M-Audio 9900-50757-00 Delta 44 4-in/4-out Audio Card
#43
5.0
based on 4 reviews
from $133.95 - $169.99
Ratings Distribution
5 star
4
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
Pros
  • Easy to install (2)
  • Easy to use (2)
  • Fast (1)
  • Great sound quality (1)
  • Highly compatible (1)
  • Quality output (1)
  • Reliable (1)
  • Versatile (1)
See less See more
Best Uses
  • Amateur recording (1)
  • Everyday (1)
  • Multimedia (1)
  • Software defined radio (1)
  • Soundtracks (1)
Provided by MAGo Enterprise
MODEL- US41110LVENDOR- M-AUDIO FEATURES- Delta 44Professional 4-In/4-Out Audio Card.Need a great sounding audio interface without digital I/O The Delta 44 offers the same features and high performance as the Delta 66 but is designed for the user who does not require digital I/O. And like its big brother the Delta 44s breakout box handles four balanced/unbalanced +4dBu or -10dBV signal level analog inputs and outputs. You get the same 24-bit/96kHz fidelity industry-standard driver support and bulletproof operation as is found across the entire Delta family. * 4 x 4 24-bit/96kHz full-duplex audio interface * 4 x 4 analog I/O * Software controlled 36-bit internal DSP digital mixing/routing * Software configurable for +4dBu and -10dBV signal levels * Zero-latency monitoring * Greatly expandable with Omni i/o * Apple G5 compatible * 36-bit Embedded DSP All Delta cards contain a 36-bit embedded DSP enabling a software-driven patchbay/router for all analog and digital I/O--all with extremely fast throughput for low-latency software monitoring. A single unified control panel provides settings for clock and sample rates buffer sizes individual signal levels for every input and output adjustable +4dBu/-10dBV pad conrols and digital I/O control on up to four installed Delta cards. All controls are also easily accessible through most professional audio software applications for seamless integration and operation. * Included SoftwareYour M-Audio product comes with a great software bundle that lets you start making music right away. Many products include a special version of Ableton Live and a selection of our popular ProSessions Sound and Loop Libraries. See package for more details as software bundles may vary. -- SPECIFICATIONs ----------------------------------- FREQ.RESPONSE- 48kHz sample rate Input : +/-0.3 dB 22Hz to 22kHzOutput: +/-0.2 dB 22Hz to 22kHz 96kHz sample rate Input : +/-0.4 dB 22Hz to 40kHzOutput: +/-0.3 dB 22Hz to 40kHz DYNAMIC RANGE- 103dB (A-weighted) (D/A) 99dB (A-weighted) (A/D) THD - < 0.002% (D/A) 0.0023% (A/D) COMPATIBILITY- ASIO 2 MME Sound Manager OMS DirectX GSIF Mac OS X Core Audio/Core MIDI REQUIREMENTS - PC : Windows 98SE/Me/2000 (SP4)/XP (SP1) For 96kHz operation: Pentium III 500mHz w/128MB RAM For 48kHz operation: Pentium II 400 w/64MB RAM MAC: G3/G4* 500MHz OS 9.2.2 128MB RAM OS X 10.1.5 10.2.6 or greater 256MB RAM OMS 2.3.8 for MIDI under OS 9.2.2 * G3/G4 accelerator cards not supported; OS 10.3required for Dolby Digital and DTS pass-through withApple DVD Player. SIZE - 5 1/8 x 7/8 x 5 3/8WT.- 0.8 lbs.
Specification Description
Model 9900-50757-00, 99005075700, MDELTA44X, US41110L
UPC 612391411107
Benefits Includes 4x4 24-bit/96kHz full-duplex audio interface and 4x4 analog I/OEnjoy digital mixing/routing with extremely fast throughput v
Capacity UOM mAh
Description Header High-end audio with professional results.
Display Catalog Number 55024040
End Product Indicator Yes
Manufacturer Labor Warranty 12
Manufacturer Part Number US41110L
Manufacturer Parts Warranty 12
MAP Price 0.0
Model US41110L
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Disclaimer Dolby and Dolby Pro Logic are registered trademarks of Dolby Laboratories Licensing Corporation. DTS is a registered trademark of Digital Theater Syst
Product Height 0.88
Product Length 5.13
Product Type Specialty
Product Weight 0.8
Product Weight UOM pounds
Product Width 5.38
Required to function Windows 98SE/ME/2000(SP4)/XP(SP1)For 96kHz operation: Intel® Pentium® III 500MHz with 128MB RAMFor 48kHz operation:
Supported Languages English
M-Audio 9900-50757-00 Delta 44 4-in/4-out Audio Card Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 13, 2009
M-Audio 9900-50757-00 Delta 44 4-in/4-out Audio Card Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Best & cheapest card w/ multi IN/OUT
5.0
    Pros
  • Clear Sound
  • Easy To Use
  • Versatile
    Cons
  • None
    Best Uses
  • Amateur Recording
  • Soundtracks
"I had an Audiophile 24/96 card for many years, so I'm no stranger to M-Audio's products. As my project studio grew, I realized that having more than two INs and OUTs would be very helpful, so I stepped up to the Delta 44. Installation and setup went very smooth, and it has functioned flawlessly so f …"  Read Full Review »
Was this Sound & Video Card review on the M-Audio 9900-50757-00 Delta 44 4-in/4-out Audio Card helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 26 2008
Brock
Lubbock, TX
I am:
  • Experienced
Reviewed at:
Price: $133.95
Excellent Sound Quality
5.0
    Pros
  • Easy To Install
  • Easy To Use
  • Quality Output
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Everyday use
  • Multimedia
"I,m using the Delta 44 sound card to interface my computer with my audio recording equipment, and so far, I have been blown away with the excellent sound quality. Far beyond the results I was getting for the computers old sound card. Also of real usefulness to me is the Breakout box, allowing the …"  Read Full Review »
Sep 13 2009
Toby Recordings
Middletown, Connecticut
I am:
  • Power user
Reviewed at:
Price: $133.95
High performance sound card!
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Software Defined Radio
"I'm not using this as a normal sound card. I'm using it to do the processing for a software defined radio (SDR). The 24 bit capability is perfect for this application. It is the defacto standard soundcard for the purpose. "
May 20 2008
W2UA
Morristown, NJ
I am:
  • Frequent User
Reviewed at:
Price: $133.95
[3 of 4 customers found this review helpful]
Best you can get in this price range!
5.0
"Pros
Great for small home recording studio use!
Works great with ZERO latency recording.
NO HISS.
Cons
Hard to set up the drivers.
You need a mixer to assign ins and outs and to monitor the signals.
Additional Thoughts
I use the delta44 with windows XP, Sonar HS and Audition 2. "
 Report Abuse  (3)  (1)  0 comments
Mar 8 2008
CN666
Minnesota
Reviewed at:
Price: $149.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
