Manfrotto 055XPROB Black Pro Tripod
#1
4.7
based on 267 reviews
Ratings Distribution
5 star
190
4 star
73
3 star
3
2 star
1
1 star
0
Category Average
4.4
Low Price:
$134.95 at B&H Photo Video
 Trusted:
$139.90 at Adorama
Find it at Amazon
$134.95 - $180.00
from 7 stores
More Images
Pros
  • Good stability (248)
  • Unfolds quickly (173)
  • Folds small (82)
  • Lightweight (74)
  • Easy to use (7)
  • Versatile (7)
  • Easily adjusted (5)
  • Good footing (5)
  • High quality (5)
  • Locks in tight (5)
See less See more
Cons
  • Heavy (79)
  • Cumbersome (3)
  • Unstable (3)
  • A bit heavy on long treks (1)
  • Extra long center column (1)
  • Heavy but who cares (1)
  • Heavy if compare w carbon (1)
  • It's not that heavy (1)
  • Moderate weight (1)
Best Uses
  • Stabilization (216)
  • Long exposures (194)
  • Photography (191)
  • Portraits (141)
  • Reducing noise (iso reduction) (96)
  • Macro (8)
  • Sports (5)
  • Travel (5)
  • Home (4)
  • Special events (4)
Provided by Buzzillions.com
The Bogen/Manfrotto 055XPROB Tripod Legs builds on the success of the 3011/3021 series. It features the Manfrotto-patented horizontal center column feature, which allows the center column to flip quickly and easily from vertical to horizontal. By extending the column to its highest vertical position, it can be swung over to horizontal without removing the head or disassembling the column itself. The ergonomics of the leg-angle release mechanism and the quick action leg locks have also been improved. The 055XB provides speedy set-up coupled with added security with quick action, lever-type leg locks. It is ideal for use with 35mm and light medium format photographic cameras, and digital or conventional type video camcorders.
Specification Description
Model 055XB, 055XDB, 055XPROB
UPC 719821276883
Height (Inches) 70.3 (max)
Maximum Capacity 10 to 19.9 Lbs
Maximum Height 60" to 72"
Select Aluminum
Weight (Pounds) 5.3
Manfrotto 055XPROB Black Pro Tripod Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
Manfrotto 055XPROB Black Pro Tripod Reviews
Most helpful positive review
Most helpful negative review
[0 of 3 customers found this review helpful]
4.0
Really pleased
"I am a newly "professional" landscape photographer and have been slowly adding good equipment to my bag. After several frustrating starts with lightweight tripods I really am pleased with this for the price...." Read Full Review »
Sep 25, 2009 by Sue
See more positive Manfrotto 055XPROB Black Pro Tripod reviews
3.0
Nice but padding on only 2 of 3 legs?
"This is a good sturdy tripod. I bought it to replace my Bogen 3021 that was stolen, The only thing I don't like and think is odd is that two of the legs have built in padding; not three legs, just two. And the padding only covers two thirds of the length of the leg, leaving the other third exposed metal. I usually cover the legs with Op-Tech tripod leg wraps, but with the partial built in padding on the 55XPro, ..." Read Full Review »
Nov 25, 2008 by Dznman
See more negative Manfrotto 055XPROB Black Pro Tripod reviews
Displaying 1 - 5 of 267 Reviews
Show
Sort by
Really pleased
4.0
    Pros
  • Good Stability
  • Lightweight
  • Unfolds Quickly
    Cons
  • None
    Best Uses
  • Long Exposures
  • Photography
  • Portraits
  • Reducing Noise (ISO Reduction)
  • Stabilization
"I am a newly "professional" landscape photographer and have been slowly adding good equipment to my bag. After several frustrating starts with lightweight tripods I really am pleased with this for the price. "
spearfish falls
spearfish falls
  • Made with Product
Was this Tripod Leg review on the Manfrotto 055XPROB Black Pro Tripod helpful to you?
Sep 25 2009
Sue
Spearfish, SD
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $139.90
[14 of 18 customers found this review helpful]
Great tripod for outdoor photography
5.0
    Pros
  • Folds Small
  • Good Stability
  • Macro
  • Unfolds Quickly
    Cons
  • None
    Best Uses
  • Photography
  • Stabilization
"I have a Gitzo traveler and so was looking for an everyday outdoor photography tripod that would be stable enough to hold my D80 + as heavy as a 300/f4 lens. I like to go hiking and take everything from landscapes to Macro to wildlife shots. This tripod is perfect for someone who wants the versati …"  Read Full Review »
 Report Abuse  (14)  (4)  0 comments
Sep 20 2007
Nikonian Jon
Charlottesville, Va.
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $139.90
Great innovations-quality tripod
5.0
    Pros
  • Folds Small
  • Good Stability
  • Lightweight
  • Unfolds Quickly
    Cons
  • None
    Best Uses
  • Long Exposures
  • Photography
  • Portraits
  • Stabilization
"The horizontal center column was the selling point for me with this tripod. Noteworthy advancement from the previous model-The center column simply slides into place and takes the hassle out of removing the column and placing it in horizontally. This is not only convenient because of ease, it is als …"  Read Full Review »
Nov 10 2009
Anthony B
Chicago, IL
I am:
Reviewed at:
Price: $134.95
A good solid,but not too heavy tripod
5.0
    Pros
  • Folds Small
  • Good Stability
  • Lightweight
  • Unfolds Quickly
    Cons
  • None
    Best Uses
  • Photography
  • Stabilization
"Use primarily w/ super telephotol for wildlife photograpy. Plenty stable and light enough for field use. "
Cardinal with 900mm Lens
  • Made with Product
Feb 6 2009
dgraham329
Meeker, OK
I am:
Reviewed at:
Price: $139.90
Great Tripod--Sturdy and Ease to Set
5.0
    Pros
  • Ease to adjust
  • Good Stability
    Cons
  • None
    Best Uses
  • Long Exposures
  • Portraits
  • Stabilization
"I bought this tripod to hold my Canon 40D with my EF 70-200/2.8L IS attached. The tripod handles the weight easily and with the 486 Ball Head is very ease to adjust the position of the camera and lens. I've used it several times now and am very impressed. I do wish it came with a carrying case. I'll …"  Read Full Review »
Nov 10 2009
Frank
St. Louis, MO
I am:
  • Photo Enthusiast
Reviewed at:
Price: $134.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
