Monster AVL300S Home Theater And Lighting Remote Control
#100
3.0
based on 6 reviews
Ratings Distribution
5 star
0
4 star
3
3 star
1
2 star
1
1 star
1
Category Average
4.2
$399.95 at Your Electronic Warehouse
Find it at Amazon
Find it at Ebay
$399.95
from 1 store
More Images
Pros
  • Easy to use (2)
  • Ergonomic design (2)
  • Nice button configuration (2)
  • Nice features (2)
  • Controls multiple devices (1)
  • Eliminates remote clutter (1)
  • Rechargable battery (1)
See less See more
Cons
  • Component switch slow (1)
  • Don't stand behind prod (1)
  • Joystick (1)
  • Not durable (1)
  • Only controls ir devices (1)
  • Setup (1)
  • Takes time to set up (1)
Best Uses
  • Home (2)
  • High-end equipment (1)
  • Multi-room (1)
  • Replacement (1)
  • Upgrade (1)
Provided by Beach Audio
The Monster Cable Home Theater AVL300S is a reference multi-room controller (what we used to call a remote control) that works through walls, ceilings, and floors, thanks to its built-in RF wireless technology. You get whole-house control, even for multi-zone systems. The AVL300 is also a powerful lighting controller. Using Monster's IlluminEssence lighting modules (not included) and Z-Wave technology, the AVL300 can create customized lighting "scenes" throughout your home to accompany chosen activities, such as "Romantic Dinner," with dimmed lights and soft music!
Replace all your existing audio/video and lighting remote controls with the easy-to-use Monster AVL300 controller. Use only a single remote, plus add more functionality with special feature buttons. A unique ergonomic design provides larger tactile buttons with an intuitive layout. In the dark, the illuminated backlit buttons are easy to read. Unlike other remotes, the AVL300's component and lifestyle Activity Buttons send multiple commands to multiple devices automatically, allowing true one-touch control. And no complex programming is required. You can easily configure home theater activities and lighting scenes to create lifestyle activities via your computer and the online Set-Up Wizard. This controller remembers, so you don't have to. Intelligent Monster Tracking Memory remembers what each component is doing, so when you switch activities, your equipment responds accurately.
With the AVL300, you get special function buttons no other single remote has. The Lighting Control button give you one-touch instant access to Monster Central Home Lighting System functions. The Sys A/B button allows you to control multiple systems for multiple rooms. Quickly scroll through satellite and digital cable program guides with Page Up and Page Down buttons. Access directly important picture controls like aspect ratio and P-I-P with the Picture button. And with the Surround Mode button, you can select from among different surround sound modes while you listen.
Monster Controlnet Technology allows you the freedom to move around the house and never aim your remote again. The included Monster Omnilink, an RF-to-IR bridge and IR blaster system, extends the controller's operating range up to 130 feet through walls, ceilings, and floors; while the supplied Control Link Extender Set expands your control with TV and dual-component IR emitters. All this wireless control technology may seem complicated, but Monster's Internet-based Set-Up Wizard makes it fast and easy to get going. An online remote configurator walks you through your remote set-up by simply asking you what home theater equipment you have and how it's connected. Easy lighting setup for a single room or the whole house allows you to create lifestyle activities that integrate lighting and home theater. There's even exclusive easy-to-understand online technical assistance and advice at Monster Central Control, plus important software downloads and updates. And, if you ever need help hooking up a system, make the best connections by downloading the Monster Connection Guides for everything from PVR to iPod hook-ups.
Included With Purchase
Monster Central Omnilink (RF-to-IR bridge/IR blaster), lithium-ion rechargeable battery, tabletop charging station, and Control Link Extender Set (IR emitters).
Specification Description
Model 121149, MCC AVL300-S, MCC-AVL300-S, MCCAVL300S
UPC 050644312588
Battery Type Product
Benefits Omnilink™ enables the AVL300 to work through walls, cabinets, and throughout the houseEasy setup with no complex programming or
Cables Included USB cable
Capacity UOM mAh
Chemistry Lithium Ion
Country Of Origin China
Description Header Control it all.
Display Catalog Number 55028967
Enclosure Color Black/Silver
End Product Indicator Yes
Included in the Box AVL 300 Home Theater and Lighting ControllerMonster Central OmniLinkTabletop charging stationRechargeable lithium i
Inputs 1 x USB(USB)
Manufacturer Labor Warranty 12
Manufacturer Part Number MCC AVL300-S
Manufacturer Parts Warranty 12
MAP Price 399.95
Model MCC AVL300-S
Operating Temperature UOM ° F
Outputs 1 x USB(USB)
Power Device Rechargeable lithium ion battery
Product Depth 8.5
Product Dimensions UOM inches
Product Height 1.325
Product Type Pushbutton remotes
Product Width 2.5
Rechargeable Yes
Required to function PC: Microsoft Windows 98SE, 2000, Me, or XP with USB port, CD-Rom drive, and internet accessMacintosh: Macintosh OS X 10.2 or later
Size Pack
Supported Languages English
Technology IR
Monster AVL300S Home Theater And Lighting Remote Control Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 22, 2009
Monster AVL300S Home Theater And Lighting Remote Control Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
Nice central command control
4.0
    Pros
  • Easy To Use
    Cons
    Best Uses
  • Home
"Nice product! It helps control all AV components and eliminates need for multiple remotes and requests from family members to "fix the TV". The activity controls are great. For example the "Watch TV" button turns on my TV, AV Receiver and Cable Box. Everybody likes that feature. On the con side …"  Read Full Review »
Was this Remote Control review on the Monster AVL300S Home Theater And Lighting Remote Control helpful to you?
Feb 2 2007
Phil
Houston, TX
Reviewed at:
Price: $399.95
Strong talk, but a weak back
2.0
    Pros
  • Ergonomic Design
  • Nice Button Configuration
  • Nice Features
    Cons
  • Breaks easily
    Best Uses
  • High-End Equipment
"I bought this control in May 08 and had it installed by a professional.The components reacted slowly to signals or sometimes not at all. Controller had trouble swithching form one component to another. My fault but I dropped the controller 12 inched to the floor and the LCD screen was shot. The ent …"  Read Full Review »
Jan 22 2009
Dr. D
Lexington, Ky
I am:
  • Tech Savvy
Reviewed at:
[0 of 1 customers found this review helpful]
Very Nice Remote
4.0
    Pros
  • Ergonomic Design
  • Nice Features
    Cons
  • Joystick
    Best Uses
  • Replacement
"It was slightly challenging to set up, but a 5min. call to tech. help got me operational. Now I think its fairly easy to update. I like the button selection (prior remote was a touch screen), now I can feel for proper button and use one hand. I wish it had separate buttons instead of a joystick, …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Apr 10 2008
dug
Atlanta, GA
I am:
  • Gearhead
Reviewed at:
would not sync with light controllers
1.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Upgrade
"I spent more than 5 hours trying to get the remote to sync with the lighting attachments without success. Customer service couldn't help. The instructions that came with the software conflicted with the instructions that came with the lighting switch. Software does not allow you to go back to chec …"  Read Full Review »
Jan 1 2009
M. Smith
Texas
I am:
  • Tech Savvy
Reviewed at:
A VERY Powerful Remote
4.0
    Pros
  • Easy To Use
  • Rechargable Battery
    Cons
  • Only controls IR Devices
  • Setup
    Best Uses
  • Home
  • Multi-Room
"This product is amazing how it can control multiple devices with one button. It will control all my electronics, lights and even my iRobot Roomba Vacuum! The setup process can be simplified a little bit more, but overall a very nice remote. "
Nov 30 2006
RemoteGuy
IL
Reviewed at:
Price: $399.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
