Mitsubishi 73-inch 1080p Rear Projection DLP HDTV - WD-73835
4.9
based on 28 reviews
from
Ratings Distribution
5 star
25
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
4.5
More Images
Pros
  • Great picture quality (21)
  • Attractive design (19)
  • Fast setup (19)
  • Simple controls (17)
  • Best picture i ever seen (1)
  • Great sound quality (1)
See less See more
Best Uses
  • Movies (18)
  • Home (15)
  • Video (8)
  • Professional (3)
  • All dvd's display 1080p (1)
  • Office (1)
  • Usb for laptop camera (1)
Provided by OneCall
1080P DLP(R) Display
High Definition Television display powered by Texas Instruments` latest 1080P DLP(R) chip. In combination with Mitsubishi exclusive light engines, over 2 million pixels of the highest high-def are delivered for the most detailed HD picture for a variety of today`s and tomorrow`s sources.
Smooth 120Hz(TM)
All light hold devices have some degree of motion blurring in fast moving images or videos. Light hold devices include DLP, LCD, Plasma, CRT, etc. Smooth 120hz is a unique Mitsubishi technology in the 833 series 1080p DLP TVs and 144 and 244 series of 1080p LCD TVs. This feature displays more fluid, natural and smoother fast moving images, free from motion blur. Removing motion blur and improving motion performance requires innovation and expertise. By unlocking a new level of motion reproduction, fast motion scenes are now much smoother and natural.
xvColor(TM)
x.v.Color(TM) is the new standard in high definition color! The x.v.Color(TM) Wide Color Palette enables more color than ever before for breathtaking realism and vivid, natural colors. Maximize High Definition color performance.
Deep Color
Deep Color creates smooth transitions between different shades and eliminates color bands and complements x.v.Color(TM)`s wide color pallet. Enabled by HDMI(TM) 1.3, Deep Color goes beyond previous 8-bit HDTV.
PerfectColor(TM)
PerfectColor(TM) is an exclusive Mitsubishi feature that gives your customer the ability to adjust the intensity of six separate colors independently of each other and separately for every input. PerfectColor(TM) is a full color matrix, much more powerful than a conventional color intensity control with red versus green color balance.
PerfecTint(TM)
PerfecTint(TM) is an exclusive Mitsubishi feature that provides the ability to adjust the tint of six separate colors independently of each other and separately for every input.
DarkDetailer(TM)
DarkDetailer(TM) is a Mitsubishi exclusive technology that uses a dynamic aperture system to add depth and texture to the picture. Dark Detailer improves contrast ratio by more than four times, giving you a wide array of colors and shades that are essential for optimal viewing of dark, dramatic scenes while also providing maximum brightness.
Tru1080p(TM) Processing
Keep your signal the way it was meant to be seen. Mitsubishi`s Tru1080p(TM) Processing maintains 1080p high definition signals as 1080p from beginning to end. All 1080p DVI-I, HDMI(TM), IEEE 1394 and 1080p Broadcast signals are passed through with no down conversions. The advancements of 1080p DLP(R) technology for HDTV viewing deliver over 2 million pixels to you on-screen for a full and true 1920 x 1080 resolution. With Mitsubishi 1080p DLP(R) HDTVs, you can experience the best that high definition has to offer today and be ready to enjoy all of the 1080p sources that are on the horizon.
Plush1080p(TM)
HDTVs can display any video signal. For a 1080p HDTV, even the high quality 720p and 1080i HDTV signals being broadcast need to be reformatted in order to fill the TV screen with a sharp, clear picture. Mitsubishi developed Plush1080p(TM) technology to do just this—with the highest quality possible. It scales the picture precisely, with minimal side effects. And 1080i, currently the most common form of HDTV signal, is spectacular at 1080p. The conversion is precise, resulting in previously unachievable detail and clarity. In short, Plush1080p(TM) technology makes everything else look better on a 1080p HDTV.
4D Video Noise Reduction
Mitsubishi`s exclusive 4D Video Noise Reduction uses advanced algorithms to better identify video noise from fine detail and correct the signal rather than distort it. Video noise is caused by distortions in the video signal and makes the picture too look grainy or snowy. As signal resolutions improve with the introduction of DVD, digital cable/ satellite and HDTV, the loss of sharpness produced by most noise reduction circuits becomes more noticeable. Mitsubishi`s advanced 4D Video Noise Reduction corrects the image in four dimensions: horizontally, vertically, within each frame and across multiple frames to provide an image that is crystal clear and extraordinarily detailed.
DeepField(TM) Imager
DeepField(TM) Imager constantly adjusts brightness and contrast for optimum settings in all areas of the picture. It can even optimize complex scenes containing both dark and bright areas. DeepField(TM) Imager analyzes 135 sectors of the picture in real time. It determines the optimum blend of contrast and brightness settings within the picture using advanced Mitsubishi algorithms. Based on picture analysis it dynamically adjusts for areas that are too high or low in contrast and/or too dark or bright displaying the best balanced picture in every scene.
SharpEdge(TM)
SharpEdge(TM) is the latest in Mitsubishi`s edge-definition signal processing system. It enhances horizontal and vertical edges for stunning picture precision. SharpEdge(TM) senses the vertical boundary and amplifies it while minimizing distortion. The end result is crisp and sharp edges.
Video Modes: Brilliant / Bright / Natural / Game
Use the four picture video modes to adjust for optimum viewing in different room lighting and gaming applications. All modes are accessible via the VIDEO key on the remote control.
3D Ready
All Mitsubishi Diamond 1080p DLP HDTV's are 3D Ready. This feature allows you the ability to be immersed in your favorite video game, movie or sporting event. As more content becomes available in 3D, this functionality will develop into one of the most exciting HDTV experiences.
Easy Connect
Connectivity made easy! Mitsubishi`s ClearThought(R) Easy Connect simplifies set-up and day-to-day use. During set up, it recognizes each input as it is plugged in, prompts the user to name it, enters it into the Device Menu and only shows used inputs.
Wired IR Input
Wired IR inputs provides the ability to send remote control signals from external computerized home theater control systems into the TV without the clutter of stick-on IR blasters.
NetCommand(R) IR
This exclusive Mitsubishi feature provides the user with a true one–remote control home theater system for analog products. NetCommand IR(R) provides on-screen control of analog-connected products such as your AV receiver, DVD player, satellite receiver, and VCR. To set it up, you simply “tell the television what products are connected and “teach it their IR (infrared) commands. The TV will then take control, eliminating the coffee table clutter of remote controls. It`s capable of learning most IR remote control codes from standard home theater products, rather than relying on a preprogrammed library of codes.
Front USB Input (5MP Photo)
View 5 Mega Pixel Photos on your Mitsubishi TV in startling HD clarity. Easily connect a USB thumb drive or USB Card Reader.
Specification Description
Model WD-73835
UPC 082400026699
Analog Audio (1) Front Input
Analog Audio (1) Rear Output
Analog Audio (3) Rear Input
Aspect Ratio 16:9
Command / Control NetCommand
Compatible Formats 1080i
Compatible Formats 1080p
Compatible Formats 480i
Compatible Formats 480p
Compatible Formats 720p
Compatible Furniture or Stand MBS73
Component Video (1) Front Input
Component Video (2) Rear Input
Depth (Inches) 17.5
HDMI (1) Front Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 43.6
Projection Type DLP Rear Projector
Remote Control Included
Resolution 1920 x 1080
S-Video Rear Input
Screen Size (inches) 73
Speakers 10 Watts x 2
Speakers Built-in
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port Front Input
Weight (Pounds) 95.2
Width (Inches) 65.2
Mitsubishi 73-inch 1080p Rear Projection DLP HDTV - WD-73835 Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 73-inch 1080p Rear Projection DLP HDTV - WD-73835
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 14, 2009
Mitsubishi 73-inch 1080p Rear Projection DLP HDTV - WD-73835 Reviews
Displaying 1 - 5 of 28 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Awesome TV! HUGE!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"What an awesome TV! The picture quality is simply amazing. I personally think it's better than any LCD or Plasma screen that I've seen to date - and I'm a PICKY person!
The TV is HUGE! My kids couldn't believe it. After getting a Blu-Ray player hooked up, the magic began. I could see even the ti …"  Read Full Review »
Was this Rear Projection TV review on the Mitsubishi 73-inch 1080p Rear Projection DLP HDTV - WD-73835 helpful to you?
 Report Abuse  (2)  (0)  0 comments
Mar 4 2009
Jim R.
Hitchcock, TX
I am:
  • Enthusiast
Reviewed at:
[3 of 3 customers found this review helpful]
Probably the 2nd best tv ever created
5.0
"As I said on my title this is the 2nd best television on Earth! The best television is the Mitsubishi 73inch laser vue tv. But still even though it is the 2nd best it is amazing! If you have a blue ray player, hd dvd player, a 360, a ps3, or basically any thing, this tv will make it look like heaven …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Nov 23 2008
Thebestreviewerevery
brooklyn, NY
Reviewed at:
Very impressed! Magnolia
5.0
"I had actually purchased the Mitsubishi 60 inch 1080 DLP and I loved it. However, it did not quite fit what I was looking for, so 30-Days later I went back to the store to look at the 65 inch and noticed they had the Diamond series and all the new improvements they made. Already impressed it did tak …"  Read Full Review »
Oct 28 2008
Luvme94533
Sacramento, Ca
Reviewed at:
[2 of 3 customers found this review helpful]
Genuine Recomend
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Movies
  • Video
"This is a great set for the price, 73" of screen will quickly fill most home theaters, the picture is on par with most higher priced Plasma screens, Blacks are black, Colors are rich. the on screen menu is not overly cumbersome so set up is not too intimidating. For a DLP rear projection unit thi …"  Read Full Review »
 Report Abuse  (2)  (1)  0 comments
Sep 14 2008
Frankenstien
South Prairie WA
I am:
  • Enthusiast
Reviewed at:
As Advertised, Plus
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"I read reviews on this TV for several months before buying. The reviews were all goood, the product is even better. [...] I took it out of the box, plugged it in and the picture is perfect. The setup and controls are very easy to do. The 73 inch screen in hugh but great for my 28X32 room. This …"  Read Full Review »
Mar 31 2009
Pigeonrooster
Pigeon Roost(Hattieville), AR
I am:
  • Casual User
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
