Monster 1000HD Ultra-High Speed HDMI Cable
#1
4.9
based on 26 reviews
Ratings Distribution
5 star
24
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.1
$64.78 - $99.99
from 10 stores
More Images
Pros
  • Consistent performance (14)
  • Good length (9)
  • Durable (6)
  • Rugged (6)
  • Improves performance (5)
  • Versatile (5)
  • Highly compatible (4)
  • Reliable (4)
  • Strong connection points (4)
  • Do make a difference (1)
See less See more
Cons
  • Heavy / bulky (1)
  • Meters rather than inches (1)
Best Uses
  • High-end equipment (23)
  • Dorm room (2)
  • 1080p plasma (1)
  • Home entertainment system (1)
  • Plasma tv-hd converter bo (1)
  • Travel (1)
Provided by ClubMac
HDMI 1000HD Ultra-High Speed HDMI Cable (1 meter) - 127654 Monster Ultra-High Speed 1000HD ensures everything you like to watch in high definition has maximum realism, maximum impact. Movies are just like the director intended. Monster HDMI 1000hd Ultra-High Speed HDMI CableGuarantees a certified cable bandwidth of 10.2 Gbps* and greater, and will support not only the truest 1080p, but advanced source and display technologies such as 120 Hz refresh rates, x.v.Color, and Dolby TrueHD and DTS-HD. If you want a cable that's truly future-proof against advancing HD technologies, the 1000hd is what's right for you.HDMI places incredible performance demands on your digital A/V connections. It requires a truly high-bandwidth cable that can deliver enormous amounts of digital data without bit-error and signal degradation. Monster has created the Advanced HDMI 1000HD Ultra-High Speed Cable for those who demand the best in high definition home theater--both now and in the future. This cable is ideal for larger HDTVs, advanced projectors, and high definition AV sources. Monster designs the most advanced HDMI cables and certifies their performance for future generations of products. If the performance capabilities of this cable are ever exceeded by future generations of HDMI, Monster will replace this cable at no charge--see product packaging for further details. Monster Ultra-High Speed 1000HD ensures everything you like to watch in high definition has maximum realism, maximum impact. Movies are just like the director intended. Sports and live shows are just like you're there. Games are just what you expect—larger than life. With a certified bandwidth of greater than 10.2 Gbps*, no high definition experience is too demanding. 1000HD is your connection to the best in HD picture and sound, now and in the future. HDMI engenders more confusion than any other connector type with many different cable and component standards, interoperability problems, and false information about the quality and performance of HDMI cables. Moreover, many electronics and cables do not perform to the standard, so many combinations of cables and components don't work. Additionally, cable performance, especially over long runs, have degraded picture quality. Why Pay More for an HDMI Cable?A common misconception is that all HDMI cables are the same--so why not just buy the cheapest cables you can find? The truth is that there are many levels of High-Definition digital video, and there are different levels of HDMI cables to connect them. High-Definition (720p/1080i) as we know it today is delivered at a 2.2 Gbps (giga-bits per second) throughput rate. Although high compared to standard DVD at .81 Gbps, it won't achieve the best performance from High-Definition in the near future, which will require 10.2 Gbps and more. Previous generation HDMI cables developed to meet the original 2.2 Gbps standard are not certified for the new standard and may not pass the full bandwidth required to provide the best performance from these new products.Unlike computer data, which is tolerant of data transmission losses, video data is not. Accurate transmission is essential. Most HDMI-compliant cables can transfer older versions of High-Definition (720p/1080i) data rate over short lengths, but have problems maintaining the same performance over longer lengths as well as higher data rates required of 1080p. HDMI cables are very sensitive to construction variances. With HDMI's super-high data rate and microscopically tight tolerances, even mishandling the cables during an install can significantly affect performance. Look for better shielded connectors, mesh jackets for durability, special winding techniques, nitrogen gas dielectrics to minimize loss, and CL 3 jacket ratings to ensure maximum performance with every installation. So What Makes Monster HDMI Different?Monster commits to providing the widest range of HDMI cables at various price points, from entry level standard speed cables, to ultra-high-speed cables for the most advanced video home theaters, some of which are yet to come. Monster has been a leader in HDMI connectivity from the beginning, working with HDMI co-inventor Silicon Image to educate consumers on the benefits and performance aspects of the cables. Advanced HDMI performance is guaranteed, thanks to greater cable capacity for support of 12-bit color, also called Deep Color, available from advanced HD sources and displays. Greater color depth, from 8-bit to 12-bit, allows more detailed gradations of individual colors for the display of billions of colors. Additional cable bandwidth supports the xvYCC color space, also called x.v.Color, available from new advanced HD sources and displays. x.v.Color widens the number of available colors for 40 percent more colors than standard RGB. Bandwidth for Dolby TrueHD and DTS-HD gives you lossless surround sound, available on Blu-ray Disc™ and HD DVD™ movies. Also, Monster HDMI supports advanced HD components with 120 Hz frame/refresh rates, providing smoother, more fluid video reproduction. The Monster Connector DifferenceNoise and interference that can degrade an HDMI signal is often introduced at the connector. Monster Cable precision engineers its HDMI terminations and their internal components in order to reject external noise that can cause bit error and degrade picture and sound. The result: your HDTV will accurately display the high-definition video and audio from your high-definition sources, whether that's a 1080p-cable Blu-ray Disc™ Player, PlayStation® 3 or your 720p/1080i cable/satellite set-top box. Monster for HDMI connectors not only feature 24K gold contacts for maximum signal transfer and ultra-low distortion at the point of connection, but also silver-content soldering, connecting the HDMI cable's conductors to the connector's internal connection pins. This lowers resistance and maximizes digital signal transfer. Additionally, the Monster for HDMI cables feature a heavy-duty internal metal shell. As a result, the internal conductor wiring routed inside the connector is always fully shielded with metal. This provides an extra defense against interference that can enter at the connector and degrade the digital signal. It also makes the whole connector stronger, preventing internal breakage at any solder point between the conductors and connectors when the cable is installed or disconnected. This isn't the case on all HDMI cables. Many HDMI cables only feature metal at the connection point. Inside the connector, a thin plastic shield typically separates the molded or metal connector body from the wiring inside. This needlessly exposes the bitstream to noise and conductor wiring to damage during installation or everyday use.
Specification Description
Model 127654, 127654-00, MC 1000HD-1M, MC 1000HD-1M 127654
UPC 050644449017
Benefits Delivers up to 7.1 lossless digital surround sound for the ultimate movie, music and game experienceLarge gauge silver-coated conduct
Cable Length 3 ft
Cable Type HDMI cable
Capacity UOM mAh
Color Black
Country Of Origin China
Description Header Not all HDMI is the same.
Display Catalog Number 55030631
Enclosure Color Black
End Product Indicator Yes
Interface Supported HDMI
Jacket Material PVC
Left Connector(s) HDMI (1)
Manufacturer Labor Warranty 1
Manufacturer Part Number MC1000HD-1M
Manufacturer Parts Warranty 1
MAP Price 99.95
Model MC 1000HD-1M
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Disclaimer * Cable data rates measured under unequalized, worst case conditions. Data rates vary over longer lengths.
Product Length 39.3
Product Type HDMI & DVI cables
Right Connector(s) HDMI (1)
Shielding Material Gas-injected dielectric, high-density shielding
Supported Languages English
Monster 1000HD Ultra-High Speed HDMI Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 20, 2009
Monster 1000HD Ultra-High Speed HDMI Cable Reviews
Displaying 1 - 5 of 26 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Don't skimp on the cables
5.0
    Pros
  • High Quality
    Cons
  • None
    Best Uses
  • Home Entertainment System
"Before purchasing my home entertainment system this christmas, I did a lot of research. I purchased all top quality equipment. At the advice of the experts, I did not heed their advice and purchased cheaper, low speed HDMI cables to save a few dollars. DON'T DO IT. If you are buying quality equipmen …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Monster 1000HD Ultra-High Speed HDMI Cable helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jan 23 2008
Pete
Elysburg, PA
Reviewed at:
Price: $99.95
Quality Cable
5.0
    Pros
  • Durable construction
  • Improves Performance
    Cons
  • None
    Best Uses
  • Plasma TV-HD converter bo
"I have read various reviews that discredit buying high quality cables that tend to be more expensive. I wasn't convinced that my decision to buy this product was a good one until I had to swap out this HDMI cable with one provided to me by my cable provider.
This product provides very clear and …"  Read Full Review »
Jul 22 2008
Nicola
No. Virginia
I am:
  • Quality Oriented
Reviewed at:
Price: $99.95
Perfect Match to 1080P
5.0
    Pros
  • Perfect Picture
  • Qualty built
    Cons
  • None not even price
    Best Uses
  • 1080P Plasma
  • High-End Equipment
"Matching this cable to my Panasonic 58" Plasma is has resulted in what I can truly say is the only time I have gotten a "perfect" result. If you have taken the leap of a high end Plasma and have not experienced the "speed" of this cable you haven't experienced your Plasma. It simply is that good. "
Nov 20 2007
Done Deal
Wheaton, IL
I am:
  • Audio Enthusiast
  • Tech Savvy
Reviewed at:
One of the best deals I've found
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Good Warranty
  • Rugged
    Cons
  • None
    Best Uses
"So siimple to connect, and the picture and sound quality are amazing. Plus is was about $50 cheaper here than in any store I went to. "
Sep 6 2009
Rick the reader
Akron, Ohio
I am:
  • Casual User
Reviewed at:
Price: $99.95
[...]Good Price
5.0
    Pros
    Cons
  • None
    Best Uses
"B&H does it again. A happy and loyal customer of 5 plus years. This cable saved the day when I used the HDMI cable that Direct TV gave me the Blu-ray player didn't work. I switched over to this cable and was perfect. "
May 6 2008
Robmac
Boston
I am:
  • Tech Savvy
Reviewed at:
Price: $99.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$99.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$99.95
$64.78
$79.52
$79.99
$99.95
BizRate Rating Outstanding 9.4
$99.95
BizRate Rating Outstanding 9.1
$99.95
Code FALLSAVINGS33 : $5 Off Orders Over $50
$99.95
$99.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
