Microsoft Wireless Laser Mouse 5000
#360
4.0
based on 42 reviews
Ratings Distribution
5 star
55
4 star
60
3 star
18
2 star
7
1 star
8
Category Average
4.3
$26.95 - $36.98
from 16 stores
Pros
  • Glides smoothly (93)
  • Comfortable design (90)
  • Accurate tracking (85)
  • Fast response (79)
  • Works on any surface (67)
  • Great features (55)
  • Easy setup (4)
  • Easy to use (4)
  • Quality construction (3)
  • Didn't work well (1)
See less See more
Cons
  • Limited surface compatibility (10)
  • Uncomfortable design (8)
  • Slow response (6)
  • Inaccurate tracking (5)
  • Inadequate features (5)
  • Poor battery life (3)
  • Magnifier button (2)
  • Catches easily (1)
  • Discontinued (1)
  • Enlarge button misplaced (1)
Best Uses
  • Web browsing (67)
  • Professional (47)
  • Gaming (31)
  • Everyday (27)
  • Graphic design (10)
  • Travel (8)
  • Upgrade (4)
  • Great for editing (1)
  • Occasional (1)
  • Paper weight (1)
Provided by NothingButSoftware
Wireless Laser Technology for Performance and Precision
Experience the enhanced accuracy of a High Definition laser mouse that lets you navigate with total precision. Enjoy ergonomic design that provides comfort in either hand, and take advantage of customizable features, such as the Magnifier button that lets you point and click to enlarge and edit details.
High Definition Laser Technology
Microsoft High Definition Laser Mouse products are more precise, more responsive, and deliver smoother tracking.
Magnifier
Point and click to enlarge and edit details using the Magnifier*.
4-Way Scrolling
Scroll four ways for greater efficiency and comfort with Tilt Wheel Technology.
Comfortable in Either Hand
Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
Wireless Freedom
Give yourself room to move with a wireless mouse and keyboard that lets you work without worrying about tangled wires.
5 Customizable Buttons
Reassign any button to fit your needs. Quick access to the media, programs, and files you use most often.
6+ Months Battery Life
Work with less interruption with longer battery life.
Ergonomic Design
Point and click in comfort - ergonomic design helps you work longer without discomfort.
* Magnifier is not compatible with Direct3D API in full screen mode, media players, OpenGL, and Layered Windows. If you are using Mac OS X, the Magnifier enlarges text and images on the entire screen.
  • Dimensions:  4.82" x 2.89" (L x H)
  • Windows 2000 SP4 or higher, XP, Vista
  • 45 MB free Hard Drive space (100 MB to install)
  • Available USB port
  • CD-ROM drive
  • Mac OS X v10.2.x (excluding Mac OS X v10.0-10.1)
  • 15 MB free Hard drive space (30 MB to install)
  • CD-ROM drive
Specification Description
Model 63A-00001, 63A00001, NP110AA#ABA
UPC 882224109499
Accessory Indicator Yes
Benefits Magnify detail in real time; just point and click to enlarge and edit details* using the MagnifierScroll 4 ways for greater efficienc
Capacity UOM mAh
Country Of Origin China
Description Header Laser-guided precision.
Display Catalog Number 55014979
Manufacturer Labor Warranty 3
Manufacturer Part Number 63A-00001
Manufacturer Parts Warranty 3
MAP Price 0.0
Model 63A-00001
Operating Temperature UOM ° F
Product Disclaimer *The Magnifier is not compatible with Direct3D® API in fullscreen mode, media players, OpenGL and Layered Windows. If you are using Mac OS X, the
Product Type Wireless
Required to function Windows® XP Pro, Pro x64 Edition, Home, Media Center Edition, Tablet PC Edition, Windows 2000Intel® Pentium® 233MHz or hi
Supported Languages English
Microsoft Wireless Laser Mouse 5000 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 15, 2009
Microsoft Wireless Laser Mouse 5000 Reviews
Most helpful positive review
[15 of 17 customers found this review helpful]
Most helpful negative review
4.0
Pros Has magnification ...
"Pros Has magnification window Cons Magnification button easily bumped during mouse usage ,causing window to open.scroll wheel does not have stop click on wheel. mouse transmitter to big for laptop..." Read Full Review »
Apr 10, 2007 by kitlw123
See more positive Microsoft Wireless Laser Mouse 5000 reviews
3.0
If at first you don't succeed.......
"First one had a right button problem. Just a bump or a tap would set off the magnifier and it reacted in a variety of ways before closing. Switched functions with wheel and then the instant viewer would activate for no reason. Talked to Bill's world wide tech somewhere after going through the Phillipines and the reply was, "Dis button is very sensitive." To which I explained, "Even if I bump my keyboard tabl..." Read Full Review »
Nov 28, 2007 by Bryce
See more negative Microsoft Wireless Laser Mouse 5000 reviews
Displaying 1 - 5 of 42 Reviews
Show
Sort by
4.0
"Pros
Cons
Magnification button easily bumped during mouse usage ,causing window to open.scroll wheel does not have stop click on wheel. mouse transmitter to big for laptop "
Was this Computer Mice review on the Microsoft Wireless Laser Mouse 5000 helpful to you?
 Report Abuse  (15)  (2)  0 comments
Apr 10 2007
kitlw123
Carson City,Nevada
Reviewed at:
Price: $29.99
[4 of 4 customers found this review helpful]
Bulky interface
3.0
"Cons
Large remote receiver takes up as much spase as the mouse. This does not have a small self contained USB plug/Receiver, but separate USB plug with cord to large receiver. "
 Report Abuse  (4)  (0)  0 comments
Jan 5 2009
dp501
Ohio
Reviewed at:
Price: $29.99
Not so good
1.0
"Not a good mouse. right out of the packing i had issues. i was going to bring it back but for some stupid reason i did not. the center button was really hard to use i had to press hard to get it to work. the side buttons were great for web browsing. than in like 3 months the right button stopped wor …"  Read Full Review »
Jun 14 2008
fcfu
Johnstown , NY
I've used many mice, ...
2.0
"I've used many mice, often on the drop some random mouse, track ball or laser, at a LAN cafe. Nothing ever felt as awkward as this mouse, it always feels hard to handle and took some time to get used too.
Definitely a bad idea for gaming, given the uncomfortable handling mentioned above, and in RT …"  Read Full Review »
Feb 20 2009
Undisclosed
Microsoft Laser Mouse 5000
5.0
    Pros
  • Accurate Tracking
  • Comfortable Design
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Gaming
  • Professional
  • Web Browsing
"I love my wireless mouse would not be with out it. It does everything as fast or as slow as you want it too. Plus the foward and backward page clicks on the side are very useful. "
Dec 1 2008
ron6740
Hamburg,Pa.
I am:
  • Power user
Reviewed at:
Price: $35.54
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
