Logitech AudioHub 2.1 Speaker System
4.5
based on 23 reviews
Ratings Distribution
5 star
15
4 star
7
3 star
0
2 star
0
1 star
1
Category Average
4.0
More Images
Pros
  • Great sound quality (2)
  • Attractive design (1)
  • Comfortable (1)
  • Compact (1)
  • Compact design (1)
  • Easy to connect (1)
  • Easy to use (1)
See less See more
Best Uses
  • Frequent laptop locations (1)
  • Mobility (1)
Provided by Super Warehouse
Logitech AudioHub Notebook Speaker System with Integrated USB Hub delivers exceptional audio in a breakthrough design. The AudioHub combines a unique 2.1 one-piece speaker system and three integrated Hi-Speed USB ports in a compact design that fits neatly behind most notebooks. Offering notebook users exceptional digital audio- the AudioHub speaker system features an adjustable one-piece- three-chamber speaker system with an integrated subwoofer that creates balanced audio with clear highs and solid lows. And a useful Mute button turns off the sound without cutting power to the integrated USB hub. To help people manage their peripherals- the AudioHub offers three built-in Hi-Speed USB ports. And when people want to take their notebooks with them- the AudioHub makes it easy to disconnect their setup by simply unplugging the USB cord attached to the computer. On the base of the AudioHub- a convenient cable management system allows people to easily pass cables from their devices to a USB port. Along the back of the AudioHub- a cable hook efficiently manages cable clutter. At just three and a half inches in height- the AudioHub presents a sleek- low profile design that fits almost anywhere in the home - even in the living room. And the AudioHub speaker system's unique adjustable-width speakers effectively position the satellites around most notebooks.
  • Device Type: Portable Speakers
  • Compatibility: iPod Nano- MP3 Players - laptop
  • Color: Black
  • Power Device: Power supply- internal
  • Warranty: Two Year Limited
Specification Description
Model 980-000101
UPC 097855046703
Surround Sound Type 2.1
Logitech AudioHub 2.1 Speaker System Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: AudioHub 2.1 Speaker System
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 1, 2009
Logitech AudioHub 2.1 Speaker System Reviews
Most helpful positive review
Most helpful negative review
5.0
I suppose it depends on ...
"I suppose it depends on what you buy this for. If you want a easily portable speaker system this is not it. But it is far better sound quality. There have been negative comments on the usb hub not being easily accessible, power cord tying it to an AC outlet. So let me put my opinion in on that first. For this quality speakers I would rather have this bar then seperate speakers that can easily be damaged. It is ..." Read Full Review »
Sep 18, 2009 by Rich
See more positive Logitech AudioHub 2.1 Speaker System reviews
1.0
this is actually a great ...
"this is actually a great speaker system. At this price its steal believe me. The sound is clear and crisp. I cant find anything bad about this but they could have at least added a subwoofer controller to controll the bass but lets just leave that to your equalizers. this is definately a great product and once you use it you wont want to listen to your original laptop speakers ever again..." Read Full Review »
Feb 05, 2009 by chillax
See more negative Logitech AudioHub 2.1 Speaker System reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
5.0
"I suppose it depends on what you buy this for. If you want a easily portable speaker system this is not it. But it is far better sound quality. There have been negative comments on the usb hub not being easily accessible, power cord tying it to an AC outlet. So let me put my opinion in on that first …"  Read Full Review »
Was this Computer Speaker & Headphones review on the Logitech AudioHub 2.1 Speaker System helpful to you?
Sep 18 2009
Rich
Undisclosed
Reviewed at:
ok all in all this is an ...
5.0
"ok all in all this is an excellent pair of speakers with a sub built right into it i agree it is to big to fit into a backpack but this is not the only problem i had after awhile of wrapping up cord on the power supply the cord started to ware and fray so what i did is solder the wire back together …"  Read Full Review »
Oct 1 2009
borris
Undisclosed
Reviewed at:
Having read other ...
4.0
"Having read other reviews, I knew these are not portable -- they're not. Other reviewers had a variety of comments about the sound that seem to contradict each other. I suspect that has much to do with the music they like. I happen to like all types of music, so my comments will be music agnostic …"  Read Full Review »
Jan 16 2009
DaJamMaste
Undisclosed
Reviewed at:
Logitech 2.1 Speaker System
4.0
"While looking for a speaker system a friend recommend Logitech to upgrade my laptop speakers. I located the 2.1 system at Overstock at a great price compared to all other sites. They speakers system is more than I expected. The quality is great; the installation is simple and the quality of sound wa …"  Read Full Review »
May 27 2009
Rad69
Phoenix, Arizona
Reviewed at:
It's True!
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Frequent Laptop Locations
"I like my hp laptop with MS Media Center except for its puny speakers. This product makes a world of difference when watching movies on the laptop or listening to music. "
Aug 11 2008
The Old Doc
Ann Arbor MI
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
