Metz 58 AF-1N Digial Shoe Mount Flash for Nikon Digital SLR's, with i-TTL, Wireless function & USB Upgradable, Guide Number 190, ISO 100 ft. (MZ58314N)
#195
4.1
based on 16 reviews
from $369.95 - $370.00
Ratings Distribution
5 star
7
4 star
5
3 star
3
2 star
0
1 star
1
Category Average
4.1
Low Price:
$369.95 at B&H Photo Video
 Trusted:
$370.00 at Adorama
Find it at Amazon
Pros
  • Consistent output (5)
  • Easy to use (5)
  • Quality construction (5)
  • Fast recycling (4)
  • Durable (3)
  • Lightweight (3)
  • Auto fp high-speed synchr (1)
  • Best in comparisons (1)
  • Easily interchangeable (1)
  • Flash range (1)
See less See more
Cons
  • Not waterproof (2)
  • Battery hog (1)
  • Heavy / bulky (1)
  • Plastic shoe mount (1)
Best Uses
  • Portraits (6)
  • General purpose (5)
  • Shooting indoors (3)
  • Night photography (2)
  • Shooting outdoors (2)
  • Weddings (2)
  • Flash and fill in (1)
  • General photography (1)
  • Photojournalism (1)
  • Replacement (1)
Provided by B&H Photo Video
The Metz 58 AF-1 TTL Shoe Mount Flash is Metz's shoe mount flash designed to be compatible with all digital cameras both current and future models. To better facilitate compatibility with current and future cameras this flash now features a built-in USB port that allows for future firmware updates via the internet. Designed by one of the leading industrial designers for technical products in Germany this flash is equipped with many innovative developments. State-of-the-art secondary reflector technology high-performance power management newest-generation multi-zone AF metering flash and a full vertical tilt reflector system all mean that this flash is ideal choice for professional photographers.
Specification Description
Model MZ 58314N, MZ58314N
UPC 719821270409
Dedication Nikon
Guide Number ISO 100 Above 150
Metz 58 AF-1N Digial Shoe Mount Flash for Nikon Digital SLR's, with i-TTL, Wireless function & USB Upgradable, Guide Number 190, ISO 100 ft. (MZ58314N) Questions
Questions and Answers
Where to Buy
$369.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$370.00
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Oct 20, 2009
Metz 58 AF-1N Digial Shoe Mount Flash for Nikon Digital SLR's, with i-TTL, Wireless function & USB Upgradable, Guide Number 190, ISO 100 ft. (MZ58314N) Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[1 of 2 customers found this review helpful]
4.0
Plenty of whiz and plenty of bang
"I would probably have given it more stars but I haven't really put it through rigorous testing at this time. That said, WOW, I love this flashgun. After using Nikon branded lights for many years I was a little reluctant to try a different make, but Metz has got it right. Plenty of bang is an understatement, guide no. of 190, beautiful exposures and pleasing color reproduction, the menus are different from wha..." Read Full Review »
Nov 21, 2008 by Joe the Flash
See more positive Metz 58 AF-1N Digial Shoe Mount Flash for Nikon Digital SLR's, with i-TTL, Wireless function & USB Upgradable, Guide Number 190, ISO 100 ft. (MZ58314N) reviews
1.0
An excellent Flash, but?
"Used for weddings, portraits, fill-in and night photography. Having used Metz flashes for many years without any problems, and having done thorough comparisons with SB800 and 900's, I am reluctant to recommend the 58AF-1N shoe mount (used on a Nikon D3)as my 8 week old and lightly used 58AF-1N's flash ready light no longer comes on and no "ready" info is displayed in the camera display. The capacitor is obviuosl..." Read Full Review »
Jul 14, 2009 by Uncle Bern's
See more negative Metz 58 AF-1N Digial Shoe Mount Flash for Nikon Digital SLR's, with i-TTL, Wireless function & USB Upgradable, Guide Number 190, ISO 100 ft. (MZ58314N) reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
4.0
    Pros
  • Consistent Output
  • Durable
  • Easily Interchangeable
  • Easy To Use
  • Fast Recycling
    Cons
  • Heavy
    Best Uses
  • General Use
  • Night Photography
  • Portraits
  • Wedding/Event Photography
"I would probably have given it more stars but I haven't really put it through rigorous testing at this time. That said, WOW, I love this flashgun. After using Nikon branded lights for many years I was a little reluctant to try a different make, but Metz has got it right. Plenty of bang is an unde …"  Read Full Review »
Was this Camcorder Accessory review on the Metz 58 AF-1N Digial Shoe Mount Flash for Nikon Digital SLR's, with i-TTL, Wireless function & USB Upgradable, Guide Number 190, ISO 100 ft. (MZ58314N) helpful to you?
 Report Abuse  (4)  (0)  0 comments
Nov 21 2008
Joe the Flash
Waynesboro, VA
I am:
  • Semi-Professional
Reviewed at:
Price: $369.95
[10 of 11 customers found this review helpful]
Thumbs Up
4.0
    Pros
  • Durable
  • Fast Recycling
  • Lightweight
    Cons
  • None
    Best Uses
  • Flash and fill in
"I've only had limited time with the Metz, but the main reason that I bought it and hope to have it replace my Nikon SB 800 flash is the secondary or wink light. I like that the power to the wink light is adjustable. The unit is light and compact for this type of flash and balances nicely on my D200. …"  Read Full Review »
 Report Abuse  (10)  (1)  0 comments
Jun 15 2008
Brooklyn
Toronto
I am:
  • Semi-Professional
Reviewed at:
Price: $370.00
[6 of 6 customers found this review helpful]
I highly recomment this flash.
5.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • None
    Best Uses
  • Shooting Indoors
  • Shooting Outdoors
"What can I say? It's a Metz. Used to use them as a pro, and they never let me down. Now just an avid hobbyist--works well with my D300 and S3.
Prefer it to my SB-800 as button/menu system seems more intuitive to me. I use the Metz as master and the SB-800 as slave. They work great together. …"  Read Full Review »
 Report Abuse  (6)  (0)  0 comments
Apr 5 2009
Em the Photo Guy
Buffalo, NY
I am:
  • Film Professional
Reviewed at:
Price: $369.95
[12 of 12 customers found this review helpful]
Superior professional flash, but...
4.0
"The secondary fill-in flash of the Metz line makes them worth considering over others. Being able to tilt the main flash headtoward a white wall or ceiling and fill in the subject's eyes with a pleasing catch light(especially at drastic angles) offers the most flattering and effortless on-camera fl …"  Read Full Review »
 Report Abuse  (12)  (0)  0 comments
May 5 2007
Edward Vullo/Foremost Photography
Parma, OH USA
Reviewed at:
Price: $369.95
[8 of 8 customers found this review helpful]
Great results
5.0
    Pros
  • Consistent Output
    Cons
  • None
    Best Uses
  • General Use
  • Portraits
"I purchased this unit for the secondary flash head - very helpful when bouncing. I'm getting great results in both portrait and group settings without additional flash diffusers.
I also bought the Quantum Turbo SC battery pack which greatly improves the recycle time for short bursts.
The Metz …"  Read Full Review »
 Report Abuse  (8)  (0)  0 comments
Mar 3 2008
MarkF
Virginia
I am:
  • Semi-Professional
Reviewed at:
Price: $369.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
