Logitech X-240 2.1 Speakers System
#31
4.1
based on 174 reviews
Ratings Distribution
5 star
88
4 star
50
3 star
16
2 star
13
1 star
9
Category Average
4.0
Low Price:
$31.45 at Buydig.com
 Trusted:
$37.49 at B&H Photo Video
Find it at Amazon
$31.45 - $48.49
from 6 stores
More Images
Pros
  • Easy to use (16)
  • Great sound quality (14)
  • Compact design (7)
  • Added features (3)
  • Comfortable (3)
  • Durable (2)
  • Attractive design (1)
  • Bass (1)
  • Good value (1)
  • Great bass (1)
See less See more
Cons
  • Bulky design (3)
  • Poor sound quality (2)
  • Bass (1)
  • Bass doesn't thump (1)
  • Easy to use (1)
  • Not very loud (1)
  • Peaks easily (1)
  • Poor microphone (1)
Best Uses
  • Entertainment (2)
  • Typing & talking (2)
  • Computer speakers (1)
  • Give to wife for kitchen (1)
  • In my room (1)
  • Ipod speakers (1)
  • Listening to music (1)
  • Mobility (1)
  • Personal stereo (1)
  • Stereo system (1)
Provided by ClubMac
Portable X-240 Speakers with MP3 Cradle Turn your computer into a powerful digital music center. The stow-away MP3 cradle makes the Logitech X-240 speakers more than just a great speaker system for your computer. Turn your computer into a powerful digital music center. The stow-away MP3 cradle makes the Logitech X-240 speakers more than just a great speaker system for your computer. The stow-away MP3 cradle makes the Logitech X-240 speakers more than just a great speaker system for your computer. Connect your digital audio player with the included auxiliary cable, or use your own USB/power cable to sync, charge and play digital music from your iPod, Zune, PDA or mobile phone. Dynamic, real-time bass equalization maximizes bass response from the down-firing subwoofer while high-excursion drivers provide rich sound from the slim, stylish satellites.Features:• Stow-away device cradle.&nbsp&nbsp&nbsp&nbsp• Connect your MP3 player to the auxiliary input, or use your own USB/power cable for syncing and charging.• Convenient volume and power controls.&nbsp&nbsp&nbsp&nbsp• Enjoy deep, rich sound or use the headphone jack to listen to your music privately.• Stylish metal grills.&nbsp&nbsp&nbsp&nbsp• The modern yet durable design complements any computer system or home decor.• Ported, down-firing subwoofer.&nbsp&nbsp&nbsp&nbsp• Displaces more air for deeper bass.• High-excursion satellite drivers.&nbsp&nbsp&nbsp&nbsp• Provide rich sound while maintaining a slim profile.• Headphone jack.&nbsp&nbsp&nbsp&nbsp• Allows you to enjoy your music privately. Specifications:• Total FTC power: 25 watts RMS: &nbsp&nbsp&nbsp&nbsp• Sub-woofer: 15 watts RMS (into 8 ohms, @ 100Hz, @ 10% THD) &nbsp&nbsp&nbsp&nbsp• Satellites: Left/Right: 5 watts RMS x 2 (into 8 ohms, @ 1khz, @ 10% THD)• Drivers:&nbsp&nbsp&nbsp&nbsp• Satellites: 2" high-excursion driver&nbsp&nbsp&nbsp&nbsp• Subwoofer: 4" ported driver• Speaker Dimensions (H x W x D):&nbsp&nbsp&nbsp&nbsp• Satellites: 6.9" x 2.6" x 3.8"&nbsp&nbsp&nbsp&nbsp• Subwoofer: 8.7" x 5.9" x 8.7"
Specification Description
Model 3381292C, 970285, 970285-0403, 9702850403
UPC 097855039866
Benefits Connect your MP3 player to the auxiliary input, or use your own USB/power cable to sync & chargeConvenient volume and power controls<
Capacity UOM mAh
Country Of Origin China
Description Header Don't miss any of the crash, bang or wallop!
Display Catalog Number 55024744
Features Headphone jack allows you to enjoy your music privatelyTotal FTC power: 25W RMSTotal peak power: 50WFrequency respo
Included in the Box Speakers: satellites(2), subwoofer(1)Control center with integrated MP3 player cradleColor coded audio cableiPod&re
Manufacturer Labor Warranty 2
Manufacturer Part Number 970285-0403
Manufacturer Parts Warranty 2
MAP Price 0.0
Model 970285-0403
Operating Temperature UOM ° F
Product Type Speakers
Supported Languages English
Logitech X-240 2.1 Speakers System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
Logitech X-240 2.1 Speakers System Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[3 of 4 customers found this review helpful]
5.0
Best for the price range!!!
"1st I would like to say I am very glad that Best buy finally got this rating system up I have used ratings systems on other sites but I purchase primarily from Best Buy and would love to see other Best Buy customer reviews for products in the store/online. As for the product I love it I baught it to replace my harmon kardon speakers(stock, they do not have a sub) I baught these speakers because the specs sounded..." Read Full Review »
Aug 15, 2007 by Tino
See more positive Logitech X-240 2.1 Speakers System reviews
3.0
Disappointing
"When I first took this system out of the box and listened, I thought it sounded very good. But after awhile I noticed some significant distortion in the mid-range. Also, the bass level never seemed to come out quite right no matter how I adjusted it. The bass driver is a paper cone, which compares unfavorably with polypropylene used in better systems. Also the bass cone has no protective grill and the raw co..." Read Full Review »
Jul 21, 2009 by ROCCO
See more negative Logitech X-240 2.1 Speakers System reviews
Displaying 1 - 5 of 174 Reviews
Show
Sort by
5.0
As for the product I love it I baught it to …"  Read Full Review »
Was this Computer Speaker & Headphones review on the Logitech X-240 2.1 Speakers System helpful to you?
 Report Abuse  (5)  (0)  0 comments
Aug 15 2007
Tino
San Francisco, Ca.
Just what the doctor ordered
4.0
    Pros
  • Easy To Use
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • None
"I'm a poor grad student. Masters in Classical composition. I use a macbook pro, Sibellius and other pro music software. The Logitech reproduces my compositions perfectly with clear bass and treble definition. A great and affordable setup. "
Nov 11 2009
Musicwriter
San Francisco, California
I am:
  • Quality Oriented
Reviewed at:
Price: $39.88
[2 of 2 customers found this review helpful]
Big bang for little bucks.
5.0
"I have the logitech Z-2300 2.1 system , and it is worth it's weight in gold. Now for this system. I was in a retail store and wanted to compare the X-240's . I first listened to a Bose 2.1 system that was $99.00 . The sound was NOT that great at all. I then listened to a Bose system that was $250.00 …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 12 2009
kurtb
Undisclosed
Reviewed at:
[3 of 3 customers found this review helpful]
Wow!
5.0
    Pros
  • Bass
  • Durable
  • Good Value
  • High Quality
  • Sound
    Cons
  • None
    Best Uses
  • Computer Speakers
  • Ipod Speakers
  • Stereo System
"I bought this to use for when i work out in my garage. Its a normal 22 car garage and this little system fills it all with sound! I thought the 4" sub would be too small but i was way off! Its not a wall shaker but it does the job!! "
 Report Abuse  (3)  (0)  0 comments
Jan 15 2008
Mooseman
West Lafayette, IN
Very Good Subwoofer - Tweeters not so
3.0
    Pros
  • Compact Design
    Cons
  • Not very loud
  • Poor Sound Quality
    Best Uses
  • Give to wife for Kitchen
"I bought these based on the reviews. I guess people are comparing these to basic computer speakers, because they are average at best. I wanted to hook them up to my TV to make Guitar Hero & Rock Band games sounds great. I ended up setting them up in the kitchen with an MP3 player for my wife. At …"  Read Full Review »
Oct 8 2009
John the music guy
Altus, Oklahoma
I am:
  • Quality Oriented
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
