Logitech QuickCam Pro for Laptops
#2
4.5
based on 67 reviews
Ratings Distribution
5 star
63
4 star
22
3 star
4
2 star
2
1 star
3
Category Average
3.8
$74.95 - $99.99
from 16 stores
More Images
Pros
  • Easy setup (45)
  • Sharp image (41)
  • Great in low light (38)
  • Fast connection (35)
  • Great extra features (23)
  • Easy to use (2)
  • Quality construction (2)
  • Convenient size (1)
  • High quality (1)
See less See more
Cons
  • Free standing base weak (1)
  • Incompatible with my computer (1)
  • Marginal clip (1)
  • Need lots of memory (1)
  • Needs to tilt down more (1)
  • Poor in low light (1)
  • Usb cable too short (1)
Best Uses
  • Laptop (38)
  • Home computer (19)
  • Business meetings (12)
  • Monitoring (5)
  • Shopped compared-best (1)
  • Upgrade (1)
  • Webex conferencing (1)
Provided by Zappos
The Logitech QuickCam for Notebooks Pro Webcam will help you capture quality images and video. Features ; Carl Zeiss optics for superior image clarity. True 2 megapixel sensor allows for up to 8 megapixel photos (enhanced). Fantastic autofocus. Experience HD video calling and sharing at 960 x 720 pixels. RightLight 2 technology intelligently adjusts settings to provide the best possible images. Integrated microphone with RightSound technology for clear conversations free from echoes and background noise. Ultra-wide field of view and intelligent face tracking. 12 desktop stand puts camera at eye level. Adjustable display clip; Logitech Video Effects allow for personalized conversations with hundreds of avatars and face accessories which follow facial expressions and motion. Downloadable filters lets you add effects like fisheye, 50s movie, neon and many more. Includes HP Photosmart Essential software and other applications for Windows. Premium travel case. Specifications ; Carl Zeiss lens. 2 megapixel sensor. Color depth: 24-bit true color. Video resolution: Capture, 1600 x 1200 pixels. HD video, 960 x 720 pixels. Frame rate: 30 frames per second. Image capture: 8 megapixels. Built-in microphone. Cable length: 3 ft. Dimensions: 1.1 W x 2.5 H x 0.75 D. Weight: 2 oz. Minimum System Requirements Windows XP; Pentium P4 1.4 GHz processor. 128 MB RAM. 200 MB available hard disk space. 16-bit color display adapter. Windows compatible sound card. USB port. CD-ROM drive. Windows Vista; Pentium P4 processor 2.4 GHz. 512 MB RAM. 200 MB available hard disk space. 16-bit color display adapter. Windows compatible sound card. USB port. CD-ROM drive. Included ; Logitech QuickCam for Notebooks Pro Webcam. USB cable. Travel case. Eye-level desktop stand. Software CD. Quick-start guide. Zappos makes every attempt to provide accurate information for each electronic product. Manufacturer packaging and specifications may be different from the information provided. ; Please note, Zappos gladly accepts returns on all electronic products for up to 365 days from the original purchase date. In order to process your return and refund, returned electronic products must be unused and in the original condition and packaging in which it was purchased and include any manuals, cabling and accessories. Video Games, software, DVD and Blu-ray Disc must be returned unopened in their original shrink-wrap for a refund.
Logitech QuickCam Pro for Laptops Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
Logitech QuickCam Pro for Laptops Reviews
Most helpful positive review
[14 of 14 customers found this review helpful]
Most helpful negative review
[11 of 11 customers found this review helpful]
4.0
QuickCam Pro
"Pros The camera and microphone are excellent quality picture and voice recognition. The set-up CD runs/tests all the features so it's ready to function to your needs within minutes [user can modify settings later, if needed]. I really like the "QuickCam" tool that has all of the primary features you'll use with a live web cam window to see what everyone else will see [adjust before live activation], plus the us..." Read Full Review »
Sep 05, 2007 by MartinGA
See more positive Logitech QuickCam Pro for Laptops reviews
3.0
Pros The picture quality ...
"Pros The picture quality is fantastic. The pictures are crisp and clear and the video effects are an added bonus. Cons The video quality is terrible. The images are extremely blurry even your mouth when speaking. This webcam was bought for the sole purpose of videos and to me is useless without that feature. I would not recommend this camera if you plan on using the video features much. You must speak VERY sl..." Read Full Review »
May 10, 2008 by Rreed
See more negative Logitech QuickCam Pro for Laptops reviews
Displaying 1 - 5 of 67 Reviews
Show
Sort by
QuickCam Pro
4.0
"Pros
The camera and microphone are excellent quality picture and voice recognition. The set-up CD runs/tests all the features so it's ready to function to your needs within minutes [user can modify settings later, if needed]. I really like the "QuickCam" tool that has all of the primary features yo …"  Read Full Review »
Was this Webcam review on the Logitech QuickCam Pro for Laptops helpful to you?
 Report Abuse  (14)  (0)  0 comments
Sep 5 2007
MartinGA
Atlanta, GA
3.0
"Pros
Cons
This webcam was bought for the sole purpose of videos and to me is useless without t …"  Read Full Review »
 Report Abuse  (11)  (0)  0 comments
May 10 2008
Rreed
Arkansas
[1 of 1 customers found this review helpful]
About the best webcam for today
5.0
    Pros
  • Easy To Set Up
  • Fast Connection
  • Sharp Image
    Cons
  • None
    Best Uses
  • Home Computer
  • Laptop
"I did some research online before buying it. It looks as good as on the preview pictures in the online stores, really easy to install and use. Many video filters available for download from the manufacturer's website, installation takes seconds and is VERY easy. Software provided is just enough for …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Sep 23 2009
Mike
Atlanta, GA
I am:
  • Quality Oriented
Reviewed at:
Price: $74.95
[2 of 2 customers found this review helpful]
Great Product
5.0
    Pros
  • Easy To Set Up
  • Fast Connection
  • Good In Low Light
  • Sharp Image
    Cons
  • None
    Best Uses
  • Business Meetings
  • Home Computer
  • Laptop
"Typically, Logitech products are well designed and well made and this is no exception. Software is good, perhaps a few too many "cool" features for my taste but you don't have to use them. Purchased it for video calls via Skype and other such services and product works great in such applications. Th …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jun 18 2008
dadlfxt
Los Angeles, CA
I am:
  • Quality Oriented
Reviewed at:
Price: $89.99
Great camera at a great price
5.0
    Pros
  • Convenient size
  • Easy To Set Up
  • Good In Low Light
  • Sharp Image
    Cons
  • None
    Best Uses
  • Home Computer
  • Laptop
  • Webex Conferencing
"I use the Quickcam Pro primarily for skyping with friends, associates and family overseas. I upgraded from a less expensive webcam and people from "across the pond" noticed the difference in quality immediately. Unlike my first experience with Logitech, this time there were no glitches between Vist …"  Read Full Review »
Aug 6 2009
Avi the Rav
Silver Spring, MD
I am:
  • Value Oriented
Reviewed at:
Price: $74.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
