Manfrotto 521 Camera Remote Controller
4.6
based on 16 reviews
Ratings Distribution
5 star
10
4 star
6
3 star
0
2 star
0
1 star
0
Category Average
4.1
Pros
  • Lightweight (13)
  • Easy to use (12)
  • Quality construction (10)
  • Good interface with camcorder (9)
  • Improves performance (9)
  • Good stability (2)
  • Affordable (1)
  • Durable (1)
  • Folds small (1)
  • Zoom very steady and slow (1)
See less See more
Cons
  • Only one clampnot steady (1)
  • Small control (1)
  • Unstable (1)
  • Weak construction (1)
Best Uses
  • Shooting outdoors (8)
  • Shooting indoors (7)
  • Stabilization (4)
  • Travel (3)
  • Home movies (2)
  • Movies (2)
  • On a boom (1)
  • Replacement (1)
  • Special events (1)
  • Support braces (1)
Provided by B&H Photo Video
Manfrotto 521 Camera Remote Controller Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 521 Camera Remote Controller
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 21, 2009
Manfrotto 521 Camera Remote Controller Reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
Simple and effective
4.0
    Pros
  • Affordable
  • Easy to use
  • Good Stability
  • Lightweight
    Cons
  • None
    Best Uses
  • Movies
  • Support braces
  • Tri pods
"I ordered this remote primarily to use with a Canon GL2 and a support brace that takes my hands off of the camera's native buttons. Since i only required that the remote control the zoom function, this was my choice - and the right one. The focus control was a bonus, but it works perfectly as does t …"  Read Full Review »
Was this Camcorder Accessory review on the Manfrotto 521 Camera Remote Controller helpful to you?
Apr 10 2008
Brad from G-vegas
Greenville, SC
I am:
  • Aspiring Film Maker
  • Tech Savvy
  • Videographer
Reviewed at:
[1 of 1 customers found this review helpful]
I highly recommend this product.
5.0
    Pros
  • Easy To Use
  • Good Interface With Camcorder
  • Improves Performance
  • Lightweight
  • Quality Construction
    Cons
  • None
    Best Uses
  • Home Movies
  • Shooting Indoors
  • Shooting Outdoors
  • Special events
"This product is very easy to install and use.The operation is very easy and simple.It gives you great control of the zoom lens.If you press heavy the zoom is very fast, if you press lightly the zoom is much slower. It's nice having this control at your fingertips rather than reaching up at the top o …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 7 2008
Johnny Video
Anchorage, Alaska
I am:
  • Tech Savvy
  • Videographer
Reviewed at:
I like it
4.0
    Pros
  • Folds Small
  • Lightweight
    Cons
  • Unstable
  • Weak Construction
    Best Uses
  • For wedding shooting
  • Stabilization
"I really like it. I gave it 4 stars Instead of 5 for one fact, the clamp is only from one side which does not hold it firmly in place, why Bogen is so stingy? why not make it with clamps on both sides, so it hold this remote more steady? Besides this issue, this remote works exactly what I expect. I …"  Read Full Review »
May 21 2008
johnny
Phoenix, Arizona
I am:
  • Film Professional
  • Wedding Videographer
Works Great!
5.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • None
    Best Uses
  • Shooting Indoors
  • Shooting Outdoors
  • Wedding Ceremony
"Works perfect with my PD170. I like using this with a two handle tripod for wedding ceremonies. It really keeps helps to keep my mind focused because it has a very natural feel.
One question I had and found the answer once I received it, and maybe someone else does... This controller zooms fas …"  Read Full Review »
Sep 29 2008
Fish Hook Productions
Central Kentucky
I am:
  • Proffesional
Reviewed at:
Works great
5.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • None
    Best Uses
  • None
"This makes life a lot simpler when filming with a tripod. I had gotten into the habit of keeping my hand on the camera to control zoom and pause. During quieter events I'd begun to notice recorded sounds from my hands rubbing on the camera. This eliminates that problem. Very easy to connect and use. …"  Read Full Review »
Feb 15 2009
John
Washington
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
