Close Login Module
Join
Linksys WRT-54GS Wireless Cable/DSL Router with Speedboost
4.1
based on 87 reviews
Ratings Distribution
5 star
111
4 star
62
3 star
15
2 star
9
1 star
16
Category Average
3.9
Pros
  • Easy setup (121)
  • Fast (92)
  • Highly compatible (86)
  • Secure (82)
  • Small (58)
  • Good value (11)
  • Easy to use (10)
  • Reliable (10)
  • Good performance (9)
  • Secure connection (4)
See less See more
Cons
  • Unreliable (16)
  • Slow (10)
  • Bulky (7)
  • Insecure (6)
  • 1st set up difficult wxp (1)
  • Can be a pain to set up (1)
  • Can't get it to work (1)
  • Can't set it up (1)
  • Cd setup no help (1)
Best Uses
  • Home (127)
  • Small office (43)
  • Secure networks (24)
  • Home network (4)
  • Dorm room (2)
  • Home networks (2)
  • Highly secure networks (1)
  • Home office (1)
  • Small offices (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: WRT-54GS Wireless Cable/DSL Router with Speedboost
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 26, 2009
Linksys WRT-54GS Wireless Cable/DSL Router with Speedboost Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Top Notch Router
"Best router I ever bought. I had two Netgear routers that were terrible....wouldn't hold a connection and constantly had to reset. They now both reside in the local landfill. I'd never buy Netgear routers again. I have NEVER had to reset my Linksys router once. This router broadcasts strong signals.....my neighbor at the end of the block picks up my Linksys. Make sure you enable encryption so the neighbors c..." Read Full Review »
Jul 27, 2007 by Zebra
See more positive Linksys WRT-54GS Wireless Cable/DSL Router with Speedboost reviews
1.0
Not impressed
"My girlfriend and I bought this router about a month and a half ago and after two weeks it just died. All the lights just stayed lit up and nothing would work. We wanted to return it to the store but didn't have the receipt because we were told at the store that it was very reliable. We then called Linksys and they told me they didn't know what was wrong and that they'll send me a new one. I have not received a ..." Read Full Review »
Aug 06, 2007 by Tom the gamer
See more negative Linksys WRT-54GS Wireless Cable/DSL Router with Speedboost reviews
Displaying 1 - 5 of 87 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Read this to know more about the router
4.0
    Pros
  • Fast
  • Highly Compatible
  • Secure
    Cons
    Best Uses
  • Home
  • Small Office
"Everyone that put one star is technologically stupid. I set this up when years ago when I was 15 years old and i was ok. The security part was a little annoying at first but I found out how to do it. Setting it up without security is easy. One of the best ways to set it up with security is to se …"  Read Full Review »
Oct 30 2007
EJ
MD
I am:
  • High bandwidth user
Strong Signal, Easily Drops Signal
4.0
    Pros
  • Easy To Set Up
  • Highly Compatible
    Cons
  • Insecure
    Best Uses
  • Home
"I bought the router about a year ago; since I had switched to cable internet service, and I wanted a home network set up. I have done some research on the router and have found some varied information. It seems that this is a very popular router, however, it is very easy to hack. Many connected syst …"  Read Full Review »
Dec 27 2007
BladeRunner1
Alexandria, VA
I am:
Very good product
5.0
    Pros
  • Fast
  • Highly Compatible
  • Secure
  • Small
    Cons
  • None
    Best Uses
  • Home
  • Small Office
"I have used many different routers and am very experienced in computers. This router has the longest range and speed for its price. I have had this router for nearly 3 years and it has not failed on me once. The only problem is the installation program that is not very good. Instead you can just …"  Read Full Review »
Apr 13 2008
EJ
MD
I am:
Not impressed
1.0
    Pros
  • Easy To Set Up
  • Fast
  • Secure
  • Small
    Cons
  • Unreliable
    Best Uses
  • Home
  • Small Office
"My girlfriend and I bought this router about a month and a half ago and after two weeks it just died. All the lights just stayed lit up and nothing would work. We wanted to return it to the store but didn't have the receipt because we were told at the store that it was very reliable. We then called …"  Read Full Review »
Aug 6 2007
Tom the gamer
St. Augustine, Fl
I am:
Reliable, easy setup, strong signal
5.0
    Pros
  • Easy To Setup
  • Fast
  • Fast Connection Speed
  • Reliable connection
  • Secure Connection
    Cons
  • None
    Best Uses
  • Home network
"Outstanding, typical Linksys reliability. Easy to set up, great signal strength. In fact, it's so great, my condo neighbor 2 units away can see my LAN. Very easy to protect, from WEP on up, a good idea unless you have a reason to be paying for your neighbor's Internet.
Recommendation: Since you w …"  Read Full Review »
Feb 8 2008
Chuckzilla
Fr. Flannigan's All Night Cafe
I am:
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
BizRate Rating Outstanding 9.1
$29.99
$1.99 Shipping On Orders Over $100 at TigerDirect
$29.99
$1.99 Shipping on Orders Over $75
$47.88
BizRate Rating Outstanding 9.6
$52.95
No Tax Outside NY
$68.99
Free Shipping on Orders Over $299
$69.99
$69.99
$74.99
BizRate Rating Outstanding 9.0
$76.65
$79.99
15% Off A Single Item at DicksSportingGoods!
$79.99
15% Off Orders at FogDog.com!
$79.99
15% Off Your Entire Order at MCSports.com!
$79.99
15% Off Your Entire Order at Olympia Sports!
$79.99
15% Off an Entire Order at Joe's Sports
$79.99
15% Off Orders at Pro Golf!
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
