Manfrotto 503HDV Pro Fluid Head
#250
4.3
based on 50 reviews
Ratings Distribution
5 star
29
4 star
13
3 star
4
2 star
1
1 star
2
Category Average
4.4
Low Price:
$353.90 at Adorama
 Trusted:
$353.95 at B&H Photo Video
Find it at Amazon
$353.90 - $354.00
from 3 stores
More Images
Pros
  • Good stability (27)
  • Large range of motion (25)
  • Attaches firmly (24)
  • Strong clamp (20)
  • Durable (7)
  • High quality (7)
  • Good value (5)
  • Easily adjusted (3)
  • Smooth (3)
  • Smooth movement (3)
See less See more
Cons
  • Heavy / bulky (6)
  • Complicated controls (3)
  • Cumbersome (1)
  • Horizotal pans (1)
  • Little much for small cam (1)
  • No orientation change (1)
  • Pan stop could be smoothe (1)
  • Sticky pan motion (1)
Best Uses
  • Stabilization (24)
  • Long exposures (6)
  • Movies (5)
  • Photography (4)
  • Portraits (3)
  • Reducing noise (iso reduction) (3)
  • Videography (3)
  • Outdoors (2)
  • Bird photography (1)
  • Camcorder (1)
Provided by B&H Photo Video
Being very much aware of changing trends in the video world Manfrotto revised their proven 503 fluid head taking into account the increasing performance demands of High Definition Mini-DV camcorders. The result is the 503HDV Pro. With regard to ergonomics the engineers at Manfrotto designed the 503HDV with entirely left-handed controls to enhance operational efficiency. Since camera controls are generally left-handed every setting may be inspected and verified at a glance facilitating rapid setups from shot to shot. The greater resolution of High Definition video means that details as well as errors in movement are more apparent and thereby demands a more refined means of support. The continuously-variable fluid drag system of the 503HDV provides just the right amount of dampening for any shot on your list-from whip pans to slow motion just dial in drag to touch. This capability in conjunction with the 3-step counterbalance delivers the type of fingertip camera control normally reserved for much more costly production fluid heads. ENG crews and independent filmmakers alike will appreciate the thoughtful full-featured design of the 503HDV fluid head as it expands their shooting gamut without unnecessarily shrinking their budgets. As with all other Bogen/Manfrotto supports it includes a two-year warranty and comprehensive online documentation.
Specification Description
Model 503HDV
UPC 719821275510
Height (Inches) 4.5
Max. Capacity 10 To 20 Pounds
Select With Quick Release
Weight (Pounds) 4.3
Manfrotto 503HDV Pro Fluid Head Questions
Questions and Answers
Where to Buy
$353.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$354.00
BizRate Rating Outstanding 9.1
$353.90
Product Reviews
Last update: Nov 10, 2009
Manfrotto 503HDV Pro Fluid Head Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
An improvement over the original 503.
"I've shot about 15 weddings with the original 503 heads- I liked them a lot, and I was disappointed with some of the negative reviews I'd seen on the 503HDV. Nevertheless, I ordered a 503HDV, as I needed another tripod/head. After working with the new 503HDV, I must say, I am VERY satisfied with the re-design. The control arm can be mounted on either the left or right side, contrary to what some have writte..." Read Full Review »
May 16, 2008 by James
See more positive Manfrotto 503HDV Pro Fluid Head reviews
3.0
Sticky pans
"I use it making Wedding videos. I like the 3 tension settings for the vertical & the light on the leveling bulb. The horizontal panning is less than expected since it sticks at start of each pan, causing jerky movement in video. My 10 yr old 501 head does the same so I shouldn't have been surprised at the stickiness of horizontal motion in both directions...." Read Full Review »
Aug 11, 2009 by jimdandy
See more negative Manfrotto 503HDV Pro Fluid Head reviews
Displaying 1 - 5 of 50 Reviews
Show
Sort by
Good tripod head
4.0
    Pros
  • Good Stability
    Cons
  • None
    Best Uses
  • Photography
  • Stabilization
"For the price it's good. I've used this head for many years at my old job and liked it enough to purchase it for myself with my own business. The size of it is small yet it's functionality is great. Yeah there are better heads out there, but the ones that are better that I've used are a lot bigge …"  Read Full Review »
Was this Tripod Head review on the Manfrotto 503HDV Pro Fluid Head helpful to you?
Nov 19 2009
djderyck
Joplin
I am:
  • Photo Enthusiast
Reviewed at:
Price: $353.95
Very smooth
5.0
    Pros
  • Attaches Firmly
  • Good Stability
  • Large Range of Motion
    Cons
  • None
    Best Uses
  • Photography
  • Stabilization
  • Videography
"I had a Mafrotto 501 (non HD) before this and liked it pretty well. But the HDV head takes it to a whole new level. Very very smooth head, & the centering counter balance takes it a step further.. "
Nov 10 2009
Zach
Atlanta, Ga
Reviewed at:
Price: $353.95
5.0
    Pros
  • Attaches Firmly
  • Good Stability
  • Strong Clamp
  • Very smooth
    Cons
  • None
    Best Uses
  • Videography
Nevertheless, I ordered a 503HDV, as I needed another tripod/head. After working with the new 503HDV, I must say, I am VERY satisfied wi …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
May 16 2008
James
Katy, TX
I am:
  • Professional
Reviewed at:
Price: $353.95
[1 of 1 customers found this review helpful]
Left-handed only? Not so!
5.0
    Pros
  • Attaches Firmly
  • Good Stability
  • Strong Clamp
    Cons
  • None
    Best Uses
  • Bird photography
  • Stabilization
"I couldn't help but notice that some reviewers have complained about the lack of a handle on the right of this head. Are we looking at the same item? Either Manfrotto has altered the more recent versions, or the model exported to Japan is unique, because the handle can be fitted to either side! …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Apr 27 2008
Yukihyo
Tokyo, Japan
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $353.95
Excelence
5.0
    Pros
  • Easily Adjusted
  • Smooth Movement
    Cons
  • None
    Best Uses
  • Special Events
"I am a professional choreographer and dancer, and I do videodance work and a lot of documentary archive of our stage productions.
The head is fast enough to follow dancers and at the same time keep the movement of the shot smooth.
I used the old model of the 503, and the improvements are amaizing, …"  Read Full Review »
Nov 2 2009
Om the dancer
Mazatlán, México
I am:
  • Professional
Reviewed at:
Price: $353.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
