Lowepro Edit 110 Camcorder Case
#149
4.3
based on 55 reviews
Ratings Distribution
5 star
35
4 star
29
3 star
6
2 star
2
1 star
1
Category Average
4.2
Low Price:
$19.95 at B&H Photo Video
 Trusted:
$19.95 at Abt Electronics
Find it at Amazon
$19.95 - $27.99
from 10 stores
More Images
Pros
  • Well padded (54)
  • Lightweight (49)
  • Well built / quality construction (48)
  • Comfortable (46)
  • Easily accessible equipment (39)
  • Good design (3)
  • Compact (1)
  • Durable (1)
  • Functional (1)
  • Good protection (1)
See less See more
Cons
  • Not enough pockets (9)
  • Hard to access equipment (5)
  • Cumbersome (2)
  • Missing divider (1)
  • Small (1)
  • Small for my camera (1)
  • Small side pockets (1)
  • Small-ish size (1)
  • Space too crampy (1)
  • Too small for a camcorder (1)
Best Uses
  • Protecting gear (49)
  • Transporting gear (45)
  • Daily usage (22)
  • Storing gear (17)
  • Daily transport (1)
  • Hold wallet and gum (1)
Provided by Overstock.com
  • Lowepro digital video camera bag more compact, but with the features of larger bags
  • Edit 110 shoulder bag designed to fit most small digital cameras
  • Great original or replacement camera case
  • Lots of accessory pockets, a soft, lining, padded interior
  • Adjustable divider for superb protection
  • Space for 1 compact digital camcorder
  • video camera plus accessories
  • Shell in water-resistant 840-denier nailhead nylon and microfiber
  • Available in black color option
Specification Description
Model 34683, Edit 110, LP34683-0EF, LP346830EF
UPC 056035346835
Designed For Mini Video Camcorders
Select Universal Cases
Lowepro Edit 110 Camcorder Case Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 14, 2009
Lowepro Edit 110 Camcorder Case Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
4.0
good bag
"The bag is pretty convenient, lots of reasonably designed pockets, and so forth. My only complaint is the size - it is designed for smaller cameras, and my Panasonic DMC-FZ18 (4.6" x 3.0" x 3.5") is a *very* snug fit (no "drop and go" here, have to physically push it in, and under a certain angle so that the friction doesn't move any of the controls, specifically the power switch). If I had opted for a slightl..." Read Full Review »
May 20, 2008 by Mars
See more positive Lowepro Edit 110 Camcorder Case reviews
3.0
Not quite right for Canon camcorder
"I have several Lowepro camera bags so when this one was offered with the Canon camcorder I bought it. It is a fine bag but the internal divider makes no sense with the Canon Flash memory camcorders. I ended up having to stick the divider across one corner of the bag and using it to hold the charger. I would be happier if the divider fit from end to end in my application. It probably works better for a smalle..." Read Full Review »
Jun 24, 2009 by Bill
See more negative Lowepro Edit 110 Camcorder Case reviews
Displaying 1 - 5 of 55 Reviews
Show
Sort by
good bag
4.0
    Pros
  • Comfortable
  • Easily Accessible Equipment
  • Strong Construction
  • Well Padded
    Cons
  • Small-ish size
    Best Uses
  • None
My only complaint is the size - it is designed for smaller cameras, and my Panasonic DMC-FZ18 (4.6" x 3.0" x 3.5") is a *very* snug fit (no "drop and go" here, have to physically push it in, and under a certain angle …"  Read Full Review »
Was this Gadget Bag review on the Lowepro Edit 110 Camcorder Case helpful to you?
 Report Abuse  (3)  (0)  0 comments
May 20 2008
Mars
New York
I am:
  • Casual user
Reviewed at:
Price: $19.95
Nice camera bag for the Canon HF-200
4.0
    Pros
  • Comfortable
  • Lightweight
  • Well Padded
    Cons
  • Cumbersome
    Best Uses
  • Protecting Gear
  • Transporting Gear
"All my camera bags (ariound 10) are made by LowePro and I probably would not consider any other brand as my experience with their products is simply perfect (some of the bags endure constant use and are 10+ years old).
The Edit 110 bag is a very simple one, designed to carry a small camcorder and …"  Read Full Review »
Oct 16 2009
PP
Brazil
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $19.95
Sweet Case For Smaller Camera
4.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"Case appears to be durable and is as loaded with pockets galore per the size of the case. I bought it to use with our new Panasonic Lumix FZ8 and although it fits, there could be a little more wiggle room for accessories...would work better with a bit smaller camera. I am considering going up to th …"  Read Full Review »
Jan 21 2008
JoBeth Camera Gal
Wisconsin
Reviewed at:
Price: $19.95
Read this
5.0
    Pros
  • Comfortable
  • Lightweight
  • Well Padded
    Cons
  • None
    Best Uses
  • Daily Usage
  • Protecting Gear
  • Transporting Gear
"First I though this bag was going to be big but its NOT!
Great things:Has nice padding,well placed pockets and zippers,nice straps,easy to handle when you need your camera fast!
Bad things:Nothing "
Nov 14 2009
Ben
Montreal,Ca
Reviewed at:
Price: $19.95
Great Bag - Lots of Pockets
4.0
    Pros
  • Comfortable
  • Lightweight
  • Well Padded
    Cons
  • None
    Best Uses
  • Daily Usage
  • Protecting Gear
  • Transporting Gear
"This is a great little bag to hold your camcorder and supplies. It has enough room for the camcorder, charging cord, extra tapes, and extra battery pack. I put a memory card and a few extras in there too. The only reason I give it 4 stars instead of five is because the side pockets don't sit perfect …"  Read Full Review »
Aug 4 2009
The Filming Librarian
Houston, TX
I am:
  • Casual Photographer
Reviewed at:
Price: $19.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
