Linksys Ultra RangePlus Wireless-N Broadband Router
#293
3.6
based on 461 reviews
from $42.99 - $79.99
Ratings Distribution
5 star
286
4 star
110
3 star
34
2 star
43
1 star
147
Category Average
3.9
Low Price:
$42.99 at Geeks.com
 Trusted:
$79.99 at B&H Photo Video
Find it at Amazon
More Images
Pros
  • Easy setup (127)
  • Fast connection speed (123)
  • Reliable connection (120)
  • Fast (119)
  • Secure connection (113)
  • Secure (10)
  • Highly compatible (9)
  • Small (9)
  • Compact and sleek size (1)
  • Do not purchase this item (1)
See less See more
Cons
  • Difficult to set up (55)
  • Unreliable connection (34)
  • Slow connection speed (14)
  • Unreliable (5)
  • 1st one didn't work right (1)
  • 25ft distance at 162 mbps (1)
  • Blocks wired computers (1)
  • Cables are short (1)
  • Called tech assist (1)
Best Uses
  • Home network (155)
  • Small networks (38)
  • Home (19)
  • Secure networks (7)
  • Large networks (4)
  • Small office (4)
  • 3 computers work great (1)
  • Doorstop (1)
  • Large office (1)
  • Liked the eariler version (1)
Provided by Dell
The Ultra RangePlus Wireless-N Broadband Router is really three devices in one box. First, there's the Wireless Access Point, which lets you connect to the network without wires. There's also a built-in 4-port full-duplex 10/100 Switch to connect your wired-Ethernet devices together. Finally, the Router function ties it all together and lets your whole network share a high-speed cable or DSL Internet connection. The Access Point built into the Router uses the very latest wireless networking technology: Wireless-N (draft 802.11n). By overlaying the signals of multiple radios, Wireless-N's "Multiple In, Multiple Out" (MIMO) technology multiplies the effective data rate. Unlike ordinary wireless networking technologies that are confused by signal reflections, MIMO actually uses these reflections to increase the range and reduce "dead spots" in the wireless coverage area. With Wireless-N, the farther away you are, the more speed advantage you get. But unlike other speed-enhanced technologies, Wireless-N can dynamically enable a double-speed mode for Wireless-N devices, while still connecting to other wireless devices at their respective fastest speeds. In congested areas, the "good neighbor" mode ensures that the Router checks for other wireless devices in the area before gobbling up the radio band. To help protect your data and privacy, the Router can encode all wireless transmissions with industrial-strength 256-bit encryption. It can serve as your network's DHCP Server, has a powerful SPI firewall to protect your PCs against intruders and most known Internet attacks, and supports VPN pass-through. Configuration is a snap with the web browser-based configuration utility. The incredible speed of Wireless-N makes it ideal for media-centric applications like streaming video, gaming, and Voice over IP telephony, and gives you plenty of headroom to run multiple media-intense data streams through the network at the same time, with no degradation in performance. With the
Specification Description
Model WRT-160N, WRT160N, WRT160N - R, WRT160NKM
UPC 745883582983
#per pack 1
Accessory Indicator Yes
Antenna Type Built-in (2), RF Pwr (EIRP) in dBm 17 dBm, antenna Gain in dBi 1.5 dB
Benefits The signal travels up to 3x further and 9x faster than standard 802.11/gWireless signal is protected by wireless encryption for secur
Body Material ABS plastic
Cables Included Ethernet network cable
Capacity UOM mAh
Compatible Platforms Windows XP or Vista
Compliant Standards Draft 802.11n, 802.11g, 802.11b, 802.3, 802.3u
Cordless/Wireless Yes
Country Of Origin China
Data Link Protocol Ethernet
Description Header Faster, smarter and better!
Display Catalog Number 25-398
Enclosure Color Black/Gray
Exclusive Indicator Yes
Features Works great with standard Wireless-G and -B equipmentPlenty of headroom to run multiple media-intense data streams through the networ
Form Factor Built-in (2)
Humidity Range Operating 10-85%
Included in the Box Wireless-N Broadband RouterSetup CD-ROM with Norton Internet SecurityUser Guide on CD-ROMEthernet Network Cable
Inputs 4 x RJ45(Ethernet (1-4)), 1 x Barrel(Power), 1 x RJ11(Internet)
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model WRT160N
Networking Draft 802.11n, 802.11g, 802.11b, 802.3, 802.3u
Networking Compliant Standards Draft 802.11n, 802.11g, 802.11
Networking Features Security features: WEP, WPA, WPA2; Security Key Bits 128-Bit, 256-Bit
New Date Sun Apr 13 00:00:00 CDT 2008
Operating Temperature UOM ° F
Outputs 4 x RJ45(Ethernet (1-4)), 1 x RJ11(Internet)
PC Interface Supported Internet Explorer 6.0 or Firefox 1.0
Product Depth 6.3
Product Dimensions UOM inches
Product Height 1.34
Product Type Wireless
Product Weight 13.4
Product Weight UOM ounces
Product Width 7.95
Required to function Windows XP or VistaInternet Explorer 6.0 or Firefox 1.0CD-ROM DriveWired or Wireless Network Adapter
Software Included Setup CD-ROM with Norton Internet Security
Supported Languages English
Voltage Required 12V, 1A
Linksys Ultra RangePlus Wireless-N Broadband Router Questions
Questions and Answers
Where to Buy
$79.99
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$42.99
$64.99
5% off orders at Abt.com
BizRate Rating Outstanding 9.4
Show all 15 stores
_
Product Reviews
Last update: Nov 20, 2009
Linksys Ultra RangePlus Wireless-N Broadband Router Reviews
Most helpful positive review
[12 of 12 customers found this review helpful]
Most helpful negative review
[44 of 61 customers found this review helpful]
4.0
Good, not QUITE as good as advertised
"First day out of the box, this router was up and running in 30 minutes, with all wireless systems connected. For a few days, all was well til the router decided to dump the older G and B cards and the matched Linksys N Ultra WPC600N Laptop adapter. After resetting the router, all was well again for a few days til again all was dumped, including the hardwired PC. Linksys Tech support was excellent, and suggeste..." Read Full Review »
Jun 08, 2008 by ChrisE
See more positive Linksys Ultra RangePlus Wireless-N Broadband Router reviews
2.0
Not Full "N" speeds
"Pros Great range using 54 Mbps G Cons Slow internet speeds when you use "N draft" Review I bought a WRT160N and I am currently experiencing problems obtain N speeds. I am using a Dell XPS laptop with an internal Intel(R) Wireless WiFi Link 4965AGN that can connect to N draft. I am able to get N speeds of 160 Mbps on my XPS 1530 using WPA and WPA2 encryption, but there is significant slowness with my internet w..." Read Full Review »
Apr 17, 2008 by CMONTAN
See more negative Linksys Ultra RangePlus Wireless-N Broadband Router reviews
Displaying 1 - 5 of 461 Reviews
Show
Sort by
Not Full "N" speeds
2.0
"Pros
Cons
Review
I bought a WRT160N and I am currently experiencing problems obtain N speeds. I am using a Dell XPS laptop with an internal Intel(R) Wireless WiFi Link 4965AGN that can connect to N draft. I am able to get N sp …"  Read Full Review »
Was this Wireless Networking review on the Linksys Ultra RangePlus Wireless-N Broadband Router helpful to you?
 Report Abuse  (44)  (17)  0 comments
Apr 17 2008
CMONTAN
Undisclosed
Reviewed at:
Price: $64.99
[28 of 28 customers found this review helpful]
great router and easy to use!
5.0
"Pros
-Extremely easy to set up
-Powerful signal (full bars) throughout my house
-Network setup wizard a breeze!
-Network Key super-easy to setup through the wizard
Cons
none that I can think of really 'cept maybe the price but then you get what you pay for right?
Review
I was online at the kitchen …"  Read Full Review »
 Report Abuse  (28)  (0)  0 comments
Oct 6 2008
Lechnon
Prescott, AZ
Reviewed at:
Price: $64.99
[2 of 2 customers found this review helpful]
Nothing but issues...
1.0
    Pros
  • None
    Cons
  • Difficult To Setup
  • Slow Connection Speed
    Best Uses
  • Home network
  • Small Networks
"Setup:
Usually, setting up a wireless network at home is a snap. Since I'm pretty well-versed, I generally avoid the set-up wizards and configure the router myself. After seeing a couple of reviews that specifically said to run the cd first, I chose to ignore my instincts much to my detriment. F …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Mar 18 2009
Masemune
Brooklyn, NY
I am:
  • High bandwidth user
Reviewed at:
Price: $64.99
Excellent Wireless Router
5.0
    Pros
  • Easy Security Setup
  • Easy To Setup
  • Fast
  • Fast Connection Speed
  • More »
    Cons
  • None
    Best Uses
  • Home network
  • Small Networks
"I use this router for my laptop in my living room and it is better than the "G" router I had previously, which was a modem/router, but made by the same manufacturer of this product.It is the best wirelss router and it was cheaper here, than at MEGA store [...].There is nothing about this produt that …"  Read Full Review »
Nov 17 2009
akturner3
Eudora, KS near Lawrence, KS
I am:
Reviewed at:
Price: $79.99
I am impressed
5.0
    Pros
  • Easy To Setup
  • Fast
  • Secure Connection
    Cons
  • None
    Best Uses
  • Home network
"I have friends that are seperated by military duty. She is here in California with a new born and he is serving in Iraq. With this device, they are in touch daily with Skype. I researched the wireless online and it worked great. The setup software was superb. I could not believe how smooth it went. …"  Read Full Review »
Nov 10 2009
GoPete
Los Angeles
I am:
Reviewed at:
Price: $74.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
