Logitech Squeezebox Duet Wireless Music System
4.3
based on 33 reviews
Ratings Distribution
5 star
19
4 star
9
3 star
3
2 star
1
1 star
1
Category Average
4.1
Low Price:
$349.88 at J&R Electronics
 Trusted:
$349.95 at B&H Photo Video
Find it at Amazon
$349.88 - $413.99
from 16 stores
More Images
Pros
  • Clear sound (11)
  • Confusing / difficult controls (8)
  • Easy setup (8)
  • Attractive design (2)
  • Compact (2)
  • Great sound (2)
  • All-around solid product (1)
  • Displays album art (1)
  • Diverse codec support (1)
  • Durable (1)
See less See more
Cons
  • Difficult to set up (4)
  • Poor interface (1)
  • Poor reliability (1)
  • Poor sound quality (1)
  • Pricey (1)
  • Remote a bit too plastic (1)
Best Uses
  • Larger rooms (4)
  • Living room (4)
  • Entertainment (2)
  • Home network (2)
  • Smaller rooms (2)
  • Any room (1)
  • Basic systems (1)
  • Listening to music (1)
  • Multiple rooms (1)
  • Small networks (1)
Provided by photoalley.com
Listen to the music you love in any room in your home.
Play songs stored on your computer, tune in to thousands of Internet radio stations, or connect to online services such as Pandora and Rhapsody.
Plus, the multi-room controller with 2.4-inch color display and scroll-wheel navigation makes it easy to browse, select, and play music from the palm of your hand.
Control
  • Unlimited access to digital music: Play songs from your personal collection, tune in to thousands of Internet radio stations, or connect to online services such as Pandora and Rhapsody.
  • Multi-room controller: Browse, select and play songs - all from the palm of your hand. 2.4-inch color display, convenient scroll wheel, familiar menus and intuitive buttons make navigation easy.
    Performance
  • Unsurpassed sound quality: High-fidelity 24-bit DAC, sophisticated audio rendering technology, and digital outputs provide crystal clear CD-quality sound.
  • Reliable connectivity: Wired ethernet and true 802.11G Wi-Fi support provide excellent range and connectivity.
    Convenience
  • Easy to set up and use: Start listening to your favorite tunes within minutes. A wizard walks you through every phase of setup, including connecting to your home network and the Internet.
  • Music everywhere: Enjoy your favorite tunes anywhere in your home. Connect the Squeezebox Receiver to a stereo system or powered speakers. Even add more Squeezebox players and create a different soundtrack for every room.
  • No computer needed: Use SqueezeNetwork -our free, Internet-based service- and tune in to thousands of Internet radio stations as well as online music services. Add an MP3tunes.com music locker and listen to your personal music collection without turning on your computer!
  • Specification Description
    Model 930-000033, 930000033
    UPC 097855048929
    Type of Receiver Stereo
    Logitech Squeezebox Duet Wireless Music System Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Sep 25, 2009
    Logitech Squeezebox Duet Wireless Music System Reviews
    Most helpful positive review
    [6 of 6 customers found this review helpful]
    Most helpful negative review
    [1 of 2 customers found this review helpful]
    5.0
    Wireless Stereo Magic
    "The Squeezebox Duet really does all it says on the box. I recently moved into a new, larger apartment and was wondering how I could hook up my PC, which is now located in a different room, to my soundsystem. I had previously worked and played in the same room and so this had never been an issue. I stumbled upon the Logitech Squeezebox quite by accident and it turns out to be tailored to meet my needs exactly - a..." Read Full Review »
    May 14, 2008 by rustbucket
    See more positive Logitech Squeezebox Duet Wireless Music System reviews
    2.0
    Great System but not Wireless
    "The Squeezebox is a great concept and it works really well, except the wireless does not work. I tried both a Netgear Rangemax and a Linksys wireless router and the Squeezebox worked with neither of them unless there was line of sight between the Squeezebox and the router. Normally, my router is 25 feet and one wall away from the the Squeezebox location. I have never had an issue with any other device using eit..." Read Full Review »
    Oct 07, 2008 by al1200
    See more negative Logitech Squeezebox Duet Wireless Music System reviews
    Displaying 1 - 5 of 33 Reviews
    Show
    Sort by
    5.0
      Pros
    • Attractive Design
    • Clear sound
    • Compact
    • Easy To Set Up
    • Great Sound
    • More »
      Cons
      Best Uses
    • Basic Systems
    • Entertainment
    • Larger Rooms
    "The Squeezebox Duet really does all it says on the box. I recently moved into a new, larger apartment and was wondering how I could hook up my PC, which is now located in a different room, to my soundsystem. I had previously worked and played in the same room and so this had never been an issue. I s …"  Read Full Review »
    Was this Home Theater review on the Logitech Squeezebox Duet Wireless Music System helpful to you?
     Report Abuse  (6)  (0)  0 comments
    May 14 2008
    rustbucket
    Berlin, Germany, Europe
    I am:
    • Barely tech competent
    • Practical
    Reviewed at:
    Price: $349.95
    [2 of 2 customers found this review helpful]
    I bought two sets!!!
    5.0
    "I did a lot of research before I decided to purchase the Logitech Duet. I narrowed my choices down to the Logitech Duet, the Sonos system, and Yamaha's MusicCast. I couldn't be happier with my decision to go with the Duet!
    I purchased two sets of this, so I have two controllers and two receivers. I …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Sep 2 2008
    audiofan
    Central California, USA
    Great Sound, Great interface
    4.0
      Pros
    • Clear Sound
    • Intuitive Controls
      Cons
    • Difficult To Setup
      Best Uses
    • Larger Rooms
    • Living Room
    • Smaller Rooms
    "This is the first component that deals with the end point media playout on my home network; having spent the last couple of years building the network (NAS, Gigabit ethernet, banging holes in the walls for cables etc).The duet is tiny and light; having previously had a soundbridge by comparison. The …"  Read Full Review »
    Jul 1 2009
    Ozspeed
    Melbourne, Australia
    I am:
    • Musically Inclined
    • Practical
    Reviewed at:
    Price: $349.95
    Prettty Amazing
    5.0
      Pros
    • Clear Sound
    • Easy To Setup
      Cons
    • None
      Best Uses
    • Larger Rooms
    • Living Room
    • Smaller Rooms
    "Great solution for a whole house music system. You can use your itunes, get any radio station, also get online services such as pandora, last fm slacker, media fly. options are endless. You also don't have to use itunes specifically. You can also direct it to a specific music folder. This way I …"  Read Full Review »
    Jul 29 2009
    fitzmung
    Boston
    I am:
    • Practical
    Reviewed at:
    Price: $349.88
    2.0
      Pros
      Cons
    • Poor Sound Quality
      Best Uses
    • None
    "The Squeezebox is a great concept and it works really well, except the wireless does not work. I tried both a Netgear Rangemax and a Linksys wireless router and the Squeezebox worked with neither of them unless there was line of sight between the Squeezebox and the router. Normally, my router is 25 …"  Read Full Review »
     Report Abuse  (1)  (1)  0 comments
    Oct 7 2008
    al1200
    Park City, UT
    I am:
    • Audiophile
    • Tech Savvy
    Reviewed at:
    Price: $349.95
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
