Memorex 20X External Double-Layer DVD Drive with LightScribe™
#14
4.1
based on 18 reviews
from $59.99 - $79.88
Ratings Distribution
5 star
37
4 star
29
3 star
7
2 star
2
1 star
5
Category Average
4.1
Low Price:
$59.99 at ClubMac
$59.99 at OnSale
Find it at Amazon
More Images
Pros
  • Easy setup (52)
  • Fast (46)
  • Quiet (45)
  • Consistent burns (38)
  • Runs cool (32)
  • Easy to install (1)
  • Easy to use (1)
  • Highly compatible (1)
  • Reliable (1)
  • Vista compatible (1)
See less See more
Cons
  • Incompatible with my system (5)
  • Slow (4)
  • Big (1)
  • Broke after 3 weeks (1)
  • Difficult to set up (1)
  • Found nothing wrong (1)
  • Hard to get to work (1)
  • Inconsistent burns (1)
  • Nero causes problems (1)
  • Only burned 20 dvds (1)
Best Uses
  • Video files (30)
  • Back-up (29)
  • Audio files (28)
  • Laptop (21)
  • Upgrade (2)
  • Add files to my computer (1)
  • Burning dvds (1)
  • Copy (1)
  • Copy - can always depend (1)
  • Dvd program (1)
Provided by MAGo Enterprise
20X LightScribe DVD Recorder External - Memorex adds to its family of award-winning optical drives and continues to offer consumers the latest in DVD recording technology with the introduction of the Memorex 20X Double-Layer Multi Format DVD Recorders with LightScribe Direct Disc Labeling available in both external and internal models. Multi format capability takes the guesswork out of choosing the right discs; and the double-layer feature allows for the creation of DVD+R9 and DVD-R9 commercial quality DVDs with up to 8.5GB of data storage on one disc. List of features for 20X Recorders: Record a full DVD disc in less than 7 minutes* LightScribe version 1.2 enabled Double-layer DVD+R9 and DVD-R9 compatible Custom Nero Memorex software suite included Built-in flash-ROM for online upgradability Built-in buffer underrun protection Stylish silver and black design External version includes vertical stand *Actual recording times may vary depending on many variables such as file types lead-in/lead-out times finalizations and connections.
Specification Description
Model 03223-, 3202-3223, 32023223
UPC 034707032231
Computer Compatibility PC
Connection External
Drive Capacity Limited to Capacity of Disc
Drive Speed 20x 8x 16x DVD+RW
Port Compatibility USB
Product Type DVD-Writer (Double-layer) - DVD-RAM/±R/±RW
Type of Drive DVD Writer Drive
Memorex 20X External Double-Layer DVD Drive with LightScribe™ Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 14, 2009
Memorex 20X External Double-Layer DVD Drive with LightScribe™ Reviews
Most helpful positive review
[8 of 8 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
Competent Performer
"This unit required some Registry adjustments in order for Windows XP and LightScribe to consistently recognize the drive. The correct actions were provided in the LightScribe FAQs. A very minor note: For some reason Memorex has supplied a front power-on light that amounts to a bright blue headlight shining in my workspace. You may wish to find a way to keep the glare from your eyes by pointing it away from y..." Read Full Review »
Jun 20, 2008 by -
See more positive Memorex 20X External Double-Layer DVD Drive with LightScribe™ reviews
1.0
THIS PRODUCT CAUSED A DISASTER!
"I bought this unit to add a DVD burner to my Acer laptap. I read the instructions which told me to uninstall Roxio if I had used it. As instructed, I removed Roxio from my Acer. I installed the drivers for the Memorex and then tried to re-boot the Acer as I was told to do. I WAS NEVER ABLE TO REBOOT THE ACER! I called Memorex and was told this was a "known issue"!!! I had to reformat the "C" drive on my Acer a..." Read Full Review »
Nov 05, 2009 by RPESQ
See more negative Memorex 20X External Double-Layer DVD Drive with LightScribe™ reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
The software doesn't work ...
3.0
"The software doesn't work with the product for Vista. I totally removed the software, after getting the key #, and then downloaded the update software, and installed that, using the key # from the original software. The unit worked after that, just fine. However, for $40 less than I paid for the …"  Read Full Review »
Was this External Computer DVD Burner review on the Memorex 20X External Double-Layer DVD Drive with LightScribe™ helpful to you?
Mar 15 2009
issachar5
Undisclosed
Reviewed at:
I borrowed one of these ...
5.0
"I borrowed one of these from a friend because my inboard burner died. It worked well. I needed a replacement of my own. My friend recommended the Memorex. I found several good reviews online and the price is very reasonable. Good job Memorex. The rest is history. I can't comment on the included Nero …"  Read Full Review »
Jul 2 2009
McKeever
Undisclosed
Reviewed at:
I have been two years now ...
5.0
"I have been two years now and more with this burner. Its very good have burned more than 200 cds, more than 100 dvds and like 20 Dual Layer DVDs. I cant complain. I have never used the software that came with the drive, except NERO for burning music cds. All of the other projects where done using I …"  Read Full Review »
Jun 7 2009
DaveRob
Undisclosed
Reviewed at:
I have owner a memorex ...
3.0
"I have owner a memorex 16x dvd burn for years nows. I am buying a new one because after 6 yrs using my old one 2 -3 times a day it, no longer works. I think the problem with burn failures is more of a software issue, I run Nero software and have seen the message pop up from time to time. it is a h …"  Read Full Review »
Mar 12 2009
Undisclosed
Reviewed at:
So far so good. Has ...
4.0
"So far so good. Has issues with not getting the right software. Had to send back, when I got the second one, had the software but if was for a CD burner and was dated in '07. After getting the right drivers, and getting the lightscribe drivers off the internet, it's working great, 7 full DVD's and l …"  Read Full Review »
Mar 18 2009
ljenkins
Undisclosed
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
