LumiQuest ProMax 80-20 System - Six Piece Flash Light Modification Kit
#16
4.5
based on 33 reviews
from $52.95
Ratings Distribution
5 star
19
4 star
11
3 star
2
2 star
0
1 star
0
Category Average
4.3
Low Price:
$52.95 at B&H Photo Video
 Trusted:
$52.95 at Adorama
Find it at Amazon
More Images
Pros
  • Lightweight (23)
  • Easy to use (13)
  • Consistent output (11)
  • Versatile (10)
  • Durable (8)
  • Easily interchangeable (6)
  • Softens light (5)
  • Convenient interface (2)
  • Reliable (2)
  • Well built / quality construction (2)
See less See more
Cons
  • Comes to my mind that i (1)
  • Flash itself (1)
  • Hard light (1)
  • Heavy / bulky (1)
  • I can think of other than (1)
  • Longer to change - others (1)
  • More reflector colors (1)
  • Questionable durability (1)
  • Sb800 900 without (1)
Best Uses
  • Portraits (18)
  • Fill flash (17)
  • General purpose (9)
  • Night photography (7)
  • Photojournalism (4)
  • Lighting (3)
  • Photography (3)
  • Event photography (1)
  • General flash (1)
  • Social event photo (1)
Provided by Abes of Maine
The LumiQuest ProMax System allows 80% of the light to bounce off the ceiling while 20% is redirected forward as fill light. The system includes interchangeable white, gold and silver inserts as well as a removable frosted diffusion screen. The ProMax System will give you studio-like control in a convenient kit that attaches in seconds with touch fastener tabs and folds flat for storage in a sturdy pouch.
LumiQuest ProMax 80-20 System - Six Piece Flash Light Modification Kit Questions
Questions and Answers
Where to Buy
$52.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$52.95
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Nov 17, 2009
LumiQuest ProMax 80-20 System - Six Piece Flash Light Modification Kit Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Great Multi-Purpose Light Modification
"I'd been looking at buying the 80-20 by itself for a while now, but when I saw the combo system that includes all the extras, I was sold. The storage system for it was a nice touch, and probably the only way they could have made it better was to include some type of snap to keep it closed so nothing would fall out. But that's minor really. Between the inserts and front diffuser options, there are so many ways t..." Read Full Review »
May 25, 2009 by Jason K.
See more positive LumiQuest ProMax 80-20 System - Six Piece Flash Light Modification Kit reviews
3.0
Good diffuser, but could be improved.
"Add some included velcro and strap this device to your flash to add some diffusing properties. Folds easily and the material is durable. The diffusing properties could be better, used from close range might get some harsh light on the subject. For its construction and performance I think it should be priced a little bit lower. I have used it just for some testing and I like Lightsphere better, but then again ..." Read Full Review »
Jul 08, 2008 by Gerardo Pedraza
See more negative LumiQuest ProMax 80-20 System - Six Piece Flash Light Modification Kit reviews
Displaying 1 - 5 of 33 Reviews
Show
Sort by
Love it!
5.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • None
    Best Uses
  • Night Photography
  • Portraits
"I love the ability to have studio lighting outside. Love the interchangeable cards.
Not crazy about having to put it directly on my flash. "
Was this Camera Flash review on the LumiQuest ProMax 80-20 System - Six Piece Flash Light Modification Kit helpful to you?
Nov 10 2009
Rachael
Clearwater, FL
I am:
  • Professional
Reviewed at:
Price: $52.95
5.0
    Pros
  • Consistent Output
  • Durable
  • Lightweight
  • Versatile
    Cons
  • None
    Best Uses
  • Fill Flash
  • General Use
"I'd been looking at buying the 80-20 by itself for a while now, but when I saw the combo system that includes all the extras, I was sold. The storage system for it was a nice touch, and probably the only way they could have made it better was to include some type of snap to keep it closed so nothing …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
May 25 2009
Jason K.
Orlando, FL
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $52.95
Very versatile
5.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Versatile
    Cons
  • None
    Best Uses
  • Fill Flash
  • General Use
  • Portraits
"Pros:
very compact (travels well,
easy to use (takes seconds to install)
works in many lighting conditions (indoors or out, low ceilings or high ceilings)
Cons:
I found that when installing unit on the flash unit, you have to pay careful attention to the angle you install it. Since a flash …"  Read Full Review »
Oct 18 2009
faces and places
Pittsburg, KS
I am:
  • Semi-Professional
Reviewed at:
Price: $52.95
Super lightweight lighting modifyers
4.0
    Pros
  • Easy To Use
    Cons
  • Flimsy
    Best Uses
  • Fill Flash
  • General Use
  • Night Photography
  • Portraits
"This is a great first 80/20 product to get. Later you can just get the basic kit for a second flash. I got this because the SB-900 did not work with my Gary Fong diffuser. For the money, this kit is much more versatile and easier to transport. A little flimsy when working with cameras off the should …"  Read Full Review »
Nov 19 2009
Mark Tantrum
San Jose, CA
I am:
  • Professional
Reviewed at:
Price: $52.95
Hugely Helpful
4.0
    Pros
  • Compact
  • Durable
  • Easily Interchangeable
  • Easy To Clean
  • Lightweight
    Cons
  • None
    Best Uses
  • Event Photography
  • Portraits
"I borrowed a friend's for a wedding that I was second-shooting, and I will definitely be getting one of my own. I used it with a Nikon SB-600.
I own the Gary Fong inverted dome, and this Lumiquest kicks the dome's butt in several ways - it folds flat, whereas the fong dome takes up a huge amount …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 9 2008
AlexJB
San Francisco, CA
I am:
  • Semi-Professional
Reviewed at:
Price: $52.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
