Monster Cable 125087 iStudioLink Instrument Cable
#30
5.0
based on 2 reviews
from $25.56 - $49.00
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
3.8
More Images
Pros
  • Durable (2)
  • Easy setup (2)
See less See more
Cons
  • Pricey (1)
Best Uses
  • Home (2)
  • Office (1)
  • Travel (1)
Provided by MAGo Enterprise
MODEL- MC125087 VENDOR- MONSTER CABLE FEATURES- iStudioLink Instrument Cable12 ft. Cable (1/4 to 1/8 stereo mini plug).Extra-long (12 foot) high-quality instrument cable provides a direct connection between your instrument (with 1/4 output) to your Mac (with audio input). Features patented Monster audio technologies to enhance your gears sound.Extra-long iStudioLink Instrument Cable gives you a fast flexible connection from your instrument to your Apple. With the release of powerful easy-to-use software like Garage Band and Logic Express Apple has helped bring digital recording to the masses. Now Monster gives you the same great sound and convenience from your gear-to- Apple connection with iStudioLink Instrument Cable. Just plug one end into your instruments 1/4 audio-out jack and the other into your computers 1/8 input and you are ready to rock. The extra- long 12 foot length provides plenty of slack for flexible movement setup options and comfort while recording.iStudioLink Instrument Cable features the same high-quality design and construction the pros use to help enhance the warmth and detail of their favorite instruments--Monster Cable. All Famous Monsters (MonsterCable.com/Famous) use Monster Cable because they know that cable is essential in getting the most accurate reproduction of their instruments signature sound. So if you want to capture the true tonal quality of your Strat or the fullest range of your synths sound use what the biggest names in music use: Monster Cable.You have got the right gear. Now get the right cable to bring out its best. There is no need to use multiple connections that might cause insertion loss or buy an expensive USB input device to record to your Apple. Now you can use one direct high quality connection that makes digital recording simple while enhancing your gears sound: 12 foot long Monster iStudio Link Instrument Cable. * 24k Gold Contact ConnectorsFor maximum signal transfer and corrosion resistance. * Time Correct WindingsPatented multiple-gauge wire networks for more natural accurate sound. * Patented MicroFiber DielectricFor superior noise rejection. * Dual Solid Core Center ConductorProvides extended low-frequency response. * Color-Coded RingsFor easy ID on both ends. * Duraflex Protective JacketProtects cable from weather abrasion and chemicals.
Specification Description
Model 125087, 125087-, AI GBINST-12, AIGBINST12
UPC 050644397622
Benefits Duraflex® protective jacket protects cable from weather, abrasion and chemicals24k gold contact connectors provide maximum signal
Cable Length 12 ft
Cable Technology Double shielded
Cable Type Phone
Capacity UOM mAh
Color White
Country Of Origin China
Description Header Plug in. Rock Out. With Monster.
Display Catalog Number 55030268
Enclosure Color White
End Product Indicator Yes
Left Connector(s) 1/8"
Manufacturer Labor Warranty 1
Manufacturer Part Number AI GBINST-12
Manufacturer Parts Warranty 1
MAP Price 0.0
Model AI GBINST-12
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Length 144
Product Type Audio Cable
Right Connector(s) 1/4"
Supported Languages English
Technology Features MicroFiber dielectric, MultiTwist construction
Monster Cable 125087 iStudioLink Instrument Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 29, 2009
Monster Cable 125087 iStudioLink Instrument Cable Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Just what I needed!
5.0
    Pros
  • Durable
  • Easy Setup
    Cons
  • Expensive
    Best Uses
  • Home
  • Office
  • Travel
"I have many other Monster cables for my guitar gear, so have no problems buying Monster brand. They are a little pricey, but always seem to be worth it. So far, I've used this cable to run out of my laptop into a sound system, to run loops for music in live performances. Works exactly as it should! "
Was this MP3 Player / iPod Cable & Adapter review on the Monster Cable 125087 iStudioLink Instrument Cable helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jun 29 2009
Jinx
Texas
I am:
  • Audiophile
  • Frequent Traveler
  • Gear Head
Perfect for a guitar and a Mac
5.0
    Pros
  • Durable
  • Easy Setup
    Cons
  • None
    Best Uses
  • Home
"Excellent product. Perfect for plugging in your instrument to a Mac. "
May 27 2008
D
San Mateo, CA
I am:
  • Audiophile
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
