Mackie SWA1501 15 Inch Powered Subwoofer *
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
Pros
  • Great sound quality (2)
  • Attractive design (1)
  • Easy to connect (1)
  • Powerful (1)
See less See more
Cons
  • Heavy / bulky (1)
Best Uses
  • Basic systems (1)
  • Home theater (1)
  • Outdoors (1)
  • Smaller rooms / apartments (1)
Provided by PSSL.com - ProSound and Stage Lighting
Massive Bass In Compact Enclosure Small Enough to Fit In Your Toyota Corolla!Sometimes you need all the bottom-end you can get. That's where the Mackie SWA1501 Active Subwoofer System comes in. The SWA1501 features an internal 500-Watt Mackie FR (Fast Recovery) Series amplifier and a high-precision 15" transducer, custom designed for optimal performance with the amp and enclosure. Onboard Mackie Active electronics ensure seamless integration of the amplifier and transducer at all times, creating a system that is highly efficient and versatile. TRUE ACTIVE SUBWOOFERActive doesn't just mean the SWA1501 has an amplifier bolted on its back—it means optimized electronics that provide complete control and maximum performance over all components. The onboard Active system controls the crossover filters, equalization, protection for the transducer and electronics, and provides real time vigilance over the entire system. There is simply no way that you can get this kind of full system functionality by strapping an amp on the back of a passive speaker box. BUILT-IN CROSSOVERConnecting and setting up the SWA1501 is a breeze. It accepts a stereo or mono line-level signal via female XLR input jacks. Male XLR Thru jacks are provided for daisy-chaining the signal to additional SWA1501 cabinets. The built-in crossover routes the high frequency content to the high-pass output jacks, which can be used to feed the inputs of full-range Active speakers, such as those in the SRM Series, or an amplifier powering a pair of passive speakers. A Subwoofer Level control lets you adjust the balance between the subwoofer and the full-range speakers. LOTS OF ONBOARD HORSEPOWER…The SWA1501's built-in amplifier, which produces 500 watts continuous power, sits on a massive heatsink, eliminating the need for fans and dramatically extending life expectancy. A tremendous benefit of having the amplifier inside the subwoofer enclosure is that the SWA1501 functions as a complete system, optimizing acoustic, electronic, and mechanical designs to achieve the highest level of performance and value. SOLID WOOD CONSTRUCTIONFor High-output loudspeakers, real wood just sounds better—and it looks better, too! The SWA1501 enclosure is made of select 18mm Baltic birch plywood and finished in black splatter paint. Carrying handles are integrated into each side for easy loading. Since you will probably want the mid/high pack nearby, a pole mount receptacle is strategically placed on top of the enclosure.Features • 500-Watt single 15” compact Active subwoofer system (700-Watt peak) • Precision 15" woofer with high temperature voice coil • 500-Watt continuous power FR Series high-current amplifier • Extremely powerful system capable of real, professional output levels • Onboard Active electronics provide equalization and high-pass filter for full-range loudpseakers. • 128dB Peak Output • Frequency Response 36 Hz–120 Hz • 13-ply Baltic Birch enclosure finished in black splatter paint • Cast aluminum side handles
Mackie SWA1501 15 Inch Powered Subwoofer * Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: SWA1501 15 Inch Powered Subwoofer *
See all eBay results
  at eBay.com
Product Reviews
Last update: Feb 7, 2009
Mackie SWA1501 15 Inch Powered Subwoofer * Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Great Hitting Bass
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • Heavy
    Best Uses
  • Basic Systems
  • Home Theater
  • Outdoors
  • Smaller Rooms
"Well i dont occasionally own one but i went to a hall in Capital Heights and this Dj had it one of my friends and the Bass was jus incredible in a big hall and the sound was crisp clear so if u are jus startin to dj or want to start with this and the monitors related to the Sub "
Was this Speaker & Subwoofer review on the Mackie SWA1501 15 Inch Powered Subwoofer * helpful to you?
Feb 7 2009
Djmixxfest
Landover Hills,MD
I am:
  • Professional
  • Technically Challenged
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
