Logitech Squeezebox Wireless Music System
4.8
based on 5 reviews
Ratings Distribution
5 star
4
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
$269.95 - $299.99
from 8 stores
More Images
Pros
  • Great sound quality (4)
  • Attractive design (3)
  • Easy to connect (2)
  • Compact (1)
  • Confusing / difficult controls (1)
  • Easy setup (1)
  • Many input choices (1)
  • Powerful (1)
  • Unlimited internet radio (1)
See less See more
Cons
  • Possibly defective unit (1)
Best Uses
  • Basic systems (3)
  • Smaller rooms / apartments (3)
  • Large rooms (2)
  • Audiophiles (1)
  • Living room (1)
  • Surround sound solution (1)
Provided by WolfCamera.com
Set the music free. Squeezebox plays a wide variety of digital music files, including uncompressed and lossless formats-across a true 802.11g wireless network connection. Enjoy the widest choice of listening options beyond your music collection, including thousands of internet radio stations, Pandora's personalized music service and Rhapsody's 2 million song collection. It's music, your way.
Performance
Unsurpassed sound quality: Hear the difference with 24-bit DAC, sophisticated audio rendering technology, and digital outputs. Sound clarity to please even the most demanding audiophile.
Control
Easy access to digital music: Listen to music stored on your computer, tune into Internet radio broadcasts, or browse music from online services.
Convenience
Expand your musical empire: Add more Squeezeboxes to access high-quality digital music in every room in the house.
Simple to install and operate: A wizard walks you through connection to your home network and the Internet. An intuitive interface makes browsing and playing music easy.
Specification Description
Model 930-000009
UPC 097855044945
#per pack 1
Battery Type Remote
Benefits Uses 802.11g networking to maximize your range and expand your placement optionsIntuitive interface makes browsing and playing music
Cables Included 6-foot gold-plated RCA patch cord
Capacity UOM mAh
Connections Headphone mini jack (1)RCA (1)Digital optical output (1)Digital coax output (1)Ethernet (1)Power
Cordless/Wireless Yes
Country Of Origin China
Data Link Protocol Ethernet
Description Header For streaming music.
Display Catalog Number 55035105
End Product Indicator Yes
Included in the Box Squeezebox Classic playerAC power adapterUser's manualSqueezeCenter software (requires download)Infrared r
Manufacturer Labor Warranty 2
Manufacturer Part Number 930-000009
Manufacturer Parts Warranty 2
MAP Price 0.0
Max Operating Temperature 124 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model 930-000009
Networking Compliant Standards CE, FCC, UL, TUV
Operating Temperature UOM ° F
Power Device AC power cord
Product Depth 3.1
Product Dimensions UOM inches
Product Height 3.7
Product Type Network music player
Product Width 7.6
Radio Frequency Range 802.11g
Remote Control Type IR
Size AA
Software Included SqueezeCenter
Supported Languages English
Logitech Squeezebox Wireless Music System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 30, 2009
Logitech Squeezebox Wireless Music System Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
BEST MUSIC STREAMER,..EVER,.. PERIOD.
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Intuitive Controls
    Cons
  • None
    Best Uses
  • Larger Rooms
  • Living Room
  • Smaller Rooms
  • Surround Sound Solution
"If you are STILL debating IF YOU SHOULD SPEND THE EXTRA DOLLAR or not on this puppy,..debate no more..it is worth every penny, and some more.I have researcehed extensively this device before i decided to buy it, from xxxx. i have a complex home theater/sound system at home that includes ceiling spe …"  Read Full Review »
Was this Home Theater review on the Logitech Squeezebox Wireless Music System helpful to you?
Aug 30 2009
pallpoul
lubbock, tx
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $269.99
[2 of 5 customers found this review helpful]
Great solution
5.0
Staff Expert  (what's this?)
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"I have a lot of FLAC and OGG Vorbis files on my network. The Squeezebox easily streams all my music from my network to my hi-fi set-up without a problem. It is a great device. The Burr Brown DACS are great as well. The squeezebox is a great solution for people who want to stream their music over …"  Read Full Review »
 Report Abuse  (2)  (3)  0 comments
Apr 2 2008
AO
NYC
I am:
  • Audiophile
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Price: $269.99
This is still a ...
5.0
"This is still a revolutionary product for music lovers.
Great for high end audio systems with or without an external dac.
Rip your CD's to Flac or other lossless format not mp3. Huge sound difference.
Takes effort to get all tunes on and indexed. There are tagging softwares available to assist. …"  Read Full Review »
Apr 4 2009
Micmac
Undisclosed
[0 of 3 customers found this review helpful]
Logitech Squeezebox - great design
4.0
    Pros
  • Attractive Design
    Cons
    Best Uses
  • Basic Systems
  • Smaller Rooms
"I use this unit to replace my satellite radio. While I can't receive the same stations as satellite radio, the over 10,000 stations I can receive make up for it and there's no monthly fee! On the downside it appears that the Internet Radio stations (the only source I use) sometimes stops and the di …"  Read Full Review »
 Report Abuse  (0)  (3)  0 comments
Feb 26 2009
Ken W.
near Asheville, NC
I am:
  • Tech Savvy
Reviewed at:
Price: $269.99
Logitech Squeezebox is quite impressive
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
    Cons
  • None
    Best Uses
  • Basic Systems
"I am so impressed with the Logitech Squeezebox. It as so easy to hookup for someone technically challenged like me. The sound is crisp and clear. It almost sounds better than the local FM radio stations. I was so impressed that I bought two for my bedroom and my living room stereo systems. [...] "
Mar 20 2009
Jane J
Union City, CA
I am:
  • Practical
  • Technically Challenged
Reviewed at:
Price: $269.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
