Logitech MX 1100 Cordless Laser Mouse
#327
4.3
based on 10 reviews
Ratings Distribution
5 star
18
4 star
6
3 star
1
2 star
1
1 star
2
Category Average
4.3
Low Price:
$51.95 at Buydig.com
 Trusted:
$64.95 at B&H Photo Video
Find it at Amazon
$51.95 - $77.99
from 16 stores
More Images
Pros
  • Accurate tracking (13)
  • Comfortable design (13)
  • Glides smoothly (12)
  • Fast response (11)
  • Easy setup (9)
  • Easy to use (9)
  • Great features (9)
  • Fast (8)
  • Works on any surface (8)
  • Powerful (5)
See less See more
Cons
  • Limited surface compatibility (2)
  • Catches easily (1)
  • Freezes up alot (1)
  • Inaccurate tracking (1)
  • No place to store the usb (1)
  • Poor battery life (1)
  • Slow response (1)
  • Uncomfortable design (1)
Best Uses
  • Everyday (10)
  • Upgrade (8)
  • Replacement (7)
  • Web browsing (6)
  • Professional (5)
  • Gaming (4)
  • Filing a trash can (1)
  • Home (1)
  • Multimedia (1)
  • Office (1)
Provided by ClubMac
MX 1100 Cordless Laser Mouse Think about it. If you spend more than eight hours a day using your computer, you're spending more than eight hours a day using your mouse. Think about it. If you spend more than eight hours a day using your computer, you're spending more than eight hours a day using your mouse. Don't you want to be as comfortable as possible? Now, you can.Features:As natural as a handshake.• Elegantly contoured shape: Fits your hand for maximum comfort. Designed to support the naturally curved shape of your hand.• Full-size design: Big. Broad. For support from your palm to your fingertips.One spin and you’ll never go back.• MicroGear Precision scroll wheel with hyper-fast scrolling: Lets you fly through long documents and Web pages with one spin. Or, shift to click-to-click mode to scroll through lists and photos.All the benefits of a cord with the convenience of cordless.• Logitech's advanced 2.4 GHz wireless: Dramatically reduces interference with 300 times faster data rate. Virtually no delays or dropouts.You're in control.• Adjustable-dpi laser engine: Provides two smooth-tracking modes (up to 1600 dpi) for customizable precision. Choose the dpi setting that's right for you—from pixel-precise to ultra-fast for customizable precision.• Stealth thumb button: Makes it easy to jump from one program to the next. One of ten programmable buttons that put total control at your fingertips.• Extended battery life: Minimize the hassle of changing batteries with nine months of battery life. On/Off button saves even more power. Battery-indicator light eliminates surprises.System Requirements:PC• Windows XP or Windows Vista• USB portMac• Mac OS X 10.3.9 or later• USB port
Specification Description
Model 910-000718, 910000718, NP107AA#ABA
UPC 097855050717
Connection Type Wireless
Movement Detection Laser
Movement Resolution 1600 dpi
Logitech MX 1100 Cordless Laser Mouse Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 8, 2009
Logitech MX 1100 Cordless Laser Mouse Reviews
Most helpful positive review
Most helpful negative review
5.0
Nice Accurate Mouse
"This is a large mouse that I find very comfortable with my large paws. I have had a Logitech MX Revolution since 2006 on my desktop and decided to upgrade my laptop mouse from a small Dell travel mouse to the MX-1100. I did not get another MX due to the docking station which would not go well with the laptop. There were some negative comments on the Logitech forum page where people said they found the mouse poi..." Read Full Review »
Aug 03, 2009 by Gil
See more positive Logitech MX 1100 Cordless Laser Mouse reviews
1.0
Software does not meet cost
"I have been dealing with Logitech Support trying to get this software to properly install for 3 weeks now. None of the extra features are working without this software, making the expense related to this product not nearly appropriate. As a simple wireless mouse, it is satisfactory... although it does drop signal occasionally. In my opinion, it is not worth the price...." Read Full Review »
Nov 08, 2009 by Disappointed in Logitech Software
See more negative Logitech MX 1100 Cordless Laser Mouse reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
1.0
    Pros
  • Accurate Tracking
  • Comfortable Design
  • Fast Response
  • Glides Smoothly
  • Great Features
    Cons
  • Catches Easily
  • Limited Surface Compatibility
    Best Uses
  • Professional
As a simple wireless mouse, it is satisfactory... although i …"  Read Full Review »
Was this Computer Mice review on the Logitech MX 1100 Cordless Laser Mouse helpful to you?
Nov 8 2009
New York, NY
I am:
  • Power user
Reviewed at:
Price: $64.95
Nice Accurate Mouse
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Works On Any Surface
    Cons
  • None
    Best Uses
  • Everyday Use
  • Gaming
"This is a large mouse that I find very comfortable with my large paws. I have had a Logitech MX Revolution since 2006 on my desktop and decided to upgrade my laptop mouse from a small Dell travel mouse to the MX-1100. I did not get another MX due to the docking station which would not go well with t …"  Read Full Review »
Aug 3 2009
Gil
Asheville, NC
I am:
  • Power user
Reviewed at:
Price: $64.95
Best Logitech Mouse Ever!
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Professional
  • Web Browsing
"I have one at work and one at home. Extremely comfortable; no hand fatigue. Great that there is a switch right on top to control if the wheel rolls freely, moving super-fast through pages or is racheted for finer movements. In previous Logitech mice the adjustment was underneath the mouse. Has 10 di …"  Read Full Review »
Jul 8 2009
ResearchPen
Chattanooga, TN
I am:
  • Power user
Reviewed at:
Price: $64.95
[1 of 1 customers found this review helpful]
Excellent Ergonomic Choice
5.0
    Pros
  • Durable
  • Easy Connectivity
  • Ergonomic
  • Versatile
    Cons
  • None
    Best Uses
  • Gaming
  • Home
  • Multimedia
  • Office
"After using an undersized MS notebook mouse for a few months, I began to develop severe pain in my wrist and thumb. I shopped around, and finally decided on the MX-1100. I couldn't be happier. It fits comfortably in my hand, and the software allows a high level of customization for buttons and tr …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Apr 29 2009
Skillet the Conqueror
Gueydan, LA
I am:
  • Power user
Reviewed at:
Price: $64.95
Best mouse ever!
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Professional
"Absolutely the best mouse I've ever had. It's comfortable in your hand, fast and responsive, lots of features, programmable buttons. I love it and strongly recommend. "
Sep 21 2009
Michael S
Staten Island
I am:
  • Power user
Reviewed at:
Price: $64.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
