Marantz SR4003 7.1-Channel Home Theater Receiver
3.0
based on 2 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.3
Pros
  • Easy setup (2)
  • Good power (2)
  • Accurate controls (1)
  • Clean sound (1)
  • Durable (1)
See less See more
Cons
  • Popping noises (1)
Best Uses
  • Ak-47 target (1)
  • Boat anchor (1)
  • Doorstop (1)
  • Home theater (1)
  • Larger rooms (1)
Provided by OneCall
It’s relatively easy to find a low powered or feature-short receiver in our competitors’ product lines. But that’s a concept we simply don’t believe in at Marantz. Instead, our SR4003 offers a full 80 watts/channel across the full audio spectrum into 8 ohm loads with less than 0.08 Total Harmonic Distortion. That‘s "separate component" performance territory! We get there with a power supply specifically developed to deliver high instantaneous current when signals get really demanding. The high capacity, low-loss EI core transformer feeds a capacitor array rated at over 16,000 µfarads so the amplifier section never ends up gasping for breath. You might – but that’s because the performance is so outstanding.
All seven amplifier channels mount on an in-line array for even heat dissipation. And their voltage feedback configuration takes full advantage of the audiophile-grade parts selected only after exhaustive auditory evaluation. And there’s a separate circuit board exclusively for audio to minimize potential interference from video signals.
As you’ve already guessed, the SR4003 handles all of today’s most popular digital audio formats thanks to an advanced Cirrus Logic microprocessor that puts you at the head of the pack in enjoying the best A/V sound ever.
The SR4003 even makes getting a pristine audio signal from your system to your ears a simple process, thanks to MRAC or Marantz Room Acoustic Calibration. Using internally generated test signals and proprietary algorithms, MRAC analyzes the acoustic qualities of your room and automatically determines your speaker configuration and capabilities, adjusts channel levels and delay settings, and corrects for virtually all room anomalies.
Other A/V features? The SR4003 boasts three HDMI inputs with "repeating" capability. This allows full audio processing within the receiver itself so your enjoyment isn’t limited to the capabilities of the source component you may be using at the time.
And if three HDMI inputs aren’t enough, just connect a Marantz VS3002 and enjoy up to eight HDMI sources with single-unit convenience.
For analog-based formats like composite, S-, and component video, the SR4003 provides flexible conversion from S-video to either composite or component format. And the new integrated front panel input terminals make connecting a temporary video source plug-n-play easy.
Want to listen to a favorite audio source in another area of your home? Just use the Zone 2 speaker outputs and you’re ready for some remote relaxation.
Want to be ready for late night listening? Dolby Headphone lets you enjoy a surround experience in private so you can listen as loudly as you want without waking your neighbor. Or the baby.
Speaking of younger – or less technically sophisticated – family members, the SR4003 lets you lock out the front panel controls so another person can’t accidentally change your favorite settings. That’s quite a blessing if your home echoes to beat of many different footsteps.
Don’t forget the new shallower chassis either. It lets you place the SR4003 in racks where other components have a hard time fitting in. And the chassis leaves plenty of room for the cable connections that tie everything together.
Reduced depth isn’t the only chassis innovation you’ll enjoy. The front panel benefits from both aluminum and vibration-absorbing glass fiber-reinforced resin. Not only does this combination allow sophisticated cosmetic design, it also damps both internal and external resonance so you’re A/V receiver operates in an ideal environment.
The SR4003 brings other niceties, too. The infrared flasher input lets it play nicely with other components in your system. And the backlit remote controller lets you see what key you’re about to press. It easily learns those other commands so it can converse intelligently with all the electronic citizens in your home entertainment world.
In fact, everything you really need for a great system is in the SR4003, including a redesigned ergonomically friendly remote control.
Specification Description
Model SR4003/U1B
UPC 699927221256
AC Outlets (1) Switched
Analog Audio (3) Rear Output
Analog Audio (6) Rear Input
Analog Audio / Video (1) Rear Output
Analog Audio / Video (3) Rear Input
Color Black
Component Video Rear In/Out
D/A Converter 192kHz / 24-bit
Depth (Inches) 15.1
HDMI (1) Rear Output
HDMI (3) Rear Input
Headphone Jack Front Output
Height (Inches) 6.3
Multi-Channel 7.1 Channel Input
Multi-Channel 7.1 Channel Pre-Out
Optical (1) Rear Output
Optical (2) Rear Input
Remote Control Learning
Remote Control Pre-Programmed
S-Video (2) Rear Output
S-Video (4) Rear Input
Speaker Terminals 5-Way Binding Post
Surround Power Rating (watts) 80
Tuner AM
Tuner FM
Weight (Pounds) 25.6
Width (Inches) 17.3
Marantz SR4003 7.1-Channel Home Theater Receiver Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: SR4003 7.1-Channel Home Theater Receiver
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 3, 2009
Marantz SR4003 7.1-Channel Home Theater Receiver Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[0 of 1 customers found this review helpful]
Beware
1.0
    Pros
  • Easy To Set Up
  • Good Power
    Cons
  • Popping noises
    Best Uses
  • AK-47 target
  • Boat Anchor
  • Doorstop
"This applies to the SR-4002, so keep that in mind. Hopefully the 4003 doesn't have the same issues.I've owned the 4002 for about 8 months. In the last 2 months, it's begun to make a popping sound when muting and unmuting, and also sometimes between chapters during a DVD (not skipping chapters, just …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Marantz SR4003 7.1-Channel Home Theater Receiver helpful to you?
 Report Abuse  (0)  (1)  0 comments
Jul 9 2009
That guy
Somewhere, USA
I am:
  • Audiophile
Reviewed at:
Great system
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
  • Larger Rooms
"Thank you for great loud system. "
Aug 3 2009
Takedat
Bronx
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
