Close Login Module
Join
Manfrotto Bogen - Pro Digital Geared Head with Quick Release - Supports 16.50 lb
#9
4.8
based on 19 reviews
Ratings Distribution
5 star
17
4 star
1
3 star
0
2 star
1
1 star
0
Category Average
4.4
$399.90
from 1 store
More Images
Pros
  • Good stability (9)
  • Attaches firmly (6)
  • Large range of motion (6)
  • Strong clamp (5)
  • Improves tripod function (4)
  • Camera control (1)
  • Compact (1)
  • Easy to use (1)
  • Fine adjustment knob (1)
  • Fine adjustments (1)
See less See more
Cons
  • Heavy (4)
  • A tad pricey (1)
  • Bit pricy (1)
  • Cumbersome (1)
  • I dont see cons (1)
  • Loose clamp (1)
  • Loose fixtures (1)
  • Not for outback (1)
  • Poor design (1)
Best Uses
  • Photography (13)
  • Stabilization (12)
  • Long exposures (11)
  • Portraits (9)
  • Reducing noise (iso reduction) (2)
  • Astronomy mount (1)
  • Heavy cameraslenses (1)
  • Macro (1)
Where to Buy
BizRate Rating Outstanding 9.1
$399.90
Product Reviews
Last update: Sep 23, 2009
Manfrotto Bogen - Pro Digital Geared Head with Quick Release - Supports 16.50 lb Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
[4 of 13 customers found this review helpful]
5.0
Great for heavy cameras/lenses
"This is a fantastic camera head. I've owned one for 3 years and use it with a large MF film camera (Fuji GX-680III) with heavy glass. If it can handle that, it can handle anything in the 35mm/telephoto range. All actions are smooth and easy to access. The large knobs are rubberized and easy to grip. The knobs each have an outer collar that serves as the axis "quick release" for gross adjustment, and an inne..." Read Full Review »
Feb 23, 2008 by Barry
See more positive Manfrotto Bogen - Pro Digital Geared Head with Quick Release - Supports 16.50 lb reviews
2.0
In principle great, in fact terrible.
"This head seemed like a great idea -- great control over positioning the camera. Oil levels for each axis. BUT the geared head is clunky to use. There is a fine adjustment and a gross adjustment. Fine adjustment is easy. The gross adjustment is not particularly intuitive. This might just be a matter of familiarity. But you can find yourself releasing the gross adjustment too quickly and whipping your camera in a..." Read Full Review »
Jun 03, 2007 by Huw
See more negative Manfrotto Bogen - Pro Digital Geared Head with Quick Release - Supports 16.50 lb reviews
Displaying 1 - 5 of 19 Reviews
Show
Sort by
5.0
    Pros
  • Camera control
  • Heavy duty construction
  • Intuitive to use
    Cons
  • None
    Best Uses
  • Long Exposures
  • Photography
  • Stabilization
"This is a fantastic camera head. I've owned one for 3 years and use it with a large MF film camera (Fuji GX-680III) with heavy glass. If it can handle that, it can handle anything in the 35mm/telephoto range. All actions are smooth and easy to access. The large knobs are rubberized and easy to g …"  Read Full Review »
Was this Tripod Head review on the Manfrotto helpful to you?
 Report Abuse  (7)  (0)  0 comments
Feb 23 2008
Barry
Alabama
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Best head I own.
5.0
"I think you need a ball head on some jobs and a geared head only when adjustments are the main job you want the head to perform. I have used this head for about 5 years and have had no trouble at all. This head is not for sports unless your locked on a spot where the action takes place. I put a quic …"  Read Full Review »
Dec 1 2007
Keith
CA
Reviewed at:
An almost perfect head
5.0
    Pros
  • Good Stability
  • No camera flop
    Cons
  • Cumbersome
  • Not for outback
    Best Uses
  • Long Exposures
  • Photography
  • Portraits
  • Stabilization
"I am an architectural photographer and have used 2 of these for 3 years almost daily. They are sturdy, hardy, and have all the adjustments needed. They will help remove one frustration from your life and free your mind to do what it needs to be doing. An earlier reviewer says they drift. They do not …"  Read Full Review »
Aug 14 2009
I don't like people much
Seattle WA
I am:
  • Pro Photographer
Reviewed at:
[2 of 2 customers found this review helpful]
Beefy, well constructed unit.
5.0
    Pros
  • Attaches Firmly
  • Fine adjustments
  • Good Stability
  • Large Range of Motion
  • Strong Clamp
    Cons
  • None
    Best Uses
  • Long Exposures
  • Macrophotography
  • Stabilization
"The Pro-Digital Geared Head is a solid unit, with quick adjustments and geared adjustments with no backlash. It is a rugged unit and should last a very long time, at a price that is affordable compared to other heads. I found this unit especially useful in macro photography and portraits, allowing t …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jan 27 2008
Aussie Fine Art Photographer.
Sydney, Australia.
I am:
Reviewed at:
Price: $399.90
[1 of 1 customers found this review helpful]
Great for my purpose
5.0
    Pros
  • Attaches Firmly
  • Good Stability
    Cons
  • Heavy
    Best Uses
  • Photography
  • Portraits
  • Reducing Noise (ISO Reduction)
  • Stabilization
"I use this head for macro (Canon 40D+Tamron 180mm+macro rails), and movie projector on the side as well. An over kill for my purpose but works great for me. It does creek a little over time (as in movie projector's case, you can see the movie screen a little tilted after a few hours. But I've never …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 29 2008
yc
Seaside, CA
I am:
  • Photo Enthusiast
Reviewed at:
Price: $399.90
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$399.90
Out Of Stock
BizRate Rating Outstanding 9.6
$399.95
No Tax Outside NY
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
