Close Login Module
Join
Microsmith Hlp Hot Link Pro Single Box Ir Booster System
#8
4.8
based on 16 reviews
Ratings Distribution
5 star
13
4 star
2
3 star
1
2 star
0
1 star
0
Category Average
4.2
$84.95
from 1 store
More Images
Pros
  • Easy setup (11)
  • Nice features (4)
  • Strong signal (4)
  • Durable (3)
  • Best in its class (1)
  • Ergonomic design (1)
  • Great instructions (1)
  • Highly compatible (1)
  • Works as advertised (1)
See less See more
Cons
  • Better manual (1)
  • Not enough features (1)
  • Not the best wauquos (1)
Best Uses
  • High-end equipment (7)
  • Home (3)
  • Upgrade (3)
  • Cabinet installation (1)
  • Replacement (1)
Where to Buy
$84.95
Product Reviews
Last update: Sep 8, 2009
Microsmith Hlp Hot Link Pro Single Box Ir Booster System Reviews
Most helpful positive review
Most helpful negative review
5.0
Works Great! It solved my problem
"Installed the sensor BEHIND a speaker grill and it works PERFECT! Worked imediately after installation. The Equiptment it controls is behind closed closet doors. I had to run Cat5 cable from the sensor unit to the box that sends signals to wired LEDs that attach to equiptment IR eyes with sticky tape. I had to route CAT5 wire through ceiling/walls and install RJ45 plugs. So, buy the cable length you need with..." Read Full Review »
Aug 31, 2009 by Randy at Infiniti
See more positive Microsmith Hlp Hot Link Pro Single Box Ir Booster System reviews
3.0
Great Product for the price
"This product works Ok foe the price but may wan't to spend more money to get a more reliable product..." Read Full Review »
Dec 13, 2007 by Michael
See more negative Microsmith Hlp Hot Link Pro Single Box Ir Booster System reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Set Up
  • Nice Features
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Replacement
  • Upgrade
The Equiptment it controls is behind closed closet doors. I had to run Cat5 cable from the sensor unit to the box that sends signals to wired LEDs that attach to equiptment IR eyes with stic …"  Read Full Review »
Was this Remote Control review on the Microsmith helpful to you?
Aug 31 2009
Randy at Infiniti
Little Rock, AR
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
Works as advertised with LCD and DLP
5.0
    Pros
  • Easy To Set Up
  • Nice Features
  • Strong Signal
    Cons
  • None
    Best Uses
  • Home
"I have two of these, one with an HighDef LCD, and one with a HighDef DLP. Both work perfectly. The LCD definitely requires you to mount the eye BEHIND the TV but it still works very well. I am running the extension for the eye too, about 25 feet through a wall, and it works perfectly. Way cheaper …"  Read Full Review »
May 1 2007
GMan
Fort Lauderdale FL
I am:
  • Tech Savvy
Reviewed at:
Wow
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Nice Features
    Cons
  • All Pros no Cons
    Best Uses
  • Upgrade
"WOW,Problems I have had with remote controls in the past are all gone, with Link Pro Single Box Ir Booster I like my standard remote controls again. I can point the remote up, down, right or left at 20'and it works... NICE "
May 6 2009
Rob
Irwindale,ca
I am:
  • Gearhead
  • Practical
  • Tech Savvy
Reviewed at:
Minimal but works well
4.0
    Pros
  • Strong Signal
    Cons
  • Not Enough Features
    Best Uses
"Uses a single ribbon cable for all emitters -- so this needs to be split. It could use better glue on the emitters as well. But aside from that, I've been impressed with its functionality and the sensitivity of the receiver. No worries about aiming directly at the window. "
Jan 17 2008
Andy
Arlington, MA
I am:
  • Gearhead
  • Practical
  • Tech Savvy
Reviewed at:
I would buy this product again!
5.0
    Pros
  • Easy To Set Up
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Upgrade
"It works exactly as advertised. Marcus at factory
advised on how to properly extend one emitter lead
by 6'. Also extended receiver "eye" using a
shielded cable fitted with RCA connectors. Hasn't
missed a beat since installation. I have recommend this product to family members. "
Feb 27 2009
Keith
Sammamish, Wa.
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$84.95
Out Of Stock
$66.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
