Linksys RangePlus Wireless PCI Adapter
#248
2.4
based on 8 reviews
from $59.00 - $74.22
Ratings Distribution
5 star
0
4 star
2
3 star
1
2 star
2
1 star
2
Category Average
3.9
Low Price:
$59.00 at www.sayera.com
 Trusted:
$59.99 at PC Connection
Find it at Amazon
More Images
Pros
  • Easy setup (1)
See less See more
Cons
  • Slow connection speed (1)
  • Unreliable connection (1)
Best Uses
Provided by OnSale
RangePlus Wireless PCI Adapter WMP110 - Network adapter - PCI - 802.11b, 802.11g The RangePlus Wireless PCI Adapter installs in most desktop and tower PCs, and lets you put your computer almost anywhere in the building without the cost and hassle of running network cables. Now you don't have to drill holes in your walls and climb ... The RangePlus Wireless PCI Adapter installs in most desktop and tower PCs, and lets you put your computer almost anywhere in the building without the cost and hassle of running network cables. Now you don't have to drill holes in your walls and climb through the attic or cellar to get connected to the network.The Wireless PCI Adapter uses smart antenna technology to achieve extended range. Unlike ordinary wireless networking technologies that are confused by signal reflections, the "Multiple In, Multiple Out" (MIMO) technology actually uses these reflections to increase the range and reduce "dead spots" in the wireless coverage area. The robust signal travels farther, maintaining wireless connections much farther than standard Wireless-G.With MIMO, the farther away you are, the more speed advantage you get. It works great with standard Wireless-G and -B equipment, but when both ends of the wireless link are MIMO enabled, the router can increase the throughput even more by using twice as much radio band.Once you're connected, you can surf the web, keep in touch with your e-mail, and share files and other resources such as printers and network storage with other computers on the network. To protect your data and privacy, your wireless connection is secured by up to 256-bit encryption. Do don't hassle with running cables through your house - get your desktop connected the easy way with the RangePlus Wireless PCI Adapter.
Specification Description
Model WMP110
UPC 745883583317
Interface PCI
Network Type Wireless 802.11b / 802.11g
Wireless Technology Wi-Fi - IEEE 802.11b/g
Wireless Transmission Speed 54Mbps
Linksys RangePlus Wireless PCI Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 31, 2009
Linksys RangePlus Wireless PCI Adapter Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
Don't waste your money, get NetGear WPN311 instead
1.0
"The combination was a LinkSys WRT110 router, which is a very good router, a built-in wireless adapters (XP notebook), and this WMP110 which was put into an XP desktop. I could test range and the router range was excellent. I could also measure signal strength at the location of the desktop with the …"  Read Full Review »
Was this Wireless Networking review on the Linksys RangePlus Wireless PCI Adapter helpful to you?
May 19 2009
BeefBarley
Reviewed at:
DO NOT BUY THIS OR ANY OTHER LINKSYS PRODUCT!!
1.0
"I recently bought this product yesterday and it is terrible. Disconects about every 3-7 seconds, very high latency inside games, and I was getting about 1 mbps up in my room. My router is located downstairs right under my room upstairs. I knew purchasing this card was a bad idea. Linksys was always …"  Read Full Review »
Jan 5 2009
gamer1112
Chicago, IL
Reviewed at:
Works perfect in my 8 ...
5.0
"Works perfect in my 8 years old computer I bild, I got signal quick and plus 6 more from my closers nieghbors, LoL, wow really has great range. "
Nov 17 2009
nova1014
Undisclosed
Works for me
4.0
"Since none of the PCI adapters got great reviews, I went with the linksys one because I have a linksys router. Had initial setup issues because of password problems with router, but works fine after sorting them out. Easy to install, and I'm not a 'computer guy'. A little pricey...more than netgear, …"  Read Full Review »
Feb 12 2009
Will555
Pittsburgh, PA
Reviewed at:
Is not compatible with Vista
3.0
"Not compatible with Vista. Nowhere on the box or in the instructions does it state that it is not compatible with Vista. I only learned this after calling tech support. Technician freely admitted that there was a compatibility problem with Vista but no solution - said I would have to return it to wh …"  Read Full Review »
Dec 10 2008
denali77
Michigan
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
