Maylong 4.3-inch FD-420 Text-to-Speech GPS Navigation For Dummies 1ea.
#74
4.0
based on 29 reviews
from $89.99
Ratings Distribution
5 star
13
4 star
11
3 star
1
2 star
1
1 star
3
Category Average
4.1
$89.99 at Walgreens
Find it at Amazon
Find it at Ebay
Pros
  • Easy to read (26)
  • Simple controls (25)
  • Compact (24)
  • Easy setup (24)
  • Large clear lcd (23)
  • Acquires satellites quickly (22)
  • Easy menus (22)
  • Reliable (22)
  • Affordable (1)
  • Fast gps acquisition (1)
See less See more
Cons
  • Poor battery life (5)
  • Acquires satellites slowly (2)
  • Inaccurate (2)
  • Flimsy mounting (1)
  • Not good routing (1)
  • Shortest route calc ng (1)
Best Uses
  • Finding specific address (20)
  • Planning trips (17)
  • Rural navigation (13)
  • Urban navigation (12)
  • Faster routes (11)
  • Geocaching (5)
  • Travel (2)
  • Auto (1)
Provided by Walgreens
FEATURES For Dummies GPS Nav™ software with familiar, For Dummies style user interface for simplifying the GPS navigation operation 4.3"" widescreen LCD color touch-screen with 480x272 pixels resolution Digital mapping with browsing capability Voice and visual turn-by-turn navigation speaking the actual street names (TTS) Pre-loaded continental U.S. maps 1.7 million points of interest (POI) Included applications for playing digital music and viewing digital picture The familiar, easy-to-use For Dummies™ style, complete with icons, leads you through the user interface and instruction guide PACKAGE CONTENTS 4.3"" GPS device with pre-loaded maps In-vehicle charger Vehicle suction cup mount Mini USB cable User's manual SPECIFICATIONS Dimensions (W x H x D): 4.8"" X 3.2"" X 0.8"" Display resolution (W x H): 480 x 272 pixels Weight: 8 oz (226.8g) Map: Pre-loaded maps GPS receiver: quick location fix GPS receiver Supported data card: SD card up to 2GB USB: support plug & play PC connection and device charging Speaker: Built-in loud speaker Headphone: 3.5mm jack Battery Type: Rechargeable Li-Ion battery In-vehicle Charger: Input: 12VDC, Output: 5V, 1.5A Home AC adapter: Input: 120VAC, Output: 5V, 1.5A (not included)
Maylong 4.3-inch FD-420 Text-to-Speech GPS Navigation For Dummies 1ea. Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 12, 2009
Maylong 4.3-inch FD-420 Text-to-Speech GPS Navigation For Dummies 1ea. Reviews
Most helpful positive review
[13 of 16 customers found this review helpful]
Most helpful negative review
[7 of 12 customers found this review helpful]
4.0
Mostly Great!
"1. Fast acqusition of Satellite signal. 2. Tricks in using menus/buttons easily learned. 3. Shortest route option routes thru city 15 mph neighborhoods rather than main streets. 4. Browse for POI doesn't ID as behind you. 5. Sleep option turns off glaring display at night but maintains route info. for quick turnon. 6. Needs option to display map of next 10-25 mile segment or more of surrounding neighborhood...." Read Full Review »
Dec 07, 2008 by Hot Rod
See more positive Maylong 4.3-inch FD-420 Text-to-Speech GPS Navigation For Dummies 1ea. reviews
2.0
Beats nothing
"I bought it for my mother-in-law to find her way. The route I chose to test came up with a route that was far from the most direct or convienient. I loved that if you missed or ignored a direction it would immediately provide another way to get thier...." Read Full Review »
Jul 13, 2009 by RVguy
See more negative Maylong 4.3-inch FD-420 Text-to-Speech GPS Navigation For Dummies 1ea. reviews
Displaying 1 - 5 of 29 Reviews
Show
Sort by
[20 of 32 customers found this review helpful]
Good Entry Level Value
4.0
    Pros
  • Easy To Read
  • Easy To Set Up
  • Long Battery Life
  • Reliable Performance
  • Simple Controls
    Cons
  • None
    Best Uses
  • Travel
"Using "fastest" directions are pretty straight forward, and match my personal preferences around town. When I take different path, this unit will recalculate with out telling me to "Turn Around" like other models I've used. Easy to view, but you must leave the GPS program to set the screen brightn …"  Read Full Review »
Was this Car GPS review on the Maylong 4.3-inch FD-420 Text-to-Speech GPS Navigation For Dummies 1ea. helpful to you?
 Report Abuse  (20)  (12)  0 comments
Nov 23 2008
Ben
Detroit, MI
I am:
  • Power User
Mostly Great!
4.0
    Pros
  • Compact
  • Easy To Read
  • Easy To Set Up
  • Fast GPS acquisition
  • Missed turn reroute
  • More »
    Cons
  • Shortest Route Calc NG
    Best Uses
  • Auto
  • Travel
5. Sleep option turns off glaring display at night but maintains route inf …"  Read Full Review »
 Report Abuse  (13)  (3)  0 comments
Dec 7 2008
Hot Rod
Lincoln, NE
I am:
  • Enthusiast
[5 of 5 customers found this review helpful]
It is very easy for beginners to learn.
4.0
    Pros
  • Acquires Satellites Quickly
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Finding Specific Address
  • Planning Trips
"My husband and I bought this for a trip to AZ to look at retirement properties. From Laughlin to Lake Havasau to Phoenix in 5 days. It always directed us to our desination without any problems. "
 Report Abuse  (5)  (0)  0 comments
Feb 17 2009
Looking to retire
Cottage Grove, MN
I am:
  • Casual User
Great budget priced GPS
5.0
    Pros
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • Large Screen
  • More »
    Cons
  • None
    Best Uses
  • Rural Navigation
"I decided to take a chance on this GPS because of the reviews it received. Works great, has been very accurate and for my needs, has all the features I was looking for including text-to speech. Best [$]dollars I,ve ever spent. "
Nov 9 2009
bugsj
Plain, Wi
I am:
  • Casual User
[4 of 4 customers found this review helpful]
SILLY NAME HOWEVER, GOOD PRODUCT
4.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Faster Routes
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"i PREPROGRAMMED MY SONS CURRENT BASEBALL TRIP FOR NEXT WEEK INCLUDING HOTELS BASEBALL FIELD COLLEGESETC...VERY NICE FEATURE!!!
LOVED IT
PS LETS SEE HOW IT WORKS NEXT WEEK THOUGH IT HASNT LET ME DONW YET "
 Report Abuse  (4)  (0)  0 comments
Feb 24 2009
JOHNNY H
ELMHURST, IL
I am:
  • Enthusiast
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
