Midland Radio Corporation HH50 Pocket Weather Alert Radio
#131
3.9
based on 12 reviews
Ratings Distribution
5 star
5
4 star
6
3 star
1
2 star
1
1 star
1
Category Average
3.8
Low Price:
$15.99 at ClubMac
 Trusted:
$19.99 at TigerDirect
$16.72 at Meijer.com
see all stores
$15.99 - $24.99
from 16 stores
More Images
Pros
  • Lightweight (12)
  • Easy to use (5)
  • Great reception (5)
  • Clear signal (4)
  • Durable (3)
  • Great sound quality (3)
  • Rugged (3)
  • Compact (2)
  • Clear reception (1)
  • Good audio (1)
See less See more
Cons
  • Flimsy (1)
  • Poor battery life (1)
  • Short range (1)
  • Sub-par audio (1)
Best Uses
  • Home use (5)
  • Travel (4)
  • Camping (3)
  • Emergencies (3)
  • Everyday (3)
  • Hiking (3)
  • Good for commuting (2)
  • Hunting (2)
  • Running (1)
  • Walking (1)
Provided by BoatersWorld.com
HH50
Now receive 24-hour-a-day National Weather Bureau Broadcasts no matter where you are. This handheld, portable unit has an ALERT system that turns unit on when a dangerous weather or civil emergencies arises. Features include: Weather test button to ensure the weather alert feature on the radio is functioning properly, auto scan to find an available weather channel and 6 inch telescoping antenna for clear reception no matter where you are. Uses 3 AAA batteries (not included).
  • Pocket Weather Alert Radio
  • All Weather Channel Scan
  • 9 inch Telescopic Antenna
  • Specification Description
    Model HH50, MDLHH50
    UPC 046014741508
    Antenna Type Telescopic
    Benefits Has an alert system that turns on your unit when dangerous weather or civil emergencies ariseWeather test button ensures the weather
    Capacity UOM mAh
    Channel Scan Yes
    Country Of Origin China
    Description Header A pocket-sized forecaster.
    Display Catalog Number 55032248
    End Product Indicator Yes
    Manufacturer Labor Warranty 90
    Manufacturer Part Number HH50
    Manufacturer Parts Warranty 90
    MAP Price 0.0
    Model HH50
    Operating Temperature UOM ° F
    Power Device 3 "AAA" batteries (not included)
    Product Type Weather radios
    Radio System Type Handheld
    Required to function "AAA" batteries
    Required to function SKU 2300877
    Supported Languages English
    Weather Alert Yes
    Midland Radio Corporation HH50 Pocket Weather Alert Radio Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 27, 2009
    Midland Radio Corporation HH50 Pocket Weather Alert Radio Reviews
    Most helpful positive review
    [2 of 2 customers found this review helpful]
    Most helpful negative review
    4.0
    Great All-around Weather Radio
    "A relative received one of these as a Christmas gift. It replaced an old Radio Shack weather radio he had for years. Within a couple of nights, it went off with a severe weather alert. Since my family camps and hikes a lot, it seemed like a great tool to add to our gear. My first use of it came on a day hike. The weather was inclement, but no alerts went off while I was out. It was nice to be able to check..." Read Full Review »
    Jan 23, 2008 by FLA Hiker
    See more positive Midland Radio Corporation HH50 Pocket Weather Alert Radio reviews
    1.0
    A real piece of junk.
    "When I received this it did not work. I sent it to Midland at my cost and they returned it wothout comment. IT STILL DON'T WORK. Junk! Barry Franciscus redtail444[@]..." Read Full Review »
    Oct 27, 2009 by redtail
    See more negative Midland Radio Corporation HH50 Pocket Weather Alert Radio reviews
    Displaying 1 - 5 of 12 Reviews
    Show
    Sort by
    4.0
      Pros
    • Good Sound Quality
    • Great Reception
    • Lightweight
      Cons
    • None
      Best Uses
    • Camping
    • Commuting
    • Daily Use
    • Hiking
    • Home Use
    • More »
    "A relative received one of these as a Christmas gift. It replaced an old Radio Shack weather radio he had for years. Within a couple of nights, it went off with a severe weather alert. Since my family camps and hikes a lot, it seemed like a great tool to add to our gear. My first use of it came …"  Read Full Review »
    Was this Portable Radio review on the Midland Radio Corporation HH50 Pocket Weather Alert Radio helpful to you?
     Report Abuse  (2)  (0)  0 comments
    Jan 23 2008
    FLA Hiker
    Florida
    I am:
    • Frequent Traveler
    Great Value
    5.0
      Pros
    • Compact
    • Great Reception
    • Lightweight
      Cons
    • None
      Best Uses
    • Daily Use
    • Home Use
    • Walking
    "Good reception -- much better than my old weather radio, and this has seven channels vs. my old three. This unit is very compact, and the short antenna is far less trouble than my two previous weather radios. Can be clipped to a belt and still gets good reception when out walking. The unit scans …"  Read Full Review »
    Sep 8 2009
    Midnight Rider
    West Chicago, IL
    I am:
    • Practical
    [4 of 4 customers found this review helpful]
    A great, easy to use product.
    5.0
      Pros
    • Clear Signal
    • Easy To Use
    • Good Audio
    • Lightweight
    • Rugged
      Cons
    • None
      Best Uses
    • Camping
    • Emergencies
    • Hiking
    • Hunting
    "Just turn on and listen. Nothing else to do. "
     Report Abuse  (4)  (0)  0 comments
    Apr 19 2009
    Auction man
    Milledgeville GA.
    I am:
    • Casual Adventurer
    [1 of 1 customers found this review helpful]
    Very light and stay aware
    4.0
      Pros
    • Durable
    • Lightweight
      Cons
    • None
      Best Uses
    • Travel
    "This is a good little emergency radio. It's great for the house in case the power goes out, and because of it's small size it's great on the trail for extended trips. Great to have around for any sudden weather changes. It's just weather and emergency, so if you want to listen to Britney ruining her …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Oct 3 2007
    pfinley
    Los Angeles
    I am:
    • Frequent Traveler
    very pleased, planning on buying more
    4.0
      Pros
    • Clear Signal
    • Easy To Use
    • Lightweight
    • Rugged
    • Weatherproof
      Cons
    • None
      Best Uses
    • Camping
    • Hiking
    • Hunting
    "Everyhting with this product was excellent. Recieved it in a timely manner. Product is excellent. I have no complaints with my product. I am ordering more as Christmas gifts "
    Jun 25 2009
    Harley Man
    Aurora, Illinois
    I am:
    • Avid Adventurer
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
