Mitsubishi Diamond Series 65" 1080p DLP Rear Projection HDTV - WD-65835
#17
4.5
based on 42 reviews
from $1,399.77 - $1,565.00
Ratings Distribution
5 star
26
4 star
15
3 star
0
2 star
0
1 star
1
Category Average
4.5
Low Price:
$1,399.77 at OneCall
 Trusted:
$1,565.00 at My Digital Universe
Find it at Amazon
More Images
Pros
  • Great picture quality (32)
  • Attractive design (31)
  • Fast setup (30)
  • Simple controls (25)
  • Good value (1)
  • Lightweight (1)
See less See more
Cons
  • Delays when switching (1)
  • Internal tv speakers (1)
  • No picture in a picture (1)
  • No split screen option (1)
  • Non-working chnnels setup (1)
  • Picture not the best (1)
  • Poor image quality (1)
  • Poor sound quality (1)
  • Poor speaker sound (1)
Best Uses
  • Home (29)
  • Movies (26)
  • Video (13)
  • Office (5)
  • Professional (5)
  • Games (2)
  • Blu ray (1)
  • Sports (1)
Provided by OneCall
1080P DLP® Display
High Definition Television display powered by Texas Instruments` latest 1080P DLP® chip. In combination with Mitsubishi exclusive light engines, over 2 million pixels of the highest high-def are delivered for the most detailed HD picture for a variety of today`s and tomorrow`s sources.
6-Color Processor
Mitsubishi's 6-Color Processor produces brighter colors, a wider range of colors and whiter whites.
Smooth 120Hz™
All light hold devices have some degree of motion blurring in fast moving images or videos. Light hold devices include DLP, LCD, Plasma, CRT, etc. Smooth 120hz is a unique Mitsubishi technology in the 833 series 1080p DLP TVs and 144 and 244 series of 1080p LCD TVs. This feature displays more fluid, natural and smoother fast moving images, free from motion blur. Removing motion blur and improving motion performance requires innovation and expertise. By unlocking a new level of motion reproduction, fast motion scenes are now much smoother and natural.
xvColor™
x.v.Color™ is the new standard in high definition color! The x.v.Color™ Wide Color Palette enables more color than ever before for breathtaking realism and vivid, natural colors. Maximize High Definition color performance.
Deep Color
Deep Color creates smooth transitions between different shades and eliminates color bands and complements x.v.Color™`s wide color pallet. Enabled by HDMI™ 1.3, Deep Color goes beyond previous 8-bit HDTV.
PerfectColor™
PerfectColor™ is an exclusive Mitsubishi feature that gives your customer the ability to adjust the intensity of six separate colors independently of each other and separately for every input. PerfectColor™ is a full color matrix, much more powerful than a conventional color intensity control with red versus green color balance.
PerfecTint™
PerfecTint™ is an exclusive Mitsubishi feature that provides the ability to adjust the tint of six separate colors independently of each other and separately for every input.
DarkDetailer™
DarkDetailer™ is a Mitsubishi exclusive technology that uses a dynamic aperture system to add depth and texture to the picture. Dark Detailer improves contrast ratio by more than four times, giving you a wide array of colors and shades that are essential for optimal viewing of dark, dramatic scenes while also providing maximum brightness.
Tru1080p™ Processing
Keep your signal the way it was meant to be seen. Mitsubishi`s Tru1080p™ Processing maintains 1080p high definition signals as 1080p from beginning to end. All 1080p DVI-I, HDMI™, IEEE 1394 and 1080p Broadcast signals are passed through with no down conversions. The advancements of 1080p DLP® technology for HDTV viewing deliver over 2 million pixels to you on-screen for a full and true 1920 x 1080 resolution. With Mitsubishi 1080p DLP® HDTVs, you can experience the best that high definition has to offer today and be ready to enjoy all of the 1080p sources that are on the horizon.
Plush1080p™
HDTVs can display any video signal. For a 1080p HDTV, even the high quality 720p and 1080i HDTV signals being broadcast need to be reformatted in order to fill the TV screen with a sharp, clear picture. Mitsubishi developed Plush1080p™ technology to do just this—with the highest quality possible. It scales the picture precisely, with minimal side effects. And 1080i, currently the most common form of HDTV signal, is spectacular at 1080p. The conversion is precise, resulting in previously unachievable detail and clarity. In short, Plush1080p™ technology makes everything else look better on a 1080p HDTV.
4D Video Noise Reduction
Mitsubishi`s exclusive 4D Video Noise Reduction uses advanced algorithms to better identify video noise from fine detail and correct the signal rather than distort it. Video noise is caused by distortions in the video signal and makes the picture too look grainy or snowy. As signal resolutions improve with the introduction of DVD, digital cable/ satellite and HDTV, the loss of sharpness produced by most noise reduction circuits becomes more noticeable. Mitsubishi`s advanced 4D Video Noise Reduction corrects the image in four dimensions: horizontally, vertically, within each frame and across multiple frames to provide an image that is crystal clear and extraordinarily detailed.
DeepField™ Imager
DeepField™ Imager constantly adjusts brightness and contrast for optimum settings in all areas of the picture. It can even optimize complex scenes containing both dark and bright areas. DeepField™ Imager analyzes 135 sectors of the picture in real time. It determines the optimum blend of contrast and brightness settings within the picture using advanced Mitsubishi algorithms. Based on picture analysis it dynamically adjusts for areas that are too high or low in contrast and/or too dark or bright displaying the best balanced picture in every scene.
SharpEdge™
SharpEdge™ is the latest in Mitsubishi`s edge-definition signal processing system. It enhances horizontal and vertical edges for stunning picture precision. SharpEdge™ senses the vertical boundary and amplifies it while minimizing distortion. The end result is crisp and sharp edges.
3D Ready
All Mitsubishi Diamond 1080p DLP HDTV's are "3D Ready". This feature allows you the ability to be immersed in your favorite video game, movie or sporting event. As more content becomes available in 3D, this functionality will develop into one of the most exciting HDTV experiences.
Easy Connect
Connectivity made easy! Mitsubishi`s ClearThought® Easy Connect simplifies set-up and day-to-day use. During set up, it recognizes each input as it is plugged in, prompts the user to name it, enters it into the Device Menu and only shows used inputs.
Wired IR Input
Wired IR inputs provides the ability to send remote control signals from external computerized home theater control systems into the TV without the clutter of stick-on IR blasters.
NetCommand® IR
This exclusive Mitsubishi feature provides the user with a true one–remote control home theater system for analog products. NetCommand IR® provides on-screen control of analog-connected products such as your AV receiver, DVD player, satellite receiver, and VCR. To set it up, you simply “tell" the television what products are connected and “teach it" their IR (infrared) commands. The TV will then take control, eliminating the coffee table clutter of remote controls. It`s capable of learning most IR remote control codes from standard home theater products, rather than relying on a preprogrammed library of codes.
Specification Description
Model WD-65835
UPC 082400026682
Analog Audio (1) Rear Output
Analog Audio (4) Rear Input
Analog Audio / Video Rear Input
Aspect Ratio 16:9
Command / Control NetCommand
Compatible Formats 1080i
Compatible Formats 1080p
Compatible Formats 480i
Compatible Formats 480p
Compatible Formats 720p
Compatible Furniture or Stand G363 Dark
Component Video (2) Rear Input
Depth (Inches) 15.3
HDMI (1) Front Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 39.5
Projection Type DLP Rear Projector
Remote Control Included
Resolution 1920 x 1080
S-Video Rear Input
Screen Size (inches) 65
Speakers 10 Watts x 2
Speakers Built-in
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port Front Input
Weight (Pounds) 74.4
Width (Inches) 58.2
Mitsubishi Diamond Series 65" 1080p DLP Rear Projection HDTV - WD-65835 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 14, 2009
Mitsubishi Diamond Series 65" 1080p DLP Rear Projection HDTV - WD-65835 Reviews
Most helpful positive review
Most helpful negative review
4.0
Great picture and remote control.
"Usage: TV programs (HD picture is very good, see my photo below), DVD, VCR, photos from camera and flash drive with front USB input, PC monitor with HDMI input and use of long range wireless keyboard and mouse. Good: Reasonable price. Great picture quality right out off the box. Great universal remote (much better than 2009 837 & 737 RC) for all video/audio devices connected. Convenient front USB input (o..." Read Full Review »
Aug 24, 2009 by 835user
See more positive Mitsubishi Diamond Series 65" 1080p DLP Rear Projection HDTV - WD-65835 reviews
1.0
waste of money!!
"OMGOSH!!! talk about a TV that's high maintenance...I've had this tv for 3 years now. We don't use it as often as most people do, but I will tell you this...it sucks!! With us not using it much, we have to constantly cross our fingers for it to turn out with out some bulb thing be burnt or it just not turning on...MISTSUBISHI SUCKS!!..." Read Full Review »
Nov 14, 2009 by hate mitsubishi now
See more negative Mitsubishi Diamond Series 65" 1080p DLP Rear Projection HDTV - WD-65835 reviews
Displaying 1 - 5 of 42 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Light weight
  • Simple Controls
    Cons
  • Internal TV speakers
    Best Uses
  • Home
  • Movies
  • Office
  • Video
"Usage:
Good:
Reasonable price.
Great …"  Read Full Review »
65835 in light room, HD channel, VTI TV stand.
Was this Rear Projection TV review on the Mitsubishi Diamond Series 65" 1080p DLP Rear Projection HDTV - WD-65835 helpful to you?
Aug 24 2009
835user
SouthEast
I am:
  • Casual User
Reviewed at:
Price: $1,399.77
BEAUTIFUL "BIG" PICTURE at LOW Price!!!
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • No complaints
  • None
    Best Uses
  • Home
"Beatiful TV for the price. How can you get a 65" HD TV at a lower price? It still is not a plasma or a LCD but it does have a low profile. Any complaints about the speakers are crazy. You don't buy a TV like this for the sound. Any audiophile would have a separate 7 to 1 sound sytem! Again, ex …"  Read Full Review »
Nov 10 2009
70sssnake
Park Rapids, MN
I am:
  • Power User
Reviewed at:
Price: $1,399.77
[2 of 3 customers found this review helpful]
I AGREE WITH PRO REVIEWS - FIVE STARS!!!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"I researched large screens for two years while waiting to take the plunge. Reviewers as well as sales people generally place the Pioneer Kuro Elite as the number one viewing experience, with the lower cost Pioneer Kuro at number two, then - somewhat surprisingly until you actually see it - the Mitsu …"  Read Full Review »
 Report Abuse  (2)  (1)  0 comments
Jul 6 2009
beachbull
Albuquerque NM
I am:
  • Enthusiast
Reviewed at:
Price: $1,399.77
waste of money!!
1.0
    Pros
  • Great Picture
    Cons
  • None
    Best Uses
  • None
"OMGOSH!!! talk about a TV that's high maintenance...I've had this tv for 3 years now. We don't use it as often as most people do, but I will tell you this...it sucks!! With us not using it much, we have to constantly cross our fingers for it to turn out with out some bulb thing be burnt or it just n …"  Read Full Review »
Nov 14 2009
hate mitsubishi now
spokane valley, WA
I am:
  • Casual User
Reviewed at:
Price: $1,399.77
Best Value in HD TV's on the market
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"The bottom line of any TV is the picture. As a discriminating AV consumer I am inpressed how good this TV is. The picture is lifelike and viabrant. Compared to LCD or Plasma, the picture quality differences are very difficult to notice. Unless you plan to hang it on the wall,considering the huge co …"  Read Full Review »
Oct 15 2008
rieseng
Dallas, Texas
I am:
  • Enthusiast
Reviewed at:
Price: $1,399.77
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
