Marantz SR6003 7.1-Channel Home Theater Receiver
#254
4.3
based on 12 reviews
from $779.99 - $798.98
Ratings Distribution
5 star
7
4 star
4
3 star
0
2 star
0
1 star
1
Category Average
4.3
Low Price:
$779.99 at Abes of Maine
 Trusted:
$798.98 at OneCall
Find it at Amazon
More Images
Pros
  • Great sound quality (12)
  • Good power output (11)
  • Accurate controls (10)
  • Easy setup (7)
  • Durable (5)
See less See more
Cons
  • Difficult to set up (2)
  • Confusing / bad remote control (1)
  • Runs hot (1)
Best Uses
  • Home theater (11)
  • Basic systems (4)
  • Large rooms (4)
  • Audiophiles (3)
  • Pro audio / dj / mixing (1)
  • Smaller rooms / apartments (1)
Provided by OneCall
With most endeavors, it’s the devilish details that distinguish the great from the also-rans. And the Marantz SR6003 surround sound A/V receiver definitely ranks as one of the greats.
You’ll see this immediately in the elegantly simple front panel where aluminum extrusions and glass-reinforced resin meld their respective qualities to shield internal circuitry while absorbing extraneous resonances. Only three controls interrupt the smooth three-dimensional flow – power/standby, input selection, and volume. A drop-down door hides secondary controls until you need them. The result is another visual milestone in the Marantz pantheon of superb industrial designs.
A high-density fluorescent front panel display gives you all the feedback you need to set up and operate your SR6003. In addition, a color GUI (graphical user interface) appears on your TV to help make system setup simple and error-free.
Befitting Marantz’s engineering heritage, the SR6003’s circuits derive operating current from a high capacity linear power supply built around an oversize EI-core transformer and Marantz-custom storage capacitors.
The seven channel in-line amplifier array keep high voltages isolated from low-level circuitry for cleaner sound. Each channel produces up to 100 continuous watts for exacting control of difficult speakers. A finned continuous aluminum heat sink keeps power transistors well within their SAO (safe area of operation) even under high-drive conditions.
The balance of the SR603’s audio circuitry sits on a separate circuit board to prevent contamination by video or control signals. As an example of the dedication Marantz engineers devote to continuous refinement, we’ve relegated digital and analog segments to their own section of the audio board.
You’ll enjoy the latest high bit-rate audio formats such as Dolby TrueHD, DTS-HD in both High Resolution and Master Audio implementations, as well as DSD (the data structure behind the SA-CD) and legacy formats such as Dolby Digital, etc. thanks to an advanced Texas Instruments microprocessor.
The SR6003 lets you get the most out of these sources regardless of your home theater room by including Audyssey’s remarkable MultEQ system. After “listening” to test tones sent to all your speakers, it provides a virtually perfect acoustical environment for up to six individual seats. In addition, MultEQ detects speaker wiring errors resulting in “out of phase” performance losses, automatically configures bass management for ideal integration of subwoofers and full range speakers, and calculates proper delays and speaker levels to produce the best possible surround soundfield.
Marantz’s proprietary M-DAX (Marantz Dynamic Audio eXpander) makes even compressed audio signals (MP3 files, AM/FM broadcasts, etc.) sound closer to CDs than you ever thought possible. As it dynamically analyzes a compressed signal, MDAX recreates the missing high frequency spectrum for your enhanced enjoyment.
You‘ll probably appreciate MDAX most when you take advantage of the SR6003’s front panel USB input. Not only will you have easy access to your favorite playlists, but they’ll sound better, too!
Video performance? It’s every bit equal to the SR6003’s audio circuitry. Three HDMI inputs, all version 1.3 capable, and two HDMI outputs help you connect your high definition TVs to the newest source components. The SR6003’s wide-bandwidth HDMI circuitry is ready to bring you advances like Deep Color and xvYCC Color Space for visual reality that exceeds your expectations. Need more HDMI inputs? Just add a Marantz VS3002 for up to eight HDMI sources.
For older but still valued analog video sources, the SR6003 includes extensive video format conversion and scaling capabilities thanks to the new i-Chips Technology video signal converter. This remarkable VSC accepts any video signal from 480i to 1080i and upscales it to the resolution of your choice. It even provides HDMI output for lower-resolution signals. So you’ll even be able to convert 480i images to full 1080p format and view your videotapes through the HDMI link to your high definition TV. How’s that for maximum enjoyment?
You’ll also find dual component video outputs for additional TVs either in the same room or in different areas of your home. These complement analog and digital Zone 2 audio outputs, making the SR6003 an ideal starting point for a whole-house entertainment system.
The SR6003 provides inputs for either XM or Sirius adaptor so you can enjoy your choice of satellite programming. (Yes, you’ll need a subscription to the service of your choice.)
Other conveniences include an updated backlit remote controller, the ability to lock out front panel controls so your favorite settings can’t be disturbed by accident, and a shorter chassis that fits easily in a rack or on a shelf. A variety of system integration options (RS-232 communications port, DC trigger output, and a flasher input) let you enjoy your SR6003 in any system from a simple one-room theater to the most complex multi-zone entertainment system.
Although its capabilities are superb, please remember that each feature in the SR6003 wasn’t included just for the sake of “bragging rights”. Instead, Marantz engineers carefully examined each circuit and operational aspect to assure both superb performance and easy access.
No, we didn’t design the SR6003 for spec sheets. We designed it to bring you the quality you deserve. That’s what has made Marantz a premier home entertainment icon for almost six decades. And it’s what you can put your trust in today.
Specification Description
Model SR6003
UPC 699927250751
AC Outlets (1) Switched
AC Outlets (1) Unswitched
Analog Audio (1) Front Input
Analog Audio (4) Rear Output
Analog Audio (6) Rear Input
Analog Audio / Video (1) Front Input
Analog Audio / Video (2) Rear Output
Analog Audio / Video (4) Rear Input
Color Black
Component Video (2) Rear Output
Component Video (3) Rear Input
D/A Converter 192kHz / 24-bit
HDMI (2) Rear Output
HDMI (3) Rear Input
HDMI Version 1.3
Headphone Jack Front Output
Multi-Channel 7.1 Channel Input
Multi-Channel 7.1 Channel Pre-Out
Multi-Room Rear Output
Optical (1) Front Input
Optical (1) Rear Output
Optical (3) Rear Input
Remote Control Backlit
Remote Control Included
Remote Control Learning
S-Video (1) Front Input
S-Video (2) Rear Output
S-Video (4) Rear Input
Satellite Radio Sirius Satellite Radio Ready
Satellite Radio XM Radio Ready
Speaker Switching A/B
Speaker Terminals 5-Way Binding Post
Surround Power Rating 100 Watts x 7
Tuner AM
Tuner FM
Tuner Sirius Satellite Radio Ready
Tuner XM Radio Ready
USB Port Front Input
Marantz SR6003 7.1-Channel Home Theater Receiver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Marantz SR6003 7.1-Channel Home Theater Receiver Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
No Buyers remorse here
"Its a great product don't hesitate to buy it, the sound quality is superb it is a very natural sounding amp not to bright not colored plus D&M is the holding company which stands for Denon and Marantz as far as I am concerned these are 2 of the best av receiver manufacturers on the market. Denon being more feature rich. Marantz being more musical ( I am coming from a Harmon Kardon). The only thing negative I ha..." Read Full Review »
Nov 09, 2009 by XmasterB
See more positive Marantz SR6003 7.1-Channel Home Theater Receiver reviews
1.0
So far product a nightmare
"Be careful of your components they do not all work together. Something they do not warn you about...." Read Full Review »
Apr 25, 2009 by Gooda
See more negative Marantz SR6003 7.1-Channel Home Theater Receiver reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
  • Larger Rooms
"Its a great product don't hesitate to buy it, the sound quality is superb it is a very natural sounding amp not to bright not colored plus D&M is the holding company which stands for Denon and Marantz as far as I am concerned these are 2 of the best av receiver manufacturers on the market. Denon be …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Marantz SR6003 7.1-Channel Home Theater Receiver helpful to you?
Nov 9 2009
XmasterB
Atlanta, GA
I am:
  • Audiophile
Reviewed at:
Price: $798.98
High End Performance at reasonable price
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
  • Larger Rooms
  • Music Reproduction
  • Smaller Rooms
"This is a High End receiver at an extremely reasonable price. You would have to pay [$] more for a 1% increase in overall sound and theatre quality. I had this setup in 10 minutes and could not believe the difference in sound from my old Onkyo receiver. The picture on my big screen TV was enhanced a …"  Read Full Review »
Oct 13 2009
Sences hightened
Buffalo NY
I am:
  • Audiophile
  • Movie Enthusiast
  • Technically Challenged
Reviewed at:
Price: $798.98
Awesome Upgrade
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Larger Rooms
"I upgraded from an older receiver and was skeptical of the difference it would make. Once I hooked it up to my setup I was amazed at how clean and clear the sounds that were being reproduced. It powers my speakers way better than my old receiver even though the RMS was lower on the Marantz. Music is …"  Read Full Review »
Aug 3 2009
Bryan
Seattle, WA
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $798.98
A great Audio/Video value
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Home Theater
  • Larger Rooms
"The Marantz SR6003 is a well designed A/V receiver. The 3 year warranty is above what the competition offers. The One Call timely discounts (keep an eye for them) makes this a excellent buy. I'm thrilled with the audio quality of this receiver, being an 80% Audio/20% Video afficionado. [...]Thank yo …"  Read Full Review »
Aug 1 2009
David
Nipomo, Ca.
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Price: $798.98
[1 of 1 customers found this review helpful]
Beautiful high end look - great power
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • It puts off a lot of heat
    Best Uses
  • Home Theater
"As the main component in an octagan shape home theater room this product rocks with clean and accurate sound. "
 Report Abuse  (1)  (0)  0 comments
Oct 19 2009
Trademark
Las Vegas, NV
I am:
  • Audiophile
  • Movie Enthusiast
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $798.98
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
