Logitech Harmony One Remote Control
#1
4.7
based on 285 reviews
Ratings Distribution
5 star
231
4 star
45
3 star
2
2 star
4
1 star
3
Category Average
4.2
$182.99 - $245.00
from 16 stores
More Images
Pros
  • Ergonomic design (63)
  • Nice button configuration (63)
  • Easy setup (60)
  • Nice features (51)
  • Durable (33)
  • Easy to program (33)
  • Strong signal (20)
  • Highly compatible (8)
  • Easy to use (7)
  • Reliable (6)
See less See more
Cons
  • Difficult to program (3)
  • Pricey (3)
  • Weak signal (3)
  • Incompatible (2)
  • No rf (2)
  • Activities sometimes off (1)
  • Can't use with ps3 (1)
  • Complex and expensive (1)
  • Database incomplete (1)
Best Uses
  • High-end equipment (46)
  • Upgrade (40)
  • Replacement (33)
  • Everyday (7)
  • Home (6)
  • Domestic harmony (1)
  • Great for the wife (1)
  • Home entertainment (1)
  • Home theater (1)
  • Home theatre (1)
Provided by ClubMac
Harmony One Advanced Universal Remote One-touch simplicity for your home entertainment. Enjoy easy, one-touch access to the home-entertainment activities you love. Allow you to find channel - even in the dark. One-touch simplicity for your home entertainment.Simplify your home entertainment.
  • One-touch access to your entertainment: Enjoy easy, one-touch access to the home-entertainment activities you love. Want to watch a DVD? One simple press of the touch screen and the Harmony One remote does the rest.
  • Replaces up to 15 remotes: Reduce the clutter and complexity of your living room.
Exceptionally user-friendly design.
  • Full-color touch screen: Gives you easy, one-touch access to any entertainment activity—such as watching a DVD, watching TV, listening to music, and more.
  • Sculpted, backlighted buttons in logical zones: Allow you to find the right channel—even in the dark. Ergonomic design: Fits comfortably in your hand.
  • Rechargeable design: Eliminates the worry about replacing batteries.
Sophisticated setup help, long-term solution.
  • Guided online setup: Helps you when you need it. You don’t have to be an expert. Helpful online setup software. Live customer support team.
  • World’s largest A/V control database: Be confident your Harmony remote can control virtually any home-entertainment device you have today or buy tomorrow. Online database supports more than 225,000 devices from more than 5,000 brands – and the list grows larger every day.
System Requirements:PC&nbsp&nbsp&nbsp&nbsp• Windows 2000, Windows XP, Windows Vista&nbsp&nbsp&nbsp&nbsp• USB port &nbsp&nbsp&nbsp&nbsp• CD-ROM drive &nbsp&nbsp&nbsp&nbsp• Internet access Mac&nbsp&nbsp&nbsp&nbsp• Macintosh OS X 10.3 or later &nbsp&nbsp&nbsp&nbsp• USB port &nbsp&nbsp&nbsp&nbsp• CD-ROM drive &nbsp&nbsp&nbsp&nbsp• Internet access
Specification Description
Model 915-000035, 915000035, LOGHARMONYONE, N95848
UPC 097855046673
Battery Type Product
Benefits Simple activity control so you can control your entire home theater with the touch of a buttonEasy setup with an intuitive wizard to
Cables Included USB
Capacity UOM mAh
Chemistry Lithium Ion
Connections USB
Country Of Origin China
Description Header Feel the power of Harmony.
Display Catalog Number 55031409
Enclosure Color Black
End Product Indicator Yes
Included in the Box Harmony® One remote controlCharging stationUSB cableAC adapterRechargeable lithium ion battery
Manufacturer Labor Warranty 12
Manufacturer Part Number 915-000035
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 915-000035
Operating Temperature UOM ° F
Power Device Rechargeable lithium ion battery
Product Depth 8.75
Product Dimensions UOM inches
Product Height 1.3
Product Type Pushbutton remotes
Product Weight 6
Product Weight UOM ounces
Product Width 2.3
Rechargeable Yes
Size Specialty
Supported Languages English
Technology IR
Logitech Harmony One Remote Control Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 12, 2009
Logitech Harmony One Remote Control Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Amazing technology, and easy to use!
"This remote is amazing. I have totally fallen in love with it. It was easy to set up, but I spent more time with the wizard than I needed to. Just get past that by choosing a TV or something, and get into the after-wizard configuration. That's where you'll be able to make it do anything you want it to. It can handle up to 15 devices, and can even handle duplicate types of devices. For instance, I have my main ..." Read Full Review »
Nov 10, 2009 by L3
See more positive Logitech Harmony One Remote Control reviews
2.0
I would not recomend this product .
"Product will function very well if it is the only remote that you use. If equipment is turned on or off by some other remote or manually, the Harmony One remembers the last state the equipment was in when it was used and basically forces you to get back to that state to operate normally. There is no way to select an activity (set a state) without it attempting to set the equipment to that state based on what i..." Read Full Review »
Feb 19, 2009 by Jim
See more negative Logitech Harmony One Remote Control reviews
Displaying 1 - 5 of 285 Reviews
Show
Sort by
5.0
    Pros
  • Can Store Duplicate Types
  • Durable
  • Easy To Change Devices
  • Easy To Program
  • Easy To Set Up
  • More »
    Cons
  • Setup Wizard is Only OK
    Best Uses
  • High-End Equipment
  • Multi-Button Scripting
  • Remote Consolidation
  • Replacement
  • Upgrade
It was easy to set up, but I spent more time with the wizard than I needed to. Just get past that by choosing a TV or something, and get into the after-wizard configuration. That's where you'll be able to make it do anything you want …"  Read Full Review »
Was this Remote Control review on the Logitech Harmony One Remote Control helpful to you?
Nov 10 2009
L3
Yakima, WA
I am:
  • Gearhead
Reviewed at:
Price: $196.88
Best remote at any price
5.0
    Pros
  • Customize logos
  • Easy To Program
  • Easy To Set Up
  • Ergonomic Design
  • Nice Button Configuration
  • More »
    Cons
  • Battery life
    Best Uses
  • Replacement
  • Upgrade
"The Harmony One is the last remote control that you are ever going to need. Capable of controlling 15 devices, it's intuitive design and ease of programming makes setup a snap. I control 10 components, including three DVR's,and I can switch back and forth seamlessly between devices with just a light …"  Read Full Review »
Nov 12 2009
micmason
Annapolis,MD
I am:
  • Home Theater Enthusiast
Reviewed at:
Price: $182.99
Doesn't get much easier...
5.0
    Pros
  • Easy to operate equipment
  • Easy To Program
  • Easy To Set Up
  • Nice Features
    Cons
  • None
    Best Uses
  • Replace all those remotes
"I've had 2 programmable remotes before this one. I felt like I needed a PhD to program and operate. With the Logitech Harmony One it was extremely easy. As long as you know the manufacturer & model # of your components, plus have a computer with access to the internet, you'll be up and running …"  Read Full Review »
Nov 10 2009
ticketmaster
Gahanna, OH
I am:
  • Med technical capability
  • Practical
Reviewed at:
Price: $196.88
OK, hoped for better but happy overall.
4.0
    Pros
  • Backlight
  • Good quality
  • Good Website
  • Plugin charging base
  • Remote layout
    Cons
  • Difficult To Use
  • Not consistant
    Best Uses
  • Home
"This remote can be great or just OK depending on your system. The remote would not switch my reciever properly from a component device to an HDMI device so I bought a simple switcher for twenty bucks and ran all input devices with HDMI cables on one setting (DVD) on the reciever and setup the remote …"  Read Full Review »
Jan 31 2009
Steve
Spokane, WA
I am:
  • Hobbyist/Enthusiast
Well worth the price! Power, conveniece
5.0
    Pros
  • Easy To Program
  • Easy To Set Up
  • Ergonomic Design
  • Nice Features
    Cons
  • Software is slow
    Best Uses
"The absolute best thing about this remote is the Internet device database. You just punch in the model number of your TV, A/V receiver, DVD player, etc, and they're magically programmed into the remote. I had my entire system setup in the remote in less than a half hour, including TV, A/V receiver …"  Read Full Review »
Sep 25 2009
Nostalgia
Jefferson, NJ
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
Price: $196.88
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
