Manfrotto 458B NeoTec Pro Photo Tripod Legs
#15
4.7
based on 35 reviews
Ratings Distribution
5 star
24
4 star
10
3 star
1
2 star
0
1 star
0
Category Average
4.4
$248.00 - $350.00
from 5 stores
More Images
Pros
  • Easily adjusted (19)
  • Smooth movement (18)
  • Good footing (17)
  • Locks in tight (17)
  • Rugged (9)
  • Unfolds quickly (7)
  • Good stability (6)
  • Folds small (5)
  • Lightweight (5)
  • Durable (2)
See less See more
Cons
  • Heavy / bulky (14)
  • Pricey (2)
  • Cumbersome (1)
  • Legs became hard to slide (1)
  • Legs not that great (1)
  • Slips out of position (1)
  • So-so stability (1)
Best Uses
  • Home (13)
  • Special events (11)
  • Sports (10)
  • Travel (10)
  • Long exposures (7)
  • Photography (7)
  • Portraits (7)
  • Office (6)
  • Stabilization (5)
  • Easy of leveling (1)
Provided by OneCall
Awesomely fast and easy to use, the 458B has the innovative Neotec rapid opening and closing mechanism - just pull each leg downwards to open and automatically lock it in any position, with no screws, knobs or levers to tighten or loosen. Then to fold it back up again, press the mechanism release button and push the leg closed, it`s that simple!
Combined with the 458B`s high load capacity, great minimum and maximum height range, full range of professional features and speed, makes it the ideal tripod for location work under pressure. The 458B has a built-in carrying handle; a two section center column for low angle or normal shooting and four leg angle positions.
Key features include:
  • New center column design allows you to leave the head mounted on the column when switching between low angle and normal shooting.
  • Double positioning vertical and horizontal center column.
  • Four set leg angle positions for a solid footing at any height.
  • Leg lock release button for closing the tripod or shortening each leg for perfect positioning.
  • Carrying strap can be used to support a counterweight.
  • Waterproof up to 18" as the bottom leg section is sealed.
  • Specification Description
    Model 458B
    UPC 719821240181
    Brand Bogen
    Clearance Yes
    Leg Sections 3
    Material Aluminum
    Maximum Capacity 10 to 19.9 Lbs
    Maximum Height 60" to 72"
    Select Aluminum
    Tripods Series Neotech Manfrotto Tripods
    Usage Binoculars
    Weight 5.3 lbs
    Manfrotto 458B NeoTec Pro Photo Tripod Legs Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 3, 2009
    Manfrotto 458B NeoTec Pro Photo Tripod Legs Reviews
    Most helpful positive review
    [3 of 3 customers found this review helpful]
    Most helpful negative review
    5.0
    Simply incredible!
    "I bought the NeoTec 458B as part of a package that included the 322RC2 ball grip and the quick release shoe mount. I hated using my old tripod. Each leg extension had to be released, positioned and locked. The camera was then mounted on the pan head and screw locked in place. After completing the shots, the camera had to be removed (I'd never trust carrying it on the tripod for more than a short distance.) The..." Read Full Review »
    Jul 26, 2008 by Desert rat
    See more positive Manfrotto 458B NeoTec Pro Photo Tripod Legs reviews
    3.0
    Bogen Neotec - good for general purpose
    "The legs are not as helpful as the advertising would suggest. The legs are a little weak making these not as stable as some other more standard tripods. These are a good choice for compact carry or a back up. The biggest down side to this tripod is the extra cost for the novelty of design...." Read Full Review »
    Jul 10, 2008 by Robert
    See more negative Manfrotto 458B NeoTec Pro Photo Tripod Legs reviews
    Displaying 1 - 5 of 35 Reviews
    Show
    Sort by
    Simply incredible!
    5.0
      Pros
    • Easily Adjusted
    • Good Footing
    • Locks In Tight
    • Rugged
    • Smooth Movement
      Cons
    • Heavy
      Best Uses
    • Home
    • Special Events
    • Sports
    • Travel
    "I bought the NeoTec 458B as part of a package that included the 322RC2 ball grip and the quick release shoe mount. I hated using my old tripod. Each leg extension had to be released, positioned and locked. The camera was then mounted on the pan head and screw locked in place. After completing the sh …"  Read Full Review »
    Was this Tripod Leg review on the Manfrotto 458B NeoTec Pro Photo Tripod Legs helpful to you?
     Report Abuse  (3)  (0)  0 comments
    Jul 26 2008
    Desert rat
    Tucson, AZ
    I am:
    • Hobbyist/Enthusiast
    Reviewed at:
    Price: $349.95
    [1 of 1 customers found this review helpful]
    Highly Recommend
    5.0
      Pros
    • Easily Adjusted
    • Good Footing
    • Lightweight
    • Locks In Tight
    • Rugged
    • More »
      Cons
    • None
      Best Uses
    • Home
    • Office
    • Special Events
    • Sports
    • Travel
    "In outdoor photography constantly moving and needing a tripod that sets up very quickly with no hassles the 458B has proven itself.
    The speed and ease in extending the legs by simply pulling them to the length desired is the first selling point. Being able to fine tune positioning by depressing a l …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Apr 16 2008
    Mel
    Hillsboro, OR
    I am:
    • Semi-Professional
    Reviewed at:
    Price: $349.95
    I love this tripod..I love Bogen Imaging
    5.0
      Pros
    • Good Stability
    • Unfolds Quickly
      Cons
    • Cumbersome
    • Heavy
      Best Uses
    • Long Exposures
    • Photography
    • Portraits
    • Stabilization
    "I love its ease of leg extension and contraction. I move around a lot changing positions and this helps. One note of caution, the silver buttons that release the legs for contraction are held onto the tripod by two screws. During a trek last week, a screw fell out and I lost the button so it was …"  Read Full Review »
    Nov 3 2009
    Jerry
    West Des Moines IA
    I am:
    • Semi-pro Photographer
    Reviewed at:
    Price: $349.90
    5.0
      Pros
    • Durable
    • Good Value
    • High Quality
      Cons
    • none
      Best Uses
    • Easy of leveling
    • Landscapes
    • Long Exposures
    • Portraits
    • Quick setup
    • More »
    "What more can say, this tripod is just simply Awesome! This is my first professional quality tripod and I have to say I'm completely pleased. I made a trip out to the local state park were hugh flocks of Canadian snow geese gather for wintering. After missing my first oppurtunity to photograph the f …"  Read Full Review »
    Jan 26 2009
    bobc10x
    Reading, PA
    Reviewed at:
    Price: $349.95
    Finally!
    5.0
      Pros
    • Folds Small
    • Good Stability
    • Unfolds Quickly
      Cons
    • None
      Best Uses
    • Long Exposures
    • Photography
    • Portraits
    • Stabilization
    "I've been waiting to get a Neotec for more than 4 years, you won't find it any cheaper than here. Is a very sexy tripod, looks wonderful and the operation is incredibly simple. By now all tripods should be like the Neotec. The only drawbacks is that the legs are a bit oily and probably you need to k …"  Read Full Review »
    Sep 2 2009
    Quiroz
    Humble, TX
    I am:
    • Pro Photographer
    Reviewed at:
    Price: $248.00
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
