Logitech Harmony Advanced Universal Remote for Microsoft XBox 360
#6
4.7
based on 58 reviews
from $81.00 - $399.99
Ratings Distribution
5 star
44
4 star
13
3 star
1
2 star
0
1 star
0
Category Average
4.2
More Images
Pros
  • Easy setup (3)
  • Nice features (3)
  • Strong signal (3)
  • Durable (2)
  • Nice button configuration (2)
  • Ergonomic design (1)
See less See more
Cons
  • Lights up with vibration (1)
  • Odd shape (1)
  • Remote design (1)
Best Uses
  • High-end equipment (2)
  • Home (2)
  • Replacement (2)
  • Upgrade (2)
  • Entertainment center (1)
  • Office (1)
Provided by Beach Audio
All the right one-touch activity buttons for your Xbox--and your
entire home entertainment system!
The Harmony Advanced Universal Remote for Xbox 360 makes gaming
easy. Simply choose "Play Xbox 360" and the Harmony will
automatically power on your TV, Xbox 360 and stereo receiver, then
set all the inputs, and even press "Play"! Logitechs patented
Smart State Technology gives you one-touch control over your
console.
And like all Logitech Harmony remotes, the Harmony 360 helps make
home entertainment accessible to the entire family. An intuitive
setup wizard will walk you through the steps to configure the
remote for your audio/video system. An online database containing
the remote codes for more than 2,500 manufacturers and 80,000
devices ensures that your Harmony Advanced Universal Remote will be
compatible with your favorite components.
Includes Harmony Remote, USB cable, Installation CD, Installation
guide, (4) AAA batteries.
* Use the special Xbox buttons. The Harmony 360 includes convenient Y, X,
A, and B buttons and media center controls for your Xbox gaming.
* Control your devices: past, present and future! The Harmony 360 gives
you full control of up to 12 devices. The Logitech database contains over
2,500 manufacturers and over 80,000 IR devices -- everything from HDTVs
to PVRs, DVD players to VCRs, and game consoles to lighting controls! The
database is updated daily, so it is guaranteed to work with all models
and manufacturers.
* Set it up in a snap! The Harmony Set-up Wizard does the programming, so
you do not have to. Just connect your remote to your computer and answer
a few questions about how you currently use your audio/video and
entertainment components. Logitechs patented Smart State Technology does
the rest.
* Control your entire home entertainment system with just one button.
Choose the "Play Xbox" activity and the Harmony Remote will power on your
TV, Xbox 360, stereo receiver, set all the inputs, and even press "Play!"
* Help Button -- One touch leads you through simple troubleshooting to
solve your problem.
* Fully backlit keypad -- Backlighting makes the buttons and interactive
display glow brightly for easy use in the dark.
-- SPECIFICATIONs ----------------------------------
REQUIREMENTS - PC : IBM compatible PC
Windows 98SE, 2000, Me, XP
USB port
CD-ROM drive
Internet access
10MB free hard drive space
MAC: Macintosh PC
Macintosh OS X 10.2 or later
USB port
CD-ROM port
Internet access
www.logitech.com
Specification Description
Model 097855037145, 966200, 966200-0403, 966200x
UPC 097855036889
Accessory Indicator Yes
Benefits Connect the remote to your computer and the Web wizard walks you step-by-step through a simple setupSmart State Technology®: easi
Capacity UOM mAh
Country Of Origin China
Display Catalog Number 55024479
Included in the Box Logitech® Harmony Advanced Universal Remote for Xbox 360USB cableInstallation CDInstallation guideAAA
MAC Operating System Support Mac OS X 10.2 or later
Manufacturer Labor Warranty 12
Manufacturer Part Number 097855037145
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 097855037145
Operating Temperature UOM ° F
PC Interface Supported USB
PC Operating System Support Windows® 98, 2000, Me, XP
Product Type Xbox 360
Required to function Windows® (98, 2000, Me, XP) or Mac OS (X 10.2 or later)CD ROM driveInternet accessUSB port10MB free ha
Software Included Yes
Supported Languages English
Logitech Harmony Advanced Universal Remote for Microsoft XBox 360 Questions
Questions and Answers
Where to Buy
$399.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$81.00
$81.99
Free Shipping on Orders Over $299 ends 07/03/14
Show all 4 stores
_
Product Reviews
Last update: Jul 20, 2009
Logitech Harmony Advanced Universal Remote for Microsoft XBox 360 Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Awesome Entry Level Universal Remote
"The remote is very comfortable in your hand! It is very light and all of the buttons are easily reachable while just using one hand! The back of the remote is covered in an anti slip, rubber like material that feels pretty nice. My only concern is the bottom of the remote is pretty thick so that it can accommodate the batteries but as the case of the remote goes up toward the screen, the overall thickness of the..." Read Full Review »
Apr 29, 2008 by brettday2002
See more positive Logitech Harmony Advanced Universal Remote for Microsoft XBox 360 reviews
3.0
Universal Remote
"Pros Easy to set up, Easy to operate, Works well with all my equipment. Cons After having this remote for 2 weeks, the screen went blank and no longer worked. So I had to contact Dell and get a replacement. So far the new remote hasn't given me any problems. Additional Thoughts This remote is nice to have. I just hope my replacement doesn't break like my first one...." Read Full Review »
Oct 08, 2007 by Mikeyb2204
See more negative Logitech Harmony Advanced Universal Remote for Microsoft XBox 360 reviews
Displaying 1 - 5 of 58 Reviews
Show
Sort by
5.0
"The remote is very comfortable in your hand! It is very light and all of the buttons are easily reachable while just using one hand! The back of the remote is covered in an anti slip, rubber like material that feels pretty nice. My only concern is the bottom of the remote is pretty thick so that it …"  Read Full Review »
Was this Remote Control review on the Logitech Harmony Advanced Universal Remote for Microsoft XBox 360 helpful to you?
 Report Abuse  (1)  (0)  0 comments
Apr 29 2008
brettday2002
Oklahoma City
Great Buy, good responsiveness.
4.0
    Pros
  • Easy To Set Up
  • Nice Button Configuration
  • Nice Features
  • Strong Signal
    Cons
  • Odd shape
    Best Uses
"This product is great. It is easy to set up, easy to operate and responds very quickly. I had another model that I could not use because the response was too slow. The button layout is intuitive and the remote replaces all of your other ones.
The only problem I have is with the shape and the lig …"  Read Full Review »
Mar 7 2007
Brian
Tampa
[2 of 2 customers found this review helpful]
Harmony Remote (xbox 360)
4.0
"Pros
easy to use, easy to setup
excellent compatibility allows you to setup Activities, eliminating switching devices and activating one by one
sleek design
infrared "learning" feature for remote functions that do not transfer properly
USB connection to PC for remote setup
Cons
refuses to turn of …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 27 2006
RWPF
New England
Reviewed at:
Unbelievable!!!!
5.0
"When we bought this remote I thought it would just be another universal remote that would hopefully at least turn everything on and off and control the volume on the TV and Receiver. I couldn't believe what it could actually do! You don't have to punch in codes for individual components. Just get th …"  Read Full Review »
Nov 25 2007
DRCM
Florida
Great purchase to get rid of clutter
5.0
"I recently purchased the Harmony 360 remote hoping to get rid of the six separate remotes sitting on my coffee table. After having this remote for only a week, I think that it has already been worth what I paid for it. Setting this remote up is easy as pie, all you need is a computer with an interne …"  Read Full Review »
Sep 13 2007
aredkid
Grand Forks, North Dakota
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
