Mitsubishi 57" 734 Series 1080p DLP Rear Projection HDTV - WD-57734
4.0
based on 5 reviews
from
Ratings Distribution
5 star
3
4 star
1
3 star
0
2 star
0
1 star
1
Category Average
4.5
More Images
Pros
  • Fast setup (4)
  • Great picture quality (4)
  • Attractive design (3)
  • Simple controls (3)
See less See more
Cons
  • Bad interface (1)
Best Uses
  • Home (5)
  • Movies (3)
  • Video (1)
Provided by Beach Audio
More color, for a more colorful image. Mitsubishi is taking Color to a new level with x.v.Color support and its exclusive 6-Color Light Engine. x.v.Color is the new standard for HDTV color and it enables 80% more color than standard HDTV! Mitsubishis 6-Color Light Engine processes and produces images with six different colors instead of the traditional three to display a wider range of colors, brighter colors and whiter whites. Additional color features such as Color 4D Video
Noise Reduction, PerfectColor and PerfecTint allow for additional advanced color processing and adjustment. The result is breathtaking realism with vivid, yet natural Color Without Compromise.
Larger screen, not larger spaces.
These 734 Series 57, 65 and 73 1080p DLP HDTVs feature Mitsubishis unique TurboLight180 lamp system and Plush1080p processing for both unsurpassed detail in over 2 million pixels and for bright, vibrant images. The stunning High Definition picture is further enhanced by its sleek and modern look. Mitsubishis sleek, simple design in Platinum Black provides more picture with less frame. This year even the 73 1080p DLP HDTV gets a thin frame, and a dramatically thinner cabinet. With 1080p and a compact cabinet, get a larger screen and sit closer than ever before! Go ahead and get into the action, immerse yourself
Lots of connections, made easy.
Mitsubishi leads the industry with 3 rear HDMI 1.3 inputs and 2 rear component inputs for maximum HD connectivity. Both a Front HDMI 1.3 input and Front Component Video Input allow you to easily connect your favorite HD game system. Additionally, a USB input for up to 5 Mega Pixel pictures connects you to large screen digital photo viewing. And Mitsubishis Easy Connect along with NetCommand make set-up and single remote operation of all your AV components so easy.
Features:
1080p DLP Display
Mitsubishi Exclusive 6-Color Light Engine
x.v.Color
Deep Color
TurboLight180
Dark Detailer
Plush1080p
Tru1080p Processing
Color 4D Video Noise Reduction
PerfectColor
PerfecTint
DeepField Imager
SharpEdge
Video Modes: Brilliant / Bright / Natural / Game
Watch TV Your Way
Easy Connect
NetCommand
Front USB Input (5 Mega Pixel Photo)
Front HDMI 1.3 Input
3 Rear HDMI 1.3 Inputs
SimplayHD Certified HDMI
2 Rear Component Inputs
Partially-Illuminated Remote
Specifications:
Model: WD-57734
Screen Size: 57-inch
Aspect Ratio: 16:9 (widescreen)
Height (Physical): 35.0"
Width (Physical): 51.3"
Depth (Physical): w/o foot 13.9"
Height On Base: 53.1"
Weight (Physical): 62.3 lbs.
Power Consumption
Operating: 265 Watts
Standby: < 15 Watts
Low Standby: < 2 Watts
Optical System
Display Type: 1080p DLP
Mitsubishi Exclusive Light Engine: 6-Color
Pixel Resolution (horizontal x vertical*): 1920 x 1080
Lamp Power: 180 Watts
Dynamic Contrast: Dark Detailer
Video Performance
Video Format Conversion: Plush1080p
x.v.Color: Yes
Deep Color: Yes
PerfectColor: Yes
PerfecTint: Yes
DeepField Imager: Yes
SharpEdge: Yes
Video Noise Reduction: Color 4D
Picture Format Modes (4:3 sources): 6
Picture Format Modes (16:9 sources): 2
User Controls
Easy Connect: Yes
NetCommand: Yes
ChannelView: Yes
AV Adjustment (memorized by input): Yes
Color Temperature Control (by input): High/Low
Video Modes: Brilliant/Bright/Natural/Game: Yes
Full Screen Image Freeze: Yes
Audio
Internal Loudspeakers: Stereo Full Range
Speaker Size: 5 1/2" x 2 1/4"
Output Power (watts/ch.): 10W x 2
Level Sound (dynamics limiter): Yes
Digital Output (PCM) for All Analog Sources: Yes
Tuning
Combined Tuner (Analog/Digital/Cable) In The Clear: 1
Antenna (RF) Inputs: 2
AV Inputs (Analog with Stereo Audio)
Front Component Video Input: 1
Rear Component Video Inputs (480i/480P/720P/1080i): 2
Rear A/V Inputs with S-Video: 2
Front USB Input (5 Mega Pixel Photo): 1
Inputs / Outputs (Digital)
Front HDMI 1.3 Inputs: 1
Rear HDMI 1.3 Inputs: 3
480i, 480p, 720p, 1080i (60Hz): Yes
1080p (24Hz, 30Hz, 60Hz): Yes
Digital Audio Output (Dolby Digital / PCM): 1 (coaxial)
HDMI: Digital PC Compatibility
640 x 480, 898 x 480, 800 x 600, 1064 x 600, 1024 x 768, 1280 x 720, 1365 x 768, 1280 x 1024 @ 60Hz: Yes
1920 x 1080 @ 24Hz, 30Hz, 60Hz: Yes
Outputs (Analog)
Stereo Audio Output: 1 (fixed)
NetCommand IR Emitter: 1
Remote Control
Remote Control: Partially-Illuminated
5 Device Multibrand Illuminated Remote: Yes
Customization Features
Direct IR Input Selection: Yes
Direct IR Format Selection: Yes
Independent IR Power ON / OFF: Yes
Specification Description
Model WD-57734, WD57734
UPC 082400025357
Analog Audio (1) Rear Input
Analog Audio (1) Rear Output
Analog Audio / Video (2) Rear Input
Aspect Ratio 16:9
Coaxial (1) Rear Output
Command / Control NetCommand
Compatible Formats 1080i
Compatible Formats 1080p
Compatible Formats 480i
Compatible Formats 480p
Compatible Formats 720p
Compatible Formats JPEG
Compatible Furniture or Stand MB-57PB
Component Video (2) Rear Input
Depth (Inches) 13.9
HDMI (1) Front Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 35
Projection Type DLP Rear Projector
Remote Control Included
Resolution 1920 x 1080
RF (2) Rear Input
S-Video (2) Rear Input
Screen Size (inches) 57
Speakers 10 Watts x 2
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port (1) Front Input
Weight (Pounds) 62.3
Width (Inches) 51.3
Mitsubishi 57" 734 Series 1080p DLP Rear Projection HDTV - WD-57734 Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 57" 734 Series 1080p DLP Rear Projection HDTV - WD-57734
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 11, 2009
Mitsubishi 57" 734 Series 1080p DLP Rear Projection HDTV - WD-57734 Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
Lamp life is very short and expensive
1.0
    Pros
  • Fast Setup
  • Great Picture
    Cons
  • None
    Best Uses
  • Home
"The best picture I've ever seen but the lamp has a short life. Mine lasted 14 months, and the replacement costs $250. Since Mitsubishi will not replace the lamp after 12 months, this must be fairly normal. I have talked to their service line several times and they just say that I abuse my TV by watc …"  Read Full Review »
Was this Rear Projection TV review on the Mitsubishi 57" 734 Series 1080p DLP Rear Projection HDTV - WD-57734 helpful to you?
Jan 11 2009
Mike
Ridgecrest, CA
I am:
  • Casual User
Very Satisfied
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"This TV is awsome. I purchased the 57" online and then wondered if I should have gotten the 65" instead. Glad I didn't because the 57" is large enough even for larger rooms. The non HD picture is not any better then the previous projection TV I owned but the HD picture is far superior (especially co …"  Read Full Review »
Dec 13 2007
CrazedEaglesFan
San Diego
I am:
  • Practical
Reviewed at:
theirs to many controls and adjustments
4.0
    Pros
  • None
    Cons
  • Bad Interface
    Best Uses
  • Home
"I'm still having a problem with the dvd player that I bought with my DLP TV (just getting it to respond to the remote...I will be giving tech support a call tomarrow morning also my surround sound system works but can't get it to work with the TV and DVD player. My Directv service did not help much …"  Read Full Review »
Jan 20 2008
JC
Chicago IL.
I am:
  • Practical
  • Technically Challenged
I would buy this product again and again
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"I never thought television could be such a great experience. I have been recommending to family members. One family member in the process of buying it. "
Sep 1 2008
Earley Bird Man
Salamanca, NY
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Can't get any better but bigger
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"I've done a solid month of heavy investigating on big screen TV's, and this brand wins out by far, for the price. "
Dec 4 2007
J.T.
Grand Prairie, Texas
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
