-powerful amplifiers - up to 150 watts per channel . These precision - crafted resistors improve frequency response so you'll enjoy fuller more three dimensional music reproduction. And all the connections to the circuit board are completely wired with high performance Monster Cable for the best possible sound. Get All The Performance You Paid For With Monster Cable Speaker Selector you will be able to enjoy music anywhere in the house while protecting your amplifier from damage and maximizing the performance of your entire music system. Product Features High Current Amplifier Protection Circuitry: Maximizes high power amplifier performance and allows safe use of up to four speaker pairs simultaneously without amplifier damage Large Push-Button Speaker Selectors: Allows you to select one speaker pair or up to four pairs of speakers simultaneously - anywhere in the house Internally Wired with Monster Cable: For smoother more natural sound with improved clarity and dynamics PC Board with Extra-Wide Traces: Extra-heavy copper on printed circuit board for maximum conductivity signal transfer and durability Ultra-High Conductivity Silver Contact Switches with Paralleled Contacts: Provides superior corrosion resistance for maximum durability and reliability 24k Gold Contact Spring-Loaded Connectors: Delivers maximum signal transfer and provides quick easy speaker cable hookup - up to 14 gauge non-terminated speaker wire and any gauge speaker cable terminated with Monster Angled Gold Pin connectors Low-Loss Resistors with Aluminum Finned Heat Sinks: Delivers maximum power from power hungry amplifiers - up to 150 watts per Easy-to-use Push Button Speaker Selectors: Instantly enjoy music in any room or multiple rooms of your home by selecting up to four pairs of speakers simultaneously
Monster Cable 6-Zone Speaker Selector Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 10, 2009
Monster Cable 6-Zone Speaker Selector Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
[11 of 11 customers found this review helpful]
speaker selector does the job
4.0
"I'm highly pleased with the utility of the monster speaker selector. Connections are easy, logical, and the sound does not appear degraded at all. Make sure you always have the protection button engaged. Without it, my amp shut down.
The SS6 is a good way to run speakers to other rooms and outdoors "
Was this Amplifier, Receiver & Equalizer review on the Monster Cable 6-Zone Speaker Selector helpful to you?
 Report Abuse  (11)  (0)  0 comments
Aug 24 2006
Kerry Doyle
SW Illinois
Reviewed at:
Price: $129.99
[5 of 5 customers found this review helpful]
Nice speaker selector!
4.0
"This six pair speaker selector switch replaced a piece of junk I had unfortunately purchased from Radio Shack. The old switch had bleed-through to non-selected speakers, which sort of defeats the purpose.
The monster switch works as it should - sound only from selected speakers. It also looks nic …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Jul 26 2008
D. McCann
Marshall, Tx USA
Reviewed at:
Price: $129.99
[4 of 5 customers found this review helpful]
Great Product!
5.0
"The Monster Cable SS-6 Speaker is a great product, at first I thought it would help me to connect my 3 additional speakers, but to my surprise it was able to connect 12 speakers! (6 sets of two/audio-area), this is something great for the price it costs. "
 Report Abuse  (4)  (1)  0 comments
Mar 24 2008
Roberto Canseco
Jacksonville, FL
Reviewed at:
Price: $129.99
[1 of 1 customers found this review helpful]
Does Exactly What is Promised
5.0
"I have limited budget for audio and I wanted to run speakers to a porch, two sets to a patio and another set in my kitchen. I connected this device to the "B" speakers on my Yamaha reciever. I thought I'd give this thing a try, but I was pretty skeptical because I have a variety of speakers and they …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jun 4 2009
Mick M
Brookfield, WI
Reviewed at:
Price: $129.99
Not a review, a question
5.0
"Would someone be able to answer a question for me...i have 4 sets of speakers in various rooms in my house, installed in the ceiling. Would I be able to hook this switcher up to a receiver in order to get my speakers working? "
Jun 10 2009
J. Ruffatto
Amazon
Reviewed at:
Price: $129.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
