Marantz AV8003 Networking A/V Preamp/Processor
#76
4.6
based on 5 reviews
from $2,599.00
Ratings Distribution
5 star
3
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.3
$2,599.00 at OneCall
Find it at Amazon
Find it at Ebay
Pros
  • Great sound quality (5)
  • Accurate controls (4)
  • Durable (4)
  • Easy setup (3)
See less See more
Cons
  • Confusing / bad remote control (1)
  • Limited functions (1)
  • Needs multiple audyssey (1)
  • Poor instructions / manual (1)
Best Uses
  • Home theater (5)
  • Audiophiles (4)
  • Large rooms (2)
  • Smaller rooms / apartments (1)
Provided by OneCall
Equipped with all of the latest high resolution audio formats, the AV8003 is the perfect centerpiece for the ultimate home theater system. Featuring 7.1 channel Dolby TrueHD and DTS-HD Master Audio decoding, the AV8003 is also THX Ultra2 certified, with additional THX surround sound post-processing functions. Able to handle a variety of input sources and formats, the AV8003 features a quartet of latest specification v1.3a HDMI inputs, which provide high resolution audio format compatibility as well as supporting Deep Color and xvYCC extended video formats, for the ultimate picture and sound quality with high definition sources such as Blu-Ray.
For whole home entertainment, the AV8003 features three zone A/V signal distribution, including high definition video via HDMI for the main zone, component video to the second zone, with third zone independent audio program capability. The AV8003 also features a built-in video processor that provides de-interlacing and up-conversion to 1080P. Multiple power supplies and extensive internal shielding, along with a full copper-plated chassis provide maximum audio and video signal integrity. A build in digital media player makes it easy to stream Audio, Video and Photos from your PC or NAS device to your theater. Combined with the companion MM8003 8 channel power amplifier, the AV8003 delivers nothing less than the ultimate home theater viewing and listening experience.
Specification Description
Model AV8003
UPC 699927101350
Analog Audio (4) Rear Output
Analog Audio (7) Rear Input
Audio D/A Converter 24-bit/192kHz
Component Video (2) Rear Output
Component Video (4) Rear Input
Depth (Inches) 15.2
DTS(R) Yes
HD Radio Yes
HDMI (2) Rear Output
HDMI (4) Rear Input
Headphone Jack Front Output
Height (Inches) 7.3
Multi-Channel 7.1 Channel Input
Multi-Room/Multi-Source Yes
On Screen Display Yes
Optical (1) Rear Output
Optical (3) Rear Input
Preamplifier Outputs (2) 7.1 Channels
RJ45 Ethernet Yes
RS-232C Yes
S-Video (4) Rear Input
S-Video (4) Rear Output
Surround Modes Circle Surround II
Surround Modes DTS
Surround Modes DTS ES
Surround Modes DTS ES Discrete 6.1
Surround Modes DTS ES Matrix 6.1
Surround Modes DTS NEO:6
Surround Modes Dolby Digital EX
Surround Modes Dolby Pro Logic IIx
Surround Modes THX
Tuner AM
Tuner FM
Tuner HD
Tuner Sirius Satellite Radio Ready
Tuner XM Radio Ready
Weight (Pounds) 25.6
Width (Inches) 17.3
XLR Rear Input
Marantz AV8003 Networking A/V Preamp/Processor Questions
Questions and Answers
Where to Buy
$2,599.00
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Aug 24, 2009
Marantz AV8003 Networking A/V Preamp/Processor Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Excellent Surround Processor
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
    Cons
  • None
    Best Uses
  • Audiophiles
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"I have used the integra 9.8 for the past year. The integra is an excellent pre-pro but the marantz ups it by a point. The marantz does not have as many bells and whistles but the quality of the sound makes up for it. Excellent separation and clearly defined sound for both music and movies. The instr …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Marantz AV8003 Networking A/V Preamp/Processor helpful to you?
 Report Abuse  (2)  (0)  0 comments
Sep 5 2008
Blissful
Utah
I am:
  • Audiophile
  • Musically Inclined
  • Practical
Reviewed at:
Price: $2,599.00
[0 of 1 customers found this review helpful]
Great sound with limitless expansion
4.0
    Pros
  • Clean Sound
    Cons
  • Manual needs improvement
  • Needs multiple Audyssey
    Best Uses
  • Audiophiles
  • Home Theater
"I am using the AV8003 in a home theater setup with Sunfire Amplifier and Martin Logan Request, Aerius Surround, and Logos Center channel. Their is great acommodation for Balanced connections and a clean sound. Figuring out all of the Surround modes is somewhat challenging. Would like a simple w …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Jan 30 2009
Daiku
Silicon Valley
I am:
  • Audiophile
Reviewed at:
Price: $2,599.00
[1 of 2 customers found this review helpful]
Excellent
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Audiophiles
  • Home Theater
  • Larger Rooms
"Perfect for home theater and basic music use. I am using the unit with the older Marantz 5 Channel AMP right now and the sound is amazingly clean and transparent. It processes all the latest Hi-Def formats with ease and accuracy. The features on this unit are endless. This is a high end unit wor …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Dec 8 2008
crazyj
houston, tx
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $2,599.00
Sound Quality is awesome!
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
    Cons
  • Limited Functions
  • Remote can be better
    Best Uses
  • Home Theater
"2 channel audio is excellent, Surround sound with the new format is just great.Video processing is so-so for the price,Audissey EQ a plus but needs to run decoded PCM from BR player to engage. "
Aug 24 2009
Mike
San Diego,Ca.
I am:
  • Audiophile
  • Movie Enthusiast
  • Practical
Reviewed at:
Price: $2,599.00
[1 of 1 customers found this review helpful]
Terrible Remote
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Audiophiles
  • Home Theater
"The AV8003 is a fine product. The remote is the problem with this system. It is difficult to set up and operate. "
 Report Abuse  (1)  (0)  0 comments
Mar 31 2009
Dave
Dallas Texas
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $2,599.00
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
