Mio MOOV M300 GPS Receiver
#73
4.1
based on 16 reviews
Ratings Distribution
5 star
7
4 star
7
3 star
0
2 star
1
1 star
1
Category Average
4.1
$119.99 at RadioShack
Find it at Amazon
Find it at Ebay
$119.99
from 1 store
Pros
  • Easy menus (14)
  • Easy setup (13)
  • Easy to read (12)
  • Compact (11)
  • Simple controls (10)
  • Acquires satellites quickly (9)
  • Reliable (8)
  • Large screen (6)
  • Easy to teach (1)
See less See more
Cons
  • Acquires satellites slowly (2)
  • Inaccurate (2)
  • Faulty maps (1)
  • Flimsy mounting (1)
  • Poor battery life (1)
  • Poor satellite position (1)
  • Small screen (1)
  • Unreliable (1)
Best Uses
  • Faster routes (10)
  • Planning trips (10)
  • Finding specific address (9)
  • Urban navigation (8)
  • Rural navigation (3)
  • Geocaching (1)
  • Getting lost (1)
  • Just excellent all around (1)
  • Not getting lost (1)
Provided by RadioShack
Never wonder where you are again with the M300 by your side.
Specification Description
Model MOOVM300
Alarms Speed Alert
Antenna Internal
Available memory 1GB
Battery Type Product
Benefits 3.5-inch widescreen makes it easy to see where you're headingNavPix photo navigation enables you to discover new places and find your
Cables Included USB cable
Capacity 720
Capacity UOM mAh
Chemistry Lithium Ion
Color support Yes
Connections USB (1)Power (1)
Country Of Origin China
Description Header Say goodbye to getting lost.
Display Catalog Number 20-535
Display size (diagonal) 3.5 inches
End Product Indicator Yes
GPS type Car
Included in the Box MOOV M300 GPS receiverWindshield mounting bracketUSB cableVehicle charger
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Maps U.S. 50 states and Puerto Rico
Menu navigation Touchscreen
Model MOOVM300
Mounting options Windshield mount
Operating Temperature UOM ° F
Photo viewer Yes
Points of interest 4 million
Power Device Vehicle charger, rechargeable Li-ion battery
Product Type Car
Product Weight 5.28
Product Weight UOM ounces
Rechargeable Yes
Resolution 320x240
Size Specialty
Spoken street names Yes
Supported Languages English
Touchscreen Yes
Type Touchscreen
Mio MOOV M300 GPS Receiver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Mio MOOV M300 GPS Receiver Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Exceptional Perfromance and Value
"This is an EXCEPTIONAL unit..It offers sophisticated Intersection Lane Direction Navigation and spoken street names! All the Lane change coverege appears broad not only at very complex intersections ..this alone is worth the cost.You need to spend 350.00 to get this on a Garmin... Exceptional 3d nav images are very realistic...gives you great sense of feel when driving and keys you in to places where you did no..." Read Full Review »
Oct 25, 2009 by MFB
See more positive Mio MOOV M300 GPS Receiver reviews
2.0
Great, if you want to be constantly lost
"This GPS literally got me LOST more often than it got me where I needed to be!!! The maps were COMPLETELY innacurate. There were roads just MISSING every time I got off the freeway. At one point, it routed me into a subdivision, drove me all through this neighborhood, and I ended up on a dead end, with the GPS insisting I keep on straight. I finally had to call the friend I was visiting for directions, who i..." Read Full Review »
Nov 09, 2009 by Frustrated traveller
See more negative Mio MOOV M300 GPS Receiver reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
2.0
    Pros
  • Easy Menus
  • Easy To Set Up
  • Large Screen
  • Simple Controls
    Cons
  • Faulty maps
  • Inaccurate
  • Unreliable
    Best Uses
  • Getting lost
"This GPS literally got me LOST more often than it got me where I needed to be!!! The maps were COMPLETELY innacurate. There were roads just MISSING every time I got off the freeway. At one point, it routed me into a subdivision, drove me all through this neighborhood, and I ended up on a dead end …"  Read Full Review »
Was this Car GPS review on the Mio MOOV M300 GPS Receiver helpful to you?
 Report Abuse  (1)  (0)  0 comments
Nov 9 2009
Salt Lake City, UT
I am:
  • Casual User
5.0
    Pros
  • Acquires Satellites Quickly
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Faster Routes
  • Finding Specific Address
  • Planning Trips
  • Urban Navigation
Exceptional 3d …"  Read Full Review »
Oct 25 2009
MFB
Norther California
I am:
  • Enthusiast
Good entry-level unit
4.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • Simple Controls
    Cons
  • None
    Best Uses
  • Urban Navigation
"Used this for my cross-country drive from California to Michigan.The highway directions were spot-on, except for just a few on-ramp turns. For a 1,700-mile trip, I think this is acceptable.It recalculated new directions quickly when I missed a turn.I also liked the ability to import custom Points-o …"  Read Full Review »
Oct 28 2009
Tze
Grand Rapids, MI
I am:
  • Enthusiast
GREAT GPS!
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • Short Battery Life
    Best Uses
  • Faster Routes
  • Geocaching
  • Planning Trips
  • Rural Navigation
  • More »
"This is a great gps! It aquires the satellites extremely quick. I've had a tom tom, navman, and I also currently have a magellan, all of which doesnt compare to this MIO.. Great deal! "
Nov 1 2009
FF1720
Bevinsville, KY
I am:
  • Enthusiast
[2 of 2 customers found this review helpful]
Best [$] I have spent.
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
"I can not believe what this unit can do for [$]! This unit does far more than you would expect by reading about it. Speaks street names with a real voice, not a musical DING' Shows tons of info by touching the screen. Including Speedometer, compass, Clock, and even a speed reminder set to any speed …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Oct 8 2009
Stringer
massachusetts
I am:
  • Power User
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
