Monster 19.7-Ft. ® HDMI400 Audio/Video HDMI Cable
#27
4.9
based on 11 reviews
from $29.00 - $85.77
Ratings Distribution
5 star
10
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Pros
  • Good length (6)
  • Rugged (6)
  • Consistent performance (5)
  • Versatile (3)
See less See more
Best Uses
  • High-end equipment (6)
Provided by MAGo Enterprise
High Resolution HDMI Interface for the Best Possible HDTV Picture Product Information The Ultimate Audio/Video Interface Has Finally Arrived in One Digital Connection Monster HDMI (High Definition Multimedia Interface) 400 is a remarkable new high-bandwidth digital connection that offers superior digital video and multi-channel audio in a single cable reducing the maze of home theater connections. Its simple user-friendly connection is backwards-compatible with DVI and it delivers a high-definition picture thats five times the resolution of conventional TV for the highest quality crispest image quality available. Now you can connect HDMI-equipped devices such as DVD players set-top boxes AV receivers and HDTVs with a cable that helps optimize this next-generation technology: Monster HDMI 400. Advanced Design and Construction for the Best Possible Sound and Picture Monster HDMI 400s advanced design and construction exceeds HDMI standards to transfer digital AV signals with optimal power accuracy and clarity. 24k gold contacts resist corrosion to provide optimum signal transfer. Triple-layer shielding rejects interference for the clearest picture possible. And Monsters gas-injected cellular dielectric helps facilitate high velocity transfer and maximum signal strength even over long lengths. Maximize Your Connection with the Ultimate HDMI Cable: Monster HDMI 400 Youve invested in HDMI technology so you could get superior picture and sound from your home theater. Now you can maximize the performance of this extraordinary digital interface by making the connection with the highest quality cable. For the ultimate high-definition audio and video HDMI experience get Monster HDMI 400. Product Features 20 ft. HDMI Audio/Video Cable 24kGold Contacts for optimal signal transfer and corrosion resistance Heavy Duty Outer Mesh Jacket that protects against abrasion and controls sharp bends and kinks to prevent damage to cable's delicate conductor. Double-Sided Aluminum Bonded Foil Shield and Ultra High Copper Braid rejects radio frequency and electromagnetic interference for the clearest HDTV picture possible Duraflex Protective Jacket is flexible for easy routing and installation. Resistant to temperature extremes. Large Gauge Copper Conductors - 50% more copper for reduced resistance and better signal transfer High-definition digital video and multi-channel audio in one cable For high-definition video (720p and 1080i) or standard video formats Supports multiple audio formats from stereo to multi-channel surround Delivers optimum signal transfer Transmits full bandwidth digital AV signal between HDMI capable tuners digital satellite or AV receivers DVD players/recorders and high definition displays Gas-injected dielectric for maximum signal strength and ultra-loss even over longer runs High-density triple shielding for maximum rejection of RF and EM interference Minimum Requirements In order to enjoy HDMI both your source and display must feature an HDMI connection.
Specification Description
Model 123131, 123131-, 123131-00, 130568
UPC 050644365270
Accessory Indicator Yes
Benefits Compatible with most audio systemsGas-injected dielectric for optimum signal strength and ultra-low lossExcellent shielding
Benefits Supports multiple audio formats, from stereo to multichannel soundGas-injected dielectric for optimum signal strength and ultra-low l
Body Material Multi
Cable Length 19.68 ft
Cable Length 3.3 ft
Cable Technology Triple shielded
Cable Type HDMI cable
Cables Included Monster® HDMI400 Super-High-Performance Audio/Video Cable
Capacity UOM mAh
Color Black/Gold
Country Of Origin China
Description Header Connect with the best.
Display Catalog Number 15-2413
Display Catalog Number 15-2416
Enclosure Color 2-Color
Enclosure Color Black
Features Multiple audio format capableHigh-density triple-shielding19.7-ft. length (6m)
Included in the Box Monster® HDMI400 Super-High-Performance Audio/Video Cable (1)
Interface Supported HDMI connection
Interface Supported Video
Left Connector(s) 1 x 19 pin HDMI Type A - male
Left Connector(s) 19 pin HDMI Type A - male
Manufacturer Labor Warranty 1
Manufacturer Parts Warranty 1
MAP Price 0.0
Model HDMI400-1M
Model HDMI400-6M
Operating Temperature UOM ° F
Product Dimensions UOM feet
Product Length 19.7
Product Length 3.3
Product Type Audio/Video Cable
Product Type HDMI cable
Right Connector(s) 1 x 19 pin HDMI Type A - male
Right Connector(s) 19 pin HDMI Type A - male
Supported Languages English
Technology Features Gas injected dielectric
Monster 19.7-Ft. ® HDMI400 Audio/Video HDMI Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 4, 2009
Monster 19.7-Ft. ® HDMI400 Audio/Video HDMI Cable Reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
Nice Cable even over the length
5.0
    Pros
  • Good Length
  • Rugged
    Cons
  • None
    Best Uses
  • High-End Equipment
"Used the cable for an in-wall install from my receiver to a 50 inch plasma. Cable was rugged enough to support being pulled through the walls and the quality with the length is great. Much improved picture over lesser cables. "
Was this Audio Visual Cable & Connector review on the Monster 19.7-Ft. ® HDMI400 Audio/Video HDMI Cable helpful to you?
Nov 13 2007
Audiophile
Denver, CO
I am:
  • Tech Savvy
Reviewed at:
top notch merchandise
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
"top of the line for the money. would buy it again and recomend it to everyone. extremely happy. [...] exactly as advertised with a very competive price "
Jan 9 2009
Johnny cat
Fresno Ca.
I am:
  • Enthusiast
Reviewed at:
Wow, these are Amazing!
5.0
"* Transfers HD video and audio signals
For brilliant movies, TV shows and sporting events. Compatible with most HDTVs, Blu-ray Disc players, set-top boxes and more with HDMI connectivity.
* Delivers a 13.8 Gbps bandwidth
For maximum performance.
* THX certified
Delivers 12-bit Deep Color and support …"  Read Full Review »
Jul 4 2009
PvtDavis
Likely Britain
Reviewed at:
[1 of 2 customers found this review helpful]
HDMI Cables
4.0
"The cables were high quality, competitively priced, and delivered on time. I was a first time buyer from your site and somehow ordered return protection by mistake. This appeared to have been a default selection that excaped my attention. This should not be a default component of any order. It shoul …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Oct 27 2006
Mark Horton
Phoenix
Reviewed at:
Price: $29.00
I hooked up the HDMI ...
5.0
"I hooked up the HDMI cable to my DVD and the picture is much clearer than when it was hooked up through the component video. The Monster cable was very well constructed with a protective covering on the whole cable. "
Mar 16 2006
Jimmy H
Undisclosed
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
