Linksys USB200M Compact USB 2.0 to 10/100 Ethernet Adapter
2.5
based on 4 reviews
Ratings Distribution
5 star
0
4 star
2
3 star
0
2 star
0
1 star
2
Category Average
4.1
More Images
Pros
  • Compact (2)
  • Easy setup (1)
  • Highly compatible (1)
See less See more
Cons
  • Flimsy (2)
  • Weak connection points (2)
  • Can loose it (1)
  • Limited compatibility (1)
  • Unreliable (1)
Best Uses
  • Broken ethernet port (1)
  • Home networks (1)
  • Networking (1)
  • Small offices (1)
Provided by Shoppers Choice
MODEL- USB200M VENDOR- LINKSYS FEATURES- Compact USB 2. 0 10/100 Network Adapter Now you can connect to any 10/100 Ethernet network without having to open your PC. And with the power of USB 2. 0, you ll connect at the full speed your network supports. The Compact USB 2. 0 10/100 Network Adapter from Linksys works with any USB 1. 1 or 2. 0 equipped desktop or notebook PC, running any version of Windows that supports USB. This tiny Plug-and-Play compatible device attaches directly to a USB port on your PC or hub via a standard USB Type A connector. Simply connect a Category 5 Ethernet network cable into the Compact USB 2. 0 10/100 Network Adapter s RJ-45 port, install the included device driver, and you re networked. The Compact USB 2. 0 10/100 Network Adapter is bus-powered, drawing power from the host PC so it requires no external power cord. It features easy-to-read LEDs, compact design, a 1-year limited warranty, and free world-class technical support. NOTE- USB connected devices and Win 95 or Win NT are not compatible. Linksys does not recommend or support the patches available that attempt to make USB connected devices work with Windows 95. Includes Compact USB 2. 0 10/100 Network Adapter, Driver Installation CD with User Guide, USB coupler, Quick Installation guide, Registration Card. Connects at a full 100Mbps via USB 2. 0, up to 8 times faster than a USB 1. 1 adapter. Compact size for greater flexibility Also compatible with USB 1. 1 desktop and notebook computers Plug-and-Play Compatible with Windows 98SE, 2000, Millennium, and XP. -- SPECIFICATIONs ---------------------------STANDARDs - IEEE 802. 3, IEEE 802. 3u USB 1. 0, 1. 1, and 2. 0CONNECTORs- (1) USB Type A, Male port (1) 10BaseT/100BaseTX/RJ45 portSPEED - USB: 1. 5 (Low Speed), 12 (Full Speed), up to 480 Mbps Ethernet: 10 or 100 (Half Duplex), 20 or 200 (Full Duplex) MbpsCABLE TYPE- Category 5 Ethernet Network Cable USB CableINDICATORs- LEDs for 100/ACT, F/H (Full or Half Duplex), 10/ACTREQUIRES - PC with 200MHz or Faster Processor, 64MB RAM Recommended, Available USB Port (USB 2. 0 for maximum throughput), CD-ROM Drive, Windows 98, Millennium, 2000, or XP. APPROVALS- FCC Class B, CE Mark, VCCIPOWER- 3. 3V low power consumptionSIZE - 0. 98 inch x 0. 49 inch x 3. 46 inch WT. - 2. 4 oz. Www. Linksys. Com
Specification Description
Model 737277, USB200M
UPC 745883553402
Interface USB
Network Type Wired Ethernet
Linksys USB200M Compact USB 2.0 to 10/100 Ethernet Adapter Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: USB200M Compact USB 2.0 to 10/100 Ethernet Adapter
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 15, 2009
Linksys USB200M Compact USB 2.0 to 10/100 Ethernet Adapter Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Simple, easy, plug and go
4.0
    Pros
  • Compact
  • Easy To Set Up
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Home Networks
  • Small Offices
"It's hard to get much simpler. I removed the product from the package, plugged the unit into a supplied very short USB cable which plugged directly into a USB socket on my TiVo box, then simply plugged an Ethernet cable into the other end of the product and everything "just worked". A few seconds, …"  Read Full Review »
Was this Computer Cable & Connection review on the Linksys USB200M Compact USB 2.0 to 10/100 Ethernet Adapter helpful to you?
Nov 16 2007
ml
Boston Area
I am:
  • High bandwidth user
Reviewed at:
junk
1.0
    Pros
  • None
    Cons
  • Flimsy Construction
  • Unreliable
  • Weak Connection Points
    Best Uses
  • None
"Electronics are OK. Connection is so flimsy that electrical tape must be used to secure the ethernet cable to the adapter. "
Jan 15 2009
Drew K
Madison WI
Reviewed at:
Causes my computer to crash
1.0
    Pros
  • None
    Cons
  • Limited Compatibility
    Best Uses
  • Networking
"My myriad of computer problems began when I started using this device. I am now seeking a replacement. "
Dec 29 2008
Fastnap
Edmond, OK
I am:
  • Quality Oriented
Reviewed at:
[1 of 1 customers found this review helpful]
works great when ur ethernt port doesn't
4.0
    Pros
  • Compact
    Cons
  • can loose it
    Best Uses
  • broken ethernet port
"works!!!
needed open source software for my mac "
 Report Abuse  (1)  (0)  0 comments
Jun 18 2008
jim the runner
gnv, fl
I am:
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
