Close Login Module
Join
Linksys WUSB600N Dual-Band Wireless-N Network USB Adapter
#21
4.1
based on 76 reviews
Ratings Distribution
5 star
65
4 star
23
3 star
3
2 star
6
1 star
14
Category Average
3.9
$67.99 - $75.99
from 16 stores
More Images
Pros
  • Easy setup (37)
  • Fast connection speed (31)
  • Fast (29)
  • Reliable connection (26)
  • Secure connection (25)
  • Highly compatible (2)
  • Compact (1)
  • Improves performance (1)
  • Reliable (1)
  • Secure (1)
See less See more
Cons
  • Unreliable connection (7)
  • Slow connection speed (3)
  • Difficult to set up (2)
  • Died after 6 months (1)
  • Limited compatibility (1)
  • Need ssid broadcast on (1)
  • Poor distance strength (1)
  • Poor signal reception (1)
  • Poor software driver (1)
Best Uses
  • Home network (38)
  • Small networks (7)
  • Large networks (4)
  • Home networks (1)
  • Small offices (1)
Where to Buy
$67.99
$67.99
$69.17
Show all 16 stores
Product Reviews
Last update: Oct 30, 2009
Linksys WUSB600N Dual-Band Wireless-N Network USB Adapter Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
I highly recommend this product.
"At the present moment I'm using a second home computer almost 24 hours daily to download sports video;about 80Gigs worth every day. I needed a wireless adapter that was fast,secure, and reliable....and,just as important,could use both 2.5 and 5GHz Radio Bands. My home modem (FIOS) uses the 2.5 GHz band which resulted in numerous connectivity conflicts between my laptop and my wireless home phone due to both de..." Read Full Review »
Apr 05, 2009 by DPC_Guy
See more positive Linksys WUSB600N Dual-Band Wireless-N Network USB Adapter reviews
2.0
Good except for signal reception
"The setup is quick and easy and in use it works as expected with one major exception. It does not receive a good signal. I get better signal strength and distance with my built-in "G" antenna. However, if you are close enough to the router to get a signal, you do get better speed. I routinely get 216 Mbps as opposed to 54 with "G". However, I got 270 when using an Express Card on my old laptop. (This laptop ha..." Read Full Review »
Sep 05, 2009 by MLF
See more negative Linksys WUSB600N Dual-Band Wireless-N Network USB Adapter reviews
Displaying 1 - 5 of 76 Reviews
Show
Sort by
4.0
    Pros
  • Easy To Setup
  • Fast
  • Fast Connection Speed
  • Secure Connection
    Cons
  • None
    Best Uses
  • Home network
I needed a wireless adapter that was fast,secure, and reliable....and,just as important,could use both 2.5 and 5GHz Radio Bands. My home modem (FIOS) uses the 2.5 GH …"  Read Full Review »
Apr 5 2009
DPC_Guy
NY, NY.
I am:
  • High bandwidth user
Reviewed at:
Price: $74.99
2.0
    Pros
  • Easy To Setup
  • Secure Connection
    Cons
    Best Uses
  • Home network
However, if you are close enough to the router to get a signal, you do get better speed. I routinely ge …"  Read Full Review »
Sep 5 2009
MLF
NYC
I am:
[3 of 3 customers found this review helpful]
Terrific Product
5.0
"I had purchased a Netgear version of this product and had nothing but trouble with it. I had spent 2 days and multiple phone calls trying to install it.
When I took it back I purchased the Linksys. It is WONDERFUL! I literally plugged it in, and installed within 10 minutes.
It is compatible and Mi …"  Read Full Review »
Apr 29 2008
Alis
Seattle, WA
Short Life
2.0
    Pros
  • Easy To Setup
  • Fast
    Cons
    Best Uses
  • Home network
"In theory a good product, worked flawlessly for 6 months. Then the adapter began having intermittent problems maintaining a connection to my wireless router. Checked the firmware, network router, computer TCP/IP settings, etc. and determined that the adapter was at cause. Very poor product, would no …"  Read Full Review »
Aug 22 2009
JMH
New York, NY
I am:
Product Uses:Connecting ...
5.0
"Product Uses:Connecting with Friends, Gaming, work
Review:I had been researching for about a week or so before deciding on buying this adapter. I couldn't have been happier since I did. The WUSB600N USB adapter works great and picks up more wireless networks in my neighborhood than I knew there wer …"  Read Full Review »
Sep 21 2009
Raven76
Chicago
Reviewed at:
Price: $75.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$67.99
$67.99
$69.17
BizRate Rating Outstanding 9.4
$69.99
5% off orders at Abt.com
$69.99
Free Shipping on Orders Over $299
$69.99
$69.99
$1.99 Shipping on Orders Over $75
BizRate Rating Outstanding 9.1
$69.99
$1.99 Shipping On Orders Over $100 at TigerDirect
$72.99
$72.99
$74.00
BizRate Rating Outstanding 9.6
$74.99
No Tax Outside NY
$74.99
$74.99
Overstock.com Club O Deals!
$74.99
$75.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
