Logitech ClearChat Pro USB Headset
#308
3.7
based on 82 reviews
Ratings Distribution
5 star
47
4 star
35
3 star
12
2 star
10
1 star
16
Category Average
4.0
$34.95 - $48.99
from 16 stores
More Images
Pros
  • Easy to use (33)
  • Great sound quality (33)
  • Comfortable (32)
  • Quality microphone (28)
  • Added features (16)
  • Compact design (8)
  • Move mike when not in use (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Bulky design (5)
  • Uncomfortable (5)
  • Poor sound quality (4)
  • Poor microphone (2)
  • No volume control (1)
  • Set up a bit touchy (1)
  • Too small for large head (1)
  • Unusable (1)
  • Usb cord a bit short (1)
  • Volume switch (1)
Best Uses
  • Typing & talking (25)
  • Mobility (5)
  • Gaming (3)
  • Listening to music (2)
  • Music (2)
  • All (1)
  • Chat and recording voice (1)
  • Chatting (1)
  • Games (1)
  • Gaming and talking (1)
Provided by CameraWorld.com
High-performance digital audio for PC calling, music, and gaming.
Laser-tuned audio drivers deliver premium acoustic performance. Headset-based, SoundSwitch equalizer offers three presets, which instantly optimize audio for Internet communications, music, or PC gaming.
A rotating, noise-canceling microphone puts the focus on your voice by reducing background chatter, and easy-access volume and mute controls on the headset let you quickly adjust audio.
Performance
  • Laser-tuned audio drivers: Advanced laser design technology maximizes acoustic performance.
  • SoundSwitch equalizer: Instantly optimizes EQ settings for Internet communications, music, or PC gaming. Convenient control switch located on headset.
    Control and Convenience
  • Noise-canceling microphone: Reduces background noise for clear conversation and voice commands.
  • Flexible boom: Allows precise positioning. Microphone rotates out of the way when you?re listening to music or watching a movie.
  • Mute indicator: Microphone emits soft, red glow when muted.
  • Quick-access audio controls on the headset: Instantly adjust the volume or mute the microphone.
  • Digitally enhanced USB audio: Experience premium sound clarity with the simplicity of a single USB, plug-and-play connection.
  • Specification Description
    Model 981-000010, 981000010
    UPC 097855046857
    Connection Type Cable
    Connectivity Technology Wired
    Design Type Over-the-head
    Headphones Form Factor Ear-cup
    Headphones Type Headphones - binaural
    Manufacturer Warranty 2 years warranty
    Microphone Microphone - boom
    Microphone Operation Mode Mono
    Product Description Logitech ClearChat Pro USB - headset
    Product Type Headset - wired
    Recommended Use PC multimedia, home audio system
    Response Bandwidth 20 - 20000 Hz
    Sensitivity -42 dBV/Pascal
    Sound Mode Stereo Output
    Sound Output Mode Stereo
    Logitech ClearChat Pro USB Headset Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 22, 2009
    Logitech ClearChat Pro USB Headset Reviews
    Most helpful positive review
    [4 of 4 customers found this review helpful]
    Most helpful negative review
    [1 of 1 customers found this review helpful]
    4.0
    Great headphones, great value
    "I use this for Skype and for listening to music (Rhapsody). Music sounds fabulous on these headphones. They are a bit bulky for my briefcase, but in the office they are great--and they block out a little bit of extraneous noise too. The microphone and Skype setup was a bit touchy because the mic seems to have different sensitivity than the one it replaced, but once I got the sound and the boom mic properly calib..." Read Full Review »
    Jul 23, 2008 by Tom
    See more positive Logitech ClearChat Pro USB Headset reviews
    2.0
    Design flaw ruins a great product
    "First off, the price listed online is three dollars cheaper than what I paid for it an hour ago. I am in the market for a quality headset for VoIP use and based on reviews at this site I figured I'd spend some money and get a quality product. The sound from the headphones is very full and rather enjoyable. However, I found the microphone on this headset too short and I wasn't able to adjust the microphone close ..." Read Full Review »
    May 03, 2009 by Curtis
    See more negative Logitech ClearChat Pro USB Headset reviews
    Displaying 1 - 5 of 82 Reviews
    Show
    Sort by
    Great multi-purpose headset.
    4.0
      Pros
    • Comfortable
    • Easy To Use
    • Great Sound Quality
      Cons
    • No volume control
      Best Uses
    • Gaming
    • Typing & Talking
    • VOIP
    "This is a surprisingly good headset for its intended purposes. The VOIP sound quality is outstanding for Skype as well as other internet communication (which is as far as my expectations went). The boom mic is conveniently situated out of my face, and the earphones are light and comfortable for th …"  Read Full Review »
    Was this Computer Speaker & Headphones review on the Logitech ClearChat Pro USB Headset helpful to you?
    Mar 7 2009
    I am:
    • Quality Oriented
    [2 of 2 customers found this review helpful]
    Very disapointed
    1.0
    "I bought this headset about 2 weeks ago and am so tired of it. I use it for work and everything is done VOIP. I can hear just fine on it but even with the volume up as high as it will go I have to scream for my customers to hear me. I've also had problems with the Logitech headset that goes behind n …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Nov 29 2007
    Amy4893
    Dallas TX
    Good, if you prefer malfunctioning.
    1.0
    "I went out approximately a month ago to my local Best Buy and I bought these LogiTech headset. I never had a headset before, but I needed one for Gaming purposes. They looked like a good pair for $40, and I as decieved.
    When I first got it, it worked okay; it was good enough for my standards. It was …"  Read Full Review »
    Mar 22 2008
    ThomasC
    Undisclosed
    AMAZING. Okay I bought ...
    5.0
    "AMAZING. Okay I bought these for only 49.99 Canadian dollars, they are 80.99 in Future Shop (Stupid future shop). Okay listen. Comes settings for Music/Gaming/Chat all on the Headphones, so you just adjust it when you want it. Also comes with the microphone mute and volume adjuster. All of this on t …"  Read Full Review »
    Mar 31 2009
    Undisclosed
    Don't waste your time with this!
    1.0
    "This headset is a complete waste of money! I bought it because I host an online radio talkshow and everyone listening complained about my other headset's mic causing echos and breakups. Well, not only is this headset TOTALLY uncomfortable, it is NOT worth the money. I've experienced nothing but prob …"  Read Full Review »
    Jun 27 2009
    RogueWolf
    Jackson, Mi
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
