Mackie Quad 10 Precision Subwoofer 750W 8 Ohms*
#175
4.9
based on 7 reviews
Ratings Distribution
5 star
6
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
$299.99 at GuitarTrader.com
Find it at Amazon
Find it at Ebay
$299.99
from 1 store
More Images
Pros
  • Great sound quality (11)
  • Powerful (6)
  • Attractive design (5)
  • Easy to connect (5)
  • Noisy (1)
  • Rockin (1)
  • Smooth (1)
See less See more
Cons
  • Heavy / bulky (1)
Best Uses
  • Basic systems (4)
  • Outdoors (4)
  • Home theater (2)
  • Smaller rooms / apartments (2)
  • Ballrooms (1)
  • Club (1)
  • Lg rooms (1)
  • Musician (1)
  • Pro audio / dj / mixing (1)
Provided by PSSL.com - ProSound and Stage Lighting
Tight, Punchy Bass And Lots Of It! Ask any bass player and they'll tell you 10" speakers offer quicker attack (transient) response than a single 15" or 18". In Mackie's never-ending quest for the ultimate subwoofer, they turned to the gurus at Eastern Acoustic Works (EAW), who were highly instrumental in the design of the S400 Series loudspeakers. This design philosophy, which employs multiple smaller drivers versus a single 15" or 18", is carried forward in the S400 Series subwoofer. Mackie replaced the single 18" found in most small venue sub cabinets with four 10" transducers, creating the Mackie S410s Subwoofer. This new configuration translates into a punchy, tighter bass pattern, and lots of it! BIGGER AIR MOTOR Let's look at a typical subwoofer; the 18" speaker offers extremely slow transient response, and requires a massive amount of power to get the job done. Mackie threw out the 18" speaker in favor of four 10" drivers, which provide substantially more surface area than the 18-incher, creating ample punch and tight, more focused low-end. And four 10" speakers are much more efficient. More surface area = more air movement = more thump! INTEGRATED 180Hz LOW PASS FILTER Another great feature within the S410s is the state-of-the-art 180Hz low pass filter. This eliminates the need for an external crossover* when the S410s Precision Passive Subwoofer is used in conjunction with the S408 Precision Passive 2-Way Loudspeaker. Just connect a power amp via the Speakon™ jack on the rear of the S410s. Then connect the S408 to the remaining jack and voilá, you now have a superior passive 3-way system. *Although an external crossover is not necessary, using one would mean better system efficiency. POWER HANDLING Due to its extremely efficient design, the S410s can be driven by even the smallest of power amplifiers. But to showcase its full potential, strap-on your beefiest amp (maybe one of Mackie's M-Series High-Efficiency Power Amps) and climb to a new level of sound quality and professional capability. Pair the S410s with the S408 and prepare to succumb to musical bliss! SOLID CONSTRUCTION The S410s Precision Passive Subwoofer, and its companion, the S408 are each constructed of solid 18mm Baltic Birch plywood and coated with wear-resistant, textured black PVC vinyl paint. These cabinets are built to stand up to rugged use while maintaining their stunning appearance. Side-mounted, balance-optimized handles make them easy to transport. Features: Precision Passive Subwoofer enclosure featuring touring-quality sound in a club-sized package Unique 4 x 10" LF driver configuration offers enhanced transient response vs. single 18" configuration Stackable design with recessed footholds allows for S408 atop a sub or two S410s stacked for a powerful long-throw sub-stack Top Hat pole receptacle for use with S408 Portable with 2 balance-optimized side mounted handles Dual, parallel, locking NL4 connections for Input and Thru on rear panel Sensitivity: 96dB SPL (1W/1m) 750W RMS power handling at 8 Ohms; 3000W peak Integrated 180Hz low pass filter Frequency Response: 40Hz-400Hz
Mackie Quad 10 Precision Subwoofer 750W 8 Ohms* Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 2, 2009
Mackie Quad 10 Precision Subwoofer 750W 8 Ohms* Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
awesome punchy bass
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Outdoors
"this sub box is awesome. it pounds hard. i know it was a little much to use in my house but i wouldn't change a thing. now i have plenty of punch to take it outdoors if needed. my expectations were way blown out of the water with this product. awesome sound and punch!!! "
  • Picture of Product
Was this Speaker & Subwoofer review on the Mackie Quad 10 Precision Subwoofer 750W 8 Ohms* helpful to you?
Aug 1 2009
heller
orlando fl
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Great, you can feel the base
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Outdoors
"I've been a DJ since 1974 and I've always prided myself with great sound. I purchased a pair of Mackie 410's & 408's and they blow away anything I ever had before. Very easy to set up and they soung great at either low volume or high volume. "
Small outdoor pic nic
Aug 2 2009
DJ Daniel Boone
Wormleysburg, Pa
I am:
  • Practical
  • Professional
Reviewed at:
Lovely Solid, Tight Punch
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Smaller Rooms
"Love these Speakers. They are very tight and deliver and exceptional bassline. Highly recommended and the price is great. "
Jul 21 2009
Mista Flava
Belmopan, Belize, Central America
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Don't sleep on these!
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Outdoors
"I work for a high-end sound company and we just purchased 8 of these units. They sound very loud and tight, just what you would expect from EAW-Mackey. The baltic birch wood and the superior design make this not only one of the best sounding subs on the planet, but at this price; this is one of the …"  Read Full Review »
Jun 12 2009
David Bernal
Southern California
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Mackies' Earthquake Sub.
5.0
    Pros
  • Powerful
    Cons
  • None
    Best Uses
  • Ballrooms
  • LG Rooms
  • Outdoors
"You could use this With Any Loudspeakers/Powered Ect.. Whats great about this " Mackie Quad4" Its that it Sounds Fantastic, like if ther were dual 15' or one 18' I used 4 "Mackie Quad" in a 1/2+ Acer out door Area; the Sound is Unexplainabe, Basicly it was Amazing. I have Earthquke Cerwin Vegas, And …"  Read Full Review »
Jun 7 2009
DJ TiTo
Orange County, CA
I am:
  • DJ
  • Pro Audio
  • Professional
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
