Mitsubishi WD-60737 60-inch 1080p DLP HDTV
#21
4.3
based on 21 reviews
from $1,199.00 - $1,299.99
Ratings Distribution
5 star
11
4 star
4
3 star
2
2 star
0
1 star
1
Category Average
4.5
Low Price:
$1,199.00 at OneCall
 Trusted:
$1,199.98 at Vanns.com
Find it at Amazon
More Images
Pros
  • Attractive design (10)
  • Fast setup (9)
  • Great picture quality (9)
  • Simple controls (9)
  • Price fair (1)
See less See more
Cons
  • Difficult to use (1)
  • Poor for fast motion (1)
Best Uses
  • Home (9)
  • Movies (9)
  • Professional (1)
  • Video (1)
  • Video games (1)
Provided by OneCall
Improved Performance
  • Energy Star 3.0 Qualified
  • Smooth 120Hz
  • 1080p DLP Display
  • Plush 1080p 5G Improved 12-bit Processing
  • Advanced Video Calibration Mode
  • Perfect Color ™
  • Improved Deep Field™ Imager
  • Improved SharpEdge™
  • Improved Video Noise Reduction
  • UltraThin™ Frame
  • Exclusive 6-Color Processor
  • Specification Description
    Model WD-60737
    UPC 082400028402
    Aspect Ratio 16:9
    Depth (Inches) 15.1
    Energy Star Compliant Yes
    HDTV HDTV Tuner Built In
    HDTV Native Resolution 1920 x 1080
    Height (Inches) 36.7
    Projection Type DLP Rear Projector
    Refresh Frequency 120 Hz
    Remote Control Included
    Screen Size (inches) 60
    Speakers Built-in
    Weight (Pounds) 64.9
    Width (Inches) 53.9
    Mitsubishi WD-60737 60-inch 1080p DLP HDTV Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 6, 2009
    Mitsubishi WD-60737 60-inch 1080p DLP HDTV Reviews
    Most helpful positive review
    [5 of 5 customers found this review helpful]
    Most helpful negative review
    [0 of 4 customers found this review helpful]
    4.0
    Great Overall -- Poor for fast motion
    "I decided to go with this DLP rather than an LCD or Plasma TV for it's great cost to size ratio. Wall mounting was not a priority, so the depth of the DLP was not an issue. I use the TV for watching every day TV -- anything from sitcoms to sports, DVDs, etc. Basically your typical home user. Although I am not a hardcore videophile, I tend to be very critical for poor quality, especially in the details. Pros: -..." Read Full Review »
    Jun 16, 2009 by Kurt I.
    See more positive Mitsubishi WD-60737 60-inch 1080p DLP HDTV reviews
    1.0
    How do you get a WD-60737 to shut off?
    "I have had this Home Center for a month, Now it has problems Booting up, Green light blinks all the time while trying to use the WD-60737/60inch.I have found it does not accept the remote, it turns it on But will not turn it off.All attempts to reset the TV Fail, Hold on/off switch 10 seconds, does not work?TV goes off while you hold the On/Off switch in,Let go and the tv comes back on?Screen Saver,welcome,Fans ..." Read Full Review »
    Jul 05, 2009 by Big Jim
    See more negative Mitsubishi WD-60737 60-inch 1080p DLP HDTV reviews
    Displaying 1 - 5 of 21 Reviews
    Show
    Sort by
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
      Best Uses
    • Home
    • Movies
    "I decided to go with this DLP rather than an LCD or Plasma TV for it's great cost to size ratio. Wall mounting was not a priority, so the depth of the DLP was not an issue. I use the TV for watching every day TV -- anything from sitcoms to sports, DVDs, etc. Basically your typical home user. Althoug …"  Read Full Review »
    Was this Rear Projection TV review on the Mitsubishi WD-60737 60-inch 1080p DLP HDTV helpful to you?
     Report Abuse  (5)  (0)  0 comments
    Jun 16 2009
    Kurt I.
    Cleveland, OH
    I am:
    • Enthusiast
    Reviewed at:
    Price: $1,199.00
    [3 of 3 customers found this review helpful]
    A great alternative to plasma and lcd
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Professional
    "This is a great product for the money. I shopped plasma and lcd and no where could I find a tv of this size for the money. The picture is great and contrary to what you read the blacks are deep and the brights are even better. Mitsubishi did a great job with this tv and if you are looking for the …"  Read Full Review »
     Report Abuse  (3)  (0)  0 comments
    Jul 20 2009
    dlp lover
    landisville nj
    I am:
    • Power User
    Reviewed at:
    Price: $1,199.00
    Great TV (2nd time around)
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Video games
    "I originally bought this TV through another company and it worked great for about 1 day. Then something inside the TV made a loud pop upon power-up the next morning. Only the red LED light would come on after that. I went with ONE CALL for the 2nd one (as I had already bought an expensive stand s …"  Read Full Review »
    Oct 6 2009
    Big D
    Temecula, CA
    I am:
    • Enthusiast
    Reviewed at:
    Price: $1,199.00
    REPLACED
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    Jul 26 2009
    I am:
    • Power User
    DOES ANY ONE NOTICE DARK SPOTS ON SCREEN
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "I JUST NOTICED ON THE SECOND ONE I JUST GOT PITURE WAS GREAT WHEN POWERING OFF ALL ONE SOLID COLOR,TILL A COUPLE OF DAYS AGO I NOTICED AT NIGHT AND DAY THERES A DARK SPOT AT THE BOTTOM&TOP RIGHT WHEN POWERING DOWN IS THIS NORMAL OR IS IT BURN INS? THANKS ALOT "
    Aug 7 2009
    I am:
    • Power User
    Reviewed at:
    Price: $1,199.00
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
