Manfrotto - Spring Grip Clamp with Attached Flash Shoe.
#324
4.8
based on 16 reviews
Ratings Distribution
5 star
14
4 star
1
3 star
1
2 star
0
1 star
0
Category Average
4.2
$54.90 at Adorama
Find it at Amazon
Find it at Ebay
$54.90
from 1 store
Pros
  • Durable (12)
  • Lightweight (11)
  • Reliable (11)
  • Easy to use (9)
  • Versatile (3)
  • Consistent (2)
  • Easy setup (2)
  • Easily adjusted (1)
  • Locks in tight (1)
  • Portable (1)
See less See more
Cons
  • Pricey (2)
  • Difficult to use (1)
  • Heavy / bulky (1)
Best Uses
  • Everyday (9)
  • Portraits (8)
  • Studio (5)
  • Travel (5)
  • Home (4)
  • General purpose (2)
  • Macro (2)
  • Photography (2)
  • Strobe lighting (2)
  • Weddings (2)
Provided by Buzzillions.com
An additional version of the classic Clip Clamp. This Clamp has a positionable miniature ball head with a plastic flash shoe attachment to allow it to clip and position a flash unit wherever it is needed without shorting out the flash. Flexible in...
Specification Description
Model 175F
UPC 719821240341
Select Grips/Clamps/Hangers
Manfrotto - Spring Grip Clamp with Attached Flash Shoe. Questions
Questions and Answers
Where to Buy
$54.90
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Sep 4, 2009
Manfrotto - Spring Grip Clamp with Attached Flash Shoe. Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Freedom!!!!
"This will be the best [$] you'll ever spend on lighting equipment! It will absolutely FREE your thinking about small flash, off camera lighting. All of a sudden your lighting choices will mulitply anywhere you go. Also, sign up for [@]--The Best, most Inspiring, most Informative website/blog devoted to small, off camera strobe lighting on the web.And of course, it's made by Manfrotto which means it is a soli..." Read Full Review »
Dec 31, 2008 by Doug Baz
See more positive Manfrotto - Spring Grip Clamp with Attached Flash Shoe. reviews
3.0
Nikon SB 900 is a tight fit
"The Nikon SB 900 does not fit comfortably on the cold shoe of the 175f. I think it's going to break the housing when I try to "jam" the flash on to it...." Read Full Review »
Sep 02, 2009 by Bird
See more negative Manfrotto - Spring Grip Clamp with Attached Flash Shoe. reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
Freedom!!!!
5.0
    Pros
  • Consistent
  • Easy Setup
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Artificial Lighting
  • Photography
  • Strobe Lighting
  • Weddings
"This will be the best [$] you'll ever spend on lighting equipment! It will absolutely FREE your thinking about small flash, off camera lighting. All of a sudden your lighting choices will mulitply anywhere you go. Also, sign up for [@]--The Best, most Inspiring, most Informative website/blog dev …"  Read Full Review »
Was this Camera Accessory review on the Manfrotto - Spring Grip Clamp with Attached Flash Shoe. helpful to you?
 Report Abuse  (2)  (0)  0 comments
Dec 31 2008
Doug Baz
Barrytown, NY
I am:
  • Pro Photographer
Reviewed at:
Price: $54.90
A Must Have Item
5.0
    Pros
  • Easily Adjusted
  • Lightweight
  • Locks In Tight
  • Rugged
  • Smooth Movement
    Cons
  • None
    Best Uses
  • Home
  • Office
  • Professional Work
  • Special Events
  • Sports
  • More »
"This is one the best things I have ever purchased! I take these clamps everywhere I go, weddings, sports, outdoors, I mean everywhere. Very solid build, very handy, compact, yet very very strong! These quickly clamp onto almost anything to mount a light with or without an umbrella. I use these with …"  Read Full Review »
Jul 11 2007
dmcusmc
Binghamton, NY
I am:
  • Semi-Professional
Reviewed at:
Price: $54.90
Justin Clamp - Expensive But Needed
5.0
    Pros
  • Durable
  • Easy To Use
  • Reliable
    Cons
  • Bulky
    Best Uses
  • Everyday use
  • Strobist
  • Studio
  • Traveling
"I love this clamp, it is a well made piece and well thought out - and STRONG.
I don't recommend using it for this but I recently mounted a large dSLR and zoom lens on a pistol grip ball-head secured ONLY by the Bogen 175F clamp, and it HELD.
Since buying this, I've bought $3 clamps at the home …"  Read Full Review »
May 13 2009
jhelms
Columbus, GA
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $54.90
[1 of 1 customers found this review helpful]
A handy tool in my bag of tricks
4.0
    Pros
  • Lightweight
  • Portable
  • Strong Construction
    Cons
  • Expensive
    Best Uses
  • Fill Flash
  • Lighting
  • Photojournalism
  • Placing remote strobes
"I love these flash shoe clamps and would it love even more if I could find a source to buy a handful of the flash shoe mount that threads into the mini ballhead. This clamp is wonderfully helpful for a variety of editorial photo assignments and allows me to do fast but competent remote lighting set …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 6 2007
Jeff
Madison, WI
Reviewed at:
Price: $54.90
Great Idea!
5.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • Absoutly none
    Best Uses
  • Everyday use
  • Home
  • Portraits
  • Studio
"A wonderful product which is very useful for remote flash usage,can be used for indoor or outdoor remote operation. Someone really came up with a good idea when they desighned this product you will find all kinds of ways of putting this product to use with your flash units. "
Aug 25 2009
P.H
Allenton, WI.
I am:
Reviewed at:
Price: $54.90
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
