Logitech Illuminated Keyboard with PerfectStroke Key System
#1
4.7
based on 92 reviews
Ratings Distribution
5 star
90
4 star
18
3 star
2
2 star
1
1 star
3
Category Average
4.1
Low Price:
$64.95 at B&H Photo Video
$67.99 at Best Buy
Find it at Amazon
$64.95 - $83.00
from 10 stores
More Images
Pros
  • Comfortable design (34)
  • Quiet (29)
  • Great features (27)
  • Reliable (25)
  • Highly compatible (22)
  • Easy to clean (18)
  • Easy setup (2)
  • Backlight (1)
  • Easy to use (1)
  • Feels great (1)
See less See more
Cons
  • Limited compatibility (2)
  • Function keys are useless (1)
  • Hard to clean (1)
  • Inadequate features (1)
  • Keys are close together (1)
  • No hibernation control (1)
  • No scroll lock button (1)
  • No volume knobe (1)
  • Non-standard layout (1)
  • Requires powered usb hub (1)
Best Uses
  • Professional (25)
  • Web browsing (20)
  • Financial (15)
  • Gaming (7)
  • Travel (2)
  • Upgrade (2)
  • All computer work period (1)
  • Education (1)
  • Greate feel (1)
  • No user guide or layout (1)
Provided by CameraWorld.com
You've just gotten home. It's dark but you still have e-mails to write, people to chat with, blogging to do. While everyone else is in the dark, you're getting ready to shine. Don't you deserve a keyboard that shines with you?
Type easily-even in the dark.
  • Bright, laser-etched, backlighted keys: Provide precise illumination that can be adjusted to suit your needs.
  • Only the characters are illuminated, so you get just the right amount of light.
    Cutting-edge design.
  • Ultra-thin, 9.3 mm profile and transparent frame: Make a bold statement and add an elegant touch to any desk.
  • Sleek, minimalist design: The ideal combination of form and function, the Logitech Illuminated Keyboard gives you exactly what you need from a keyboard.
    First-class comfort and control.
  • PerfectStroke key system: Gives you more key travel than typical notebook keyboards. Research shows that a longer distance required for each keystroke (key travel) improves your typing experience. Every stroke is comfortable, fluid, and silent. Tested for up to 10 million keystrokes.
  • Soft-touch palm rest and full-size key layout: Make your typing experience more comfortable-even after extended use.
  • One-touch multimedia controls: Includes volume controls for music and video. Enjoy instant access to your favorite applications, including your media player, e-mail, browser, and more.
  • Specification Description
    Model 920-000914, 920000914
    UPC 097855054548
    Compatibility PC
    Connectivity Type Wired
    Device Type Keyboard
    Select Keyboards
    Logitech Illuminated Keyboard with PerfectStroke Key System Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 17, 2009
    Logitech Illuminated Keyboard with PerfectStroke Key System Reviews
    Most helpful positive review
    [10 of 10 customers found this review helpful]
    Most helpful negative review
    [1 of 1 customers found this review helpful]
    4.0
    "This is the best quality keyboard that I've used from Logitech. The feel of the keys is much firmer compared to other Logitech keyboards. The layout is closer to a laptop than a traditional desktop: the keys are a bit closer together than in many PC or Mac keyboards. If you're used to wider spaced keys, this board will take only a bit of time to get use to using. One caveat: The keyboard cannot be used to place ..." Read Full Review »
    Feb 27, 2009 by The Practical Desk
    See more positive Logitech Illuminated Keyboard with PerfectStroke Key System reviews
    1.0
    BIOS Problems
    "Pretty nice keyboard but I've tried it on three different brands/models of computers and on two of them the keyboard is not reconized by the BIOS prior to the operating system start. That means that you can' change the boot order, start Windows in safe mode or make changes to the BIOS. Other USB keyboards work fine...." Read Full Review »
    Nov 09, 2009 by Old Man
    See more negative Logitech Illuminated Keyboard with PerfectStroke Key System reviews
    Displaying 1 - 5 of 92 Reviews
    Show
    Sort by
    Solid keyboard, some quirks
    4.0
      Pros
    • Comfortable Design
    • Highly Compatible
    • Notebook-style keys
    • Quiet
    • Reliable Performance
      Cons
    • Difficult To Clean
      Best Uses
    • Gaming
    • Professional
    "I use this keyboard primarily to play games and code - I really appreciate the short key throw (akin to a notebook, for a similar typing experience) and slim profile. They did make some modifications to the standard keyboard layout, though, including relegating the right-click key to function-prints …"  Read Full Review »
    Was this Computer Keyboard review on the Logitech Illuminated Keyboard with PerfectStroke Key System helpful to you?
    Nov 10 2009
    John
    Alexandria, VA
    I am:
    • Power user
    Reviewed at:
    Price: $64.95
    GREAT KEYBOARD
    5.0
      Pros
    • Easy To Clean
    • Great Features
    • Highly Compatible
    • Quiet
    • More »
      Cons
    • None
      Best Uses
    • Financial
    • Gaming
    • Professional
    • Traveling
    • Web Browsing
    "I love this keyboard! Logitech got it right.
    Very thin design that looks great and makes for very comfortable typing. Logitech's PerfectStroke key system feels great. The keys have a very positive feel with just the right amount of travel and resistance. Feels like a laptop keyboard, which I've …"  Read Full Review »
    Nov 8 2009
    dirkfallows
    I am:
    • Power user
    Reviewed at:
    Price: $64.95
    Excellent choice!
    5.0
      Pros
    • Easy To Clean
    • Great Features
    • Highly Compatible
    • Quiet
    • More »
      Cons
    • None
      Best Uses
    • Professional
    • Web Browsing
    "I currently live on campus and as of late am using a dual monitor setup. In order to have enough work space I have to push my laptop to the corner of my desk, creating a very awkward typing position.
    This Logitech Illuminated keyboard was a perfect fix for my problem. The keyboard has a laptop k …"  Read Full Review »
    Nov 3 2009
    Brendan
    Tampa, FL
    I am:
    • Power user
    Reviewed at:
    Price: $64.95
    Great for late night use.
    5.0
      Pros
    • Highly Compatible
    • Quiet
      Cons
    • None
      Best Uses
    • Gaming
    • Professional
    • Web Browsing
    "This keyboard is by far the best one I've ever used. The keys are illuminated allowing you to leave the lights off. For mmo gaming this is a must have. The keys are ultra quiet. Nothings worse than having to hear the anoying clacking of keys while you type. And with the keys clealy visable even in z …"  Read Full Review »
    Nov 13 2009
    Steve
    Austin, TX.
    I am:
    • Power user
    Reviewed at:
    Price: $64.95
    Excellent keyboard
    5.0
      Pros
    • Great Features
    • Quiet
      Cons
    • None
      Best Uses
    • Professional
    "Took a little getting use to the keys but once I did much better feel than any other keyboard I have used. More like a quality laptop keyboard than a desktop keyboard. The illumination is well done and great for late night sessions. Quiet and reliable typing. Also stylish if that matters.
    O …"  Read Full Review »
    Nov 11 2009
    Bit flipper
    Oxford, CT
    I am:
    • Power user
    Reviewed at:
    Price: $64.95
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
