Close Login Module
Join
Linksys WMP600N Dual-Band Wireless-N PCI Adapter
#35
3.9
based on 7 reviews
Ratings Distribution
5 star
8
4 star
4
3 star
1
2 star
1
1 star
2
Category Average
0.0
$69.36 - $81.99
from 8 stores
More Images
Pros
  • Easy setup (5)
  • Fast (5)
  • Reliable connection (5)
  • Secure connection (5)
  • Fast connection speed (4)
  • Easy to install (3)
  • Reliable (2)
  • Better than usb wifi (1)
  • Easy to use (1)
  • It takes strength to inst (1)
See less See more
Cons
  • Difficult to set up (1)
  • Unreliable connection (1)
Best Uses
  • Home network (5)
  • Small networks (3)
  • Indoor (1)
  • Upgrade (1)
Where to Buy
Product Reviews
Last update: Oct 27, 2009
Linksys WMP600N Dual-Band Wireless-N PCI Adapter Reviews
Most helpful positive review
Most helpful negative review
4.0
Very good quality network card
"I purchased this card to network a PC in one of my bedrooms to my broadband connected Linksys N router. I have an 80+ year old house that is made of very dense materials, including steel-mesh lathe plaster walls on the main floor. It's not the ideal building for wireless networking. The Linksys wireless N products have worked much better than anything else I have tried, in a house where extended-range 802.11g h..." Read Full Review »
Sep 09, 2009 by Geoff the IT Evangelist
See more positive Linksys WMP600N Dual-Band Wireless-N PCI Adapter reviews
2.0
Disappointing signal pickup
"I have a wireless G router upstairs. My downstairs desktop crashed and I was using a WUSB54G, which plugged into a USB port and worked great. However, new desktops all come with Vista which is not compatible with the old network adapter. I don't need anything extensive so I went with a basic machine that didn't have built-in already. Figuring I'd go the PCI card route to minimize processing and get one that is d..." Read Full Review »
Sep 30, 2009 by MGinTX
See more negative Linksys WMP600N Dual-Band Wireless-N PCI Adapter reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Overall, very easy to ...
5.0
"Overall, very easy to install and get running with dual band router. Do not really notice much of a drop in performance.
Note that network performance can be enhanced using other bands. Some people install and don't utilize the second band. If that is all you need, don't buy a dual band adapter or …"  Read Full Review »
Was this review on the Linksys helpful to you?
Oct 27 2009
magicman
Undisclosed
2.0
"I have a wireless G router upstairs. My downstairs desktop crashed and I was using a WUSB54G, which plugged into a USB port and worked great. However, new desktops all come with Vista which is not compatible with the old network adapter. I don't need anything extensive so I went with a basic machine …"  Read Full Review »
Sep 30 2009
MGinTX
Dallas, TX
Reviewed at:
Price: $81.99
[1 of 1 customers found this review helpful]
Linksys Wmp600n Wireless-n Db Desktop Ad
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • Quality Construction
  • Stronger Wifi signal
    Cons
  • None
    Best Uses
  • Upgrade
"Great card better than the usb wifi has stronger signal and works with any 32 or 64 os even windows 7 beta rc. "
 Report Abuse  (1)  (0)  0 comments
Jun 17 2009
raptor001
Ocala Fl
I am:
  • Power User
Reviewed at:
I got this because py ...
1.0
"I got this because py former wireless card turned out to be incompatible with Windows version 7 64 bit.
This one plugged in and worked imediately ; self installed. no problems. "
Sep 15 2009
DG
Undisclosed
Got this to use on my ...
3.0
"Got this to use on my wireless network. I'm not too impressed wireless. Connection speed constantly going up and down. This dual band wireless N seems worse than the wirless g I had. "
Aug 23 2009
Roger
Undisclosed
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
