Logitech V450 Nano Cordless Laser Mouse
#2
4.8
based on 120 reviews
Ratings Distribution
5 star
229
4 star
53
3 star
1
2 star
1
1 star
2
Category Average
4.3
 Trusted:
$37.95 at B&H Photo Video
Find it at Amazon
Find it at Ebay
$37.95 - $49.00
from 15 stores
More Images
Pros
  • Comfortable design (167)
  • Glides smoothly (167)
  • Accurate tracking (165)
  • Fast response (160)
  • Works on any surface (140)
  • Great features (129)
  • Good battery life (2)
  • All apply (1)
  • Battery lasts forever (1)
  • Compact (1)
See less See more
Cons
  • Catches easily (3)
  • Limited surface compatibility (2)
  • A little expensive (1)
  • A little small (1)
  • Doesn't work on granite (1)
  • Fingerprints show easily (1)
  • Haven't found any problem (1)
  • I haven't found a problem (1)
  • It's all good (1)
Best Uses
  • Everyday (161)
  • Web browsing (123)
  • Travel (106)
  • Professional (94)
  • Gaming (41)
  • Graphics (1)
  • Meetings (1)
  • Online class work (1)
Provided by ClubMac
V450 Nano Cordless Laser Mouse for Notebooks - Red With its laser precision, 12 months battery life, and ergonomic design, the V450 Nano gives you everything you need to get the job done. You’re always on the go, always looking for the next opportunity. With its laser precision, 12 months battery life, and ergonomic design, the V450 Nano gives you everything you need to get the job done.Features:Be more productive.• Laser precision: Enjoy smoother cursor control on virtually any surface.* The V450 Nano outperforms ordinary optical mice.• Powerful, reliable connection: Logitech’s advanced 2.4 GHz wireless dramatically reduces interference with 300 times faster data rate.** Virtually no delays or dropouts. Enjoy all the benefits of a cord with the convenience of cordless.• 12 months battery life: Minimizes hassle and helps you stay more productive. Convenient on/off switch saves even more power. Battery-indicator light eliminates surprises.Be more mobile.• Plug-and-Forget Nano-receiver: Barely larger than a coin – the Nano-receiver is so small that once you plug it into your notebook, you can forget about it. Your mouse is always ready to use.• Storable Nano-receiver: Store the Nano-receiver inside the mouse, if necessary. When stored inside the battery compartment, the mouse turns off automatically.Be more comfortable.• Sculpted, ergonomic design with soft rubber grip: Work longer in more comfort.• Sculpted keys: Position fingers naturally.Specifications:System Requirements• PC&nbsp&nbsp&nbsp&nbsp - Windows XP or Windows Vista&nbsp&nbsp&nbsp&nbsp - USB port• Mac&nbsp&nbsp&nbsp&nbsp - Mac OS X 10.3.9 or later&nbsp&nbsp&nbsp&nbsp - USB port
Specification Description
Model 910-0000617, 910-000617, 910-000619, 910-000620
UPC 097855049292
Color Black
Color Light Gray
Color Red
Compatibility PC and Macintosh
Connection Type Wireless
Connectivity USB
Mouse Type Notebook
Movement Detection Laser
Logitech V450 Nano Cordless Laser Mouse Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 10, 2009
Logitech V450 Nano Cordless Laser Mouse Reviews
Most helpful positive review
Most helpful negative review
4.0
It works, and so far no hand cramps.
"I am a spreadsheet jockey. So, for my usage, this mouse is more than adequate. (If you are a graphics person, you may feel differently.) The mouse is neither comfortable nor uncomfortable; it's mouse-like. It is very light, even with batteries. I love the tiny USB receiver. I can grab my laptop for meetings and not have to worry about having some giant stick coming out of the side of my computer. I can also slid..." Read Full Review »
Nov 10, 2009 by IamIntheTesterHeckDimension
See more positive Logitech V450 Nano Cordless Laser Mouse reviews
3.0
Works great but too pricey.
"I do graphics so I use the mouse frequently. I wish it were more comfortable, especially at the [$]price tag...." Read Full Review »
Oct 06, 2009 by myself
See more negative Logitech V450 Nano Cordless Laser Mouse reviews
Displaying 1 - 5 of 120 Reviews
Show
Sort by
Great Laptop Mouse
5.0
    Pros
  • Accurate Tracking
  • Comfortable Design
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Gaming
  • Professional
  • Traveling
  • Web Browsing
"I bought this mouse to match our recently purchased Gateway P7805u Laptops, because of the color scheme this mouse sports. By the pictures online, I thought the little trim stripe on it was orange, but when you get it and look at it under good lighting, it is more red than orange. No fault of anyb …"  Read Full Review »
Was this Computer Mice review on the Logitech V450 Nano Cordless Laser Mouse helpful to you?
Jun 19 2009
Mojo
Virden, IL
I am:
  • Power user
Reviewed at:
Price: $37.95
Great Little Mouse
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Works On Any Surface
    Cons
  • None
    Best Uses
  • Everyday Use
  • Traveling
  • Web Browsing
"I wanted a wireless mouse that had a very small receiver. I thought that a jump-drive-sized receiver would snag on things and potentially break something. I am very happy with how responsive this mouse is, it doesn't have to be moved much at all to get full range on the screen, and how small the r …"  Read Full Review »
Apr 27 2009
Pilot Pete
Michigan
I am:
  • Casual User
Reviewed at:
Price: $37.95
This a great mouse!
4.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • None
"I use this mouse with my laptop and it is great because it has the very small (nano) USB interface. The other units I used before had a long interface which was in the way. The Toshiba guys must be all left handed because they put the USB ports on the right side near the front where right handed peo …"  Read Full Review »
Mar 30 2009
canadaken
Lincoln, NE
I am:
  • Power user
Reviewed at:
Price: $37.95
Excellent cordless mouse
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Gaming
  • Traveling
  • Web Browsing
"Makes using my notebook so much eeasier. The touchpad is a pain to use. "
Nov 9 2009
Karaokejoe1
San Dimas,CA
I am:
  • Casual User
Reviewed at:
Price: $49.00
Great product!
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Professional
  • Web Browsing
"I bought this mouse about 6 months ago for use with my notebook computer. I decided to try it on my desktop computer first as the wire on my standard mouse was always getting hung up. I was amazed at how small the usb receiver was and I wonder if it would work. I removed my old corded mouse and plug …"  Read Full Review »
Feb 8 2009
Dr. Dan
Beaverdale, PA
I am:
  • Casual User
Reviewed at:
Price: $37.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
