Miscellaneous Pro-T Flash Bracket
#1935
3.4
based on 18 reviews
Ratings Distribution
5 star
4
4 star
9
3 star
0
2 star
1
1 star
4
Category Average
4.2
Low Price:
$74.39 at B&H Photo Video
 Trusted:
$74.39 at Adorama
Find it at Amazon
$74.39
from 2 stores
More Images
Pros
  • Lightweight (11)
  • Reliable (9)
  • Well built / quality construction (7)
  • Easy to use (4)
  • Convenient interface (2)
  • Softens light (2)
  • Better design (1)
  • Durable (1)
  • Improve lighting quality (1)
  • None of any significance (1)
See less See more
Cons
  • Poor interface (3)
  • Bulky (2)
  • Absolutely no quality (1)
  • Adds bulk (1)
  • Cheap (1)
  • Creates shawdows (1)
  • Difficult to use (1)
  • Have to buy mount piece (1)
  • Heavy (1)
  • Limited custom baseplates (1)
Best Uses
  • Photojournalism (6)
  • Lighting (5)
  • Photography (4)
  • Fill flash (3)
  • Portraits (3)
  • Events weddings (1)
  • Everyday (1)
  • Fast action (1)
  • General purpose (1)
  • Reduce shadows (1)
Provided by B&H Photo Video
The Pro-T and Press-T are flash-rotating brackets. Both are light, compact and fast-handling with swinging flash arm to keep the flash centered over the lens for both horizontal and vertical compositions. These brackets do not require the use of a cable release. Unlike conventional brackets, the PRO-T is designed for you to hold the camera rather than the bracket, for a more natural way of shooting. Also allows you to instantly switch between horizontal and vertical compositions. The PRESS-T is a slightly shorter and more compact version of the Pro-T. Popular with photojournalists and other shooters who work out of a camera bag. Net Weight: 14 oz., Bracket Height: 9.25", Lens-to-Flash Distance: 12"
Specification Description
Model 310800
UPC 750062001889
Select 35mm & Digital Camera Brackets,Medium Format Brack
Miscellaneous Pro-T Flash Bracket Questions
Questions and Answers
Where to Buy
$74.39
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$74.39
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Nov 5, 2009
Miscellaneous Pro-T Flash Bracket Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
Well-made, great results.
"Originally purchased for Nikon D70, Currently using with Canon EOS 20, TTL extension cable and Sigma flash. Using universal cork mount, which slips slightly. makes the Best setup for Wedding and party candids where people are your primary subjects. Great results and catch lights with the height of the pro-T. Quick-flip goes from Horiz. to Vert orientation in 1 second. Small features of extendable front stan..." Read Full Review »
Feb 12, 2007 by kcImagecrafters
See more positive Miscellaneous Pro-T Flash Bracket reviews
1.0
Stamped Metal Piece of JUNK!!
"This product is so cheaply made I was embarrassed to use it in public. I am a complete loss as to why anyone in their right mind would consider hanging this thing off their camera. There are no machined parts ... it is completely made of cheap stamped metal and plastic and the thing wobbles all over the place. I would not wish this piece of junk on my worst enemy and I seriously have doubts about anyone that ..." Read Full Review »
Jan 30, 2009 by wizard
See more negative Miscellaneous Pro-T Flash Bracket reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
4.0
    Pros
  • Reliable
  • Strong Construction
    Cons
    Best Uses
  • Photography
  • Photojournalism
"Originally purchased for Nikon D70, Currently using with Canon EOS 20, TTL extension cable and Sigma flash. Using universal cork mount, which slips slightly. makes the Best setup for Wedding and party candids where people are your primary subjects. Great results and catch lights with the height o …"  Read Full Review »
  • Using Product
Was this Camera Accessory review on the Miscellaneous Pro-T Flash Bracket helpful to you?
 Report Abuse  (2)  (0)  0 comments
Feb 12 2007
kcImagecrafters
Roeland Park, KS
I am:
  • Professional
Reviewed at:
Price: $74.39
Stroboframe Pro-T flash bracket
5.0
    Pros
  • Convenient Interface
  • Lightweight
  • Reliable
  • Softens Light
  • More »
    Cons
    Best Uses
  • Fill Flash
  • Lighting
  • Photography
  • reduce shadows
"has improve my photography immensely. [...] "
This photo was taken with my strobo frame set up
  • Made with Product
 Report Abuse  (1)  (0)  0 comments
Feb 5 2007
TRPHOTOZ
RICHMOND, VA
Reviewed at:
Price: $74.39
This is a quality flash bracket...
4.0
    Pros
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Portraits
  • Studio
"I can only assume those who say this is a bad product either (a) don't know how to use it, or (b) have a personal ax to grind. This flash bracket does what it should...provides a stable flash mount for both horizontal and vertical shots, with little hassle and excellent results. If you get shadows …"  Read Full Review »
Oct 29 2009
Bad Pete
Egg Harbor Township, New Jersey
I am:
  • Semi-Professional
Reviewed at:
Price: $74.39
The bracket worked great with my flash.
5.0
    Pros
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Everyday use
  • Portraits
"I needed to get the flash off the camera to prevent "red eye" images. With the flash on the bracket, the ilumination on the subject was lighted much better. In addition, the bracket allowed the flash to be positioned over the lens when I turned the camera vertically. "
Nov 5 2009
Photo guy
East Chicago, IN
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $74.39
1.0
    Pros
    Cons
  • Absolutely NO quality
  • Bulky
  • Cheap
  • Heavy
    Best Uses
  • Fill Flash
  • General Use
  • Portraits
"This product is so cheaply made I was embarrassed to use it in public. I am a complete loss as to why anyone in their right mind would consider hanging this thing off their camera. There are no machined parts ... it is completely made of cheap stamped metal and plastic and the thing wobbles all ov …"  Read Full Review »
Jan 30 2009
wizard
St. Louis, MO
I am:
Reviewed at:
Price: $74.39
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
